Manual locks to keyless entry conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 11:15 AM   #1 (permalink)
Dante
Guest
Posts: n/a
View Dante's Photo Gallery
I have a 96 Tacoma with manual locks and windows. I want to convert it
to power locks. I would also like to add an alarm system. Are most
products compatible? Will actuators from one company work with modules
from other companies? Should I try to get everything from the same
company? I'm new to power lock and alarm installation. I've done quite
a few car stereo installations with multiple amp and crossover
configurations so I'm pretty sure that I could figure out the wiring and
installation. Am I wrong? Should I let someone else do it?
What are your opinions?
Thanks,
Dante
Old 10-09-2006, 11:38 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Manual locks to keyless entry conversion
"Dante" <dante@xmission.com> wrote in message
news:egdsk0$sjp$1@news.xmission.com...[color=blue]
>I have a 96 Tacoma with manual locks and windows. I want to convert it to
>power locks. I would also like to add an alarm system. Are most products
>compatible? Will actuators from one company work with modules from other
>companies? Should I try to get everything from the same company? I'm new
>to power lock and alarm installation. I've done quite a few car stereo
>installations with multiple amp and crossover configurations so I'm pretty
>sure that I could figure out the wiring and installation. Am I wrong?
> Thanks,
> Dante[/color]
Assuming you are talking about aftermarket power window and lock conversion
kits, I would search for one that lists which vehicles they will fit rather
than a "universal" one because I would think that a universal one can
involve a lot of cutting and fabricating. If you know the difference
between positive and negative and can use a volt meter, I would not expect
the installation to be technically difficult.
Ray O
Old 10-09-2006, 08:49 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Mon, 09 Oct 2006 10:15:55 -0600, Dante wrote:
[color=blue]
> Thanks,
> Dante[/color]
Shop around. All alarm companies offer add-ins, such as lock actuators,
etc that will allow you do change the vehicle as desired. Even the
cheapest Audiovox ($49-65, depending) has 'options' for power lock
actuators, etc.
BB code is Off
Smilies are Off
[IMG] code is Off
Adding Factory Keyless Entry to 05 Sequoia saodaniel Sequoia Forum 5 05-08-2006 10:53 PM
Keyless entry for an 2005 Camry Standard (CE)? morisato 5th & 6th Generation (2002-2006 & 2007-2011) 3 04-11-2005 04:02 PM
97 Camry Keyless Entry Replacement sgullen 3rd & 4th Generation (1992–1996 & 1997–2001) 7 02-18-2005 03:08 PM
keyless entry programming for 2000 corolla tmc Archived Corolla threads 1 09-30-2004 04:15 PM
GEn 2 Automatic to Manual Conversion phat91camryLE 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-28-2002 05:56 AM
