Re: tire size and speedometer accuracy
I'm with you on this one. I can't see how the car would know the tires are a
different size, and alter the speedo calibration by itself.
If the original size and the new size are compliments of each other, then it
is easily possible that the speedo is not affected enough to warrant
changing gears.
I don't know the tires that the Element comes with, but assuming a size,
there are other sizes that offer more tread contact area, but are the same
diameter -- within a half-inch -- which would not adversely alter the speedo
accuracy (and the new tires would be larger, making the speedo a bit slower
and probably improve its accuracy anyhow).
For example, a 235/75x15 is 28.89 inches in diameter, wheras a 255/70x15 is
29.05 inches. The difference in DIAMETER is less than 1/4 inch. But, the
contact patch would be wider by 20 mm, or about 3/4 inch. More on the
ground, but hardly any change in speedo accuracy, and any change would
probably make it more accurate than it already is.
"Dennis Leong" <spgdxl@berkeley.edu> wrote in message
news:eggn1l$16rd$1@agate.berkeley.edu...[color=blue]
> When I was hot rodding in the late '60s, I spent a lot of time researching
> how tire size and different differential gear ratios affected speedometer
> accuracy. I bought a lot of different speedo drive gears for the tranny
> (this was on a GM TH400) to compensate for the changes I made. All this
> just to keep my speedo as close accurate as possible as I didn't want to
> speed and collect tickets. Now someone tells me that after putting in
> larger diameter tires on his car (Honda Element), the tire dealer said
> that his speedo would still be accurate. I find this hard to believe.
> Are today's electronics intelligent enough to automatically adjust for
> different diameter tires? I would think at least something needs to be
> manually re-calibrated? This is a good group to get information even
> though this is not a Toyota specific issues. Thank you.
>[/color]
