2002 Avalon drivetrain starting to whine at 28 to 30 miles per hour... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2006, 11:11 PM   #1 (permalink)
Steve Henderson
Guest
Posts: n/a
View Steve Henderson's Photo Gallery
It's a low whine, and only present at 28 to 30 mph, but it's there. Will
it get worse? Is there anything I can do to prevent it getting worse?
Steve Henderson
Old 10-10-2006, 11:18 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2002 Avalon drivetrain starting to whine at 28 to 30 miles per hour...
"Steve Henderson" <hendersr@sbcglobal.net> wrote in message
news:SbEWg.14566$7I1.9891@newssvr27.news.prodigy.net...[color=blue]
> Steve Henderson[/color]
Gear whine is generally not something that develops over time unless there
is fluid loss or incorrect fluid added to the transmission and/or
differential. I would check the condition and fluid level of the automatic
transmission fluid (ATF), and if it was recently serviced, check the type of
ATF that was added.
Are you sure that the whine is not engine RPM-related? In other words, note
the engine RPM that the whine occurs at and see if it happens when you rev
the engine to that RPM with the car in park or neutral. If so, check the
power steering fluid level to make sure it is not low. Low power steering
fluid will make the PS pump whine. This is the most likely cause of the
whine. If the PS fluid is low, check for leaks in the PS system.
Other things that can cause a whine are tires (tread pattern, improper
inflation, or road surface); alternator; wheel bearings; water pump; idler
pulleys; and AC compressor.
Ray O
Old 10-10-2006, 12:53 PM   #3 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:d9bb0$452bbe7a$44a4a10d$21536@msgid.meganewsservers.com...[color=blue]
> news:SbEWg.14566$7I1.9891@newssvr27.news.prodigy.net...[color=green]
> automatic transmission fluid (ATF), and if it was recently serviced, check
> the type of ATF that was added.
> note the engine RPM that the whine occurs at and see if it happens when
> you rev the engine to that RPM with the car in park or neutral. If so,
> check the power steering fluid level to make sure it is not low. Low
> power steering fluid will make the PS pump whine. This is the most likely
> cause of the whine. If the PS fluid is low, check for leaks in the PS
> system.
> Ray O
> (correct punctuation to reply)[/color]
Once again, Ray O comes thru with accurate, complete and concise diagnosis
of a problem. What would we on the ng do without you? Many thanks (even
from one whose Avalon is Not whining!)
Old 10-10-2006, 01:54 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
"mack" <mackerel@dslextreme.com> wrote in message
news:12ink0q867efp84@corp.supernews.com...[color=blue]
> news:d9bb0$452bbe7a$44a4a10d$21536@msgid.meganewsservers.com...[color=green]
>> news:SbEWg.14566$7I1.9891@newssvr27.news.prodigy.net...[color=darkred]
>> there is fluid loss or incorrect fluid added to the transmission and/or
>> check the type of ATF that was added.
>> likely cause of the whine. If the PS fluid is low, check for leaks in
>> the PS system.
>> idler pulleys; and AC compressor.
>> Ray O
>[/color]
Thanks for the vote of confidence! Hopefully, the OP will let us know what
the cause is.
Now, if I could only get my 16 year old daughter to stop whining when one of
her brothers has the Avalon that they share!
Ray O
Old 10-10-2006, 06:45 PM   #5 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
news:5274c$452bdf62$44a4a10d$22142@msgid.meganewsservers.com...[color=blue]
> news:12ink0q867efp84@corp.supernews.com...[color=green]
>> news:d9bb0$452bbe7a$44a4a10d$21536@msgid.meganewsservers.com...[color=darkred]
>>>> Will it get worse? Is there anything I can do to prevent it getting
>>>> worse?
>>>> Steve Henderson
>>> the PS system.
>>> Ray O
>> diagnosis of a problem. What would we on the ng do without you? Many
>> thanks (even from one whose Avalon is Not whining!)
>>[/color]
> what the cause is.
> of her brothers has the Avalon that they share!
> --[/color]
Make sure she has the correct fluid installed.
Old 10-11-2006, 04:14 PM   #6 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:5274c$452bdf62$44a4a10d$22142@msgid.meganewsservers.com...[color=blue]
> "mack" <mackerel@dslextreme.com> wrote in message news:12ink0q867efp84@corp.supernews.com...[color=green]
>> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:d9bb0$452bbe7a$44a4a10d$21536@msgid.meganewsservers.com...[color=darkred]
>>> "Steve Henderson" <hendersr@sbcglobal.net> wrote in message news:SbEWg.14566$7I1.9891@newssvr27.news.prodigy.net...
>>>> It's a low whine, and only present at 28 to 30 mph, but it's there. Will it get worse? Is there anything I can do to prevent it
>>>> getting worse?
>>>> Steve Henderson
>>> Gear whine is generally not something that develops over time unless there is fluid loss or incorrect fluid added to the
>>> transmission and/or differential. I would check the condition and fluid level of the automatic transmission fluid (ATF), and if
>>> it was recently serviced, check the type of ATF that was added.
>>> Are you sure that the whine is not engine RPM-related? In other words, note the engine RPM that the whine occurs at and see if
>>> it happens when you rev the engine to that RPM with the car in park or neutral. If so, check the power steering fluid level to
>>> make sure it is not low. Low power steering fluid will make the PS pump whine. This is the most likely cause of the whine. If
>>> Other things that can cause a whine are tires (tread pattern, improper inflation, or road surface); alternator; wheel bearings;
>>> water pump; idler pulleys; and AC compressor.
>>> Ray O
>> Once again, Ray O comes thru with accurate, complete and concise diagnosis of a problem. What would we on the ng do without
>> you? Many thanks (even from one whose Avalon is Not whining!)
>>[/color]
> Thanks for the vote of confidence! Hopefully, the OP will let us know what the cause is.
> Now, if I could only get my 16 year old daughter to stop whining when one of her brothers has the Avalon that they share!
> Ray O
>[/color]
Hehe, take away the phone. She will be so upset everybody will forget about the car!
Just kidding Ray, I would wish the battle that would start on any other teenagers father.
Dan
Old 10-11-2006, 06:46 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Danny G." <dandog@pacbell.net> wrote in message
news:NgcXg.15610$7I1.6901@newssvr27.news.prodigy.net...[color=blue]
> news:5274c$452bdf62$44a4a10d$22142@msgid.meganewsservers.com...[color=green]
>> news:12ink0q867efp84@corp.supernews.com...[color=darkred]
>>>>> worse?
>>>>> Steve Henderson
>>>> the PS system.
>>>> Ray O
>>>[/color]
>> what the cause is.
>> Ray O
>>[/color]
> about the car!
> teenagers father.
> Dan
>[/color]
Been there, done that. Getting wisdom teeth pulled is a lot less painful!
Ray O
Old 10-12-2006, 10:33 AM   #8 (permalink)
Danny G.
Guest
Posts: n/a
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:effea$452d7928$44a4a10d$32581@msgid.meganewsservers.com...[color=blue]
> "Danny G." <dandog@pacbell.net> wrote in message news:NgcXg.15610$7I1.6901@newssvr27.news.prodigy.net...[color=green]
>> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:5274c$452bdf62$44a4a10d$22142@msgid.meganewsservers.com...[color=darkred]
>>>>>> it getting worse?
>>>>>> Steve Henderson
>>>>> if it was recently serviced, check the type of ATF that was added.
>>>>> if it happens when you rev the engine to that RPM with the car in park or neutral. If so, check the power steering fluid
>>>>> level to make sure it is not low. Low power steering fluid will make the PS pump whine. This is the most likely cause of the
>>>>> bearings; water pump; idler pulleys; and AC compressor.
>>>>> Ray O
>>> Ray O
>>>[/color]
>> Dan
>>[/color]
> Ray O
>[/color]
eek, correction. "I would not wish the battle that would start on any other teenagers father."
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 5 06-01-2011 07:59 PM
1st issue with 07'Camry AESANTIAGO 5th & 6th Generation (2002-2006 & 2007-2011) 949 01-08-2008 03:49 PM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 12:14 PM
