Cam and Crank shaft timing position - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 08:11 PM   #1 (permalink)
SlyckTom
Guest
Posts: n/a
View SlyckTom's Photo Gallery
Hi all,
I've posted previously about a timing belt job I did on my 93 Toyota
Corolla DX, 203,000 miles (automatic.) ( [url]http://tinyurl.co.uk/r6o7[/url] )
Since I've only owned the car for a short period, I've been suspicious
of a slight engine vibration. From the research I've conducted, this
appears to be very normal. I simply have not owned the car long
enough to remember if there was a vibration or not before I did the
timing belt job...
In any case, my speculation got the better of my and I decided to pull
the cam cover and see if the crank and cam timing tic marks match up.
Since its impossible to describe, I set the crank shaft pulley at 0
degrees and took the following pictures:
side view: [url]http://www.networkjournalism.com/images/side_view02.gif[/url]
top view: [url]http://www.networkjournalism.com/images/top_view01.gif[/url]
As you can tell from the side picture, the cam marking is virtually
dead on. However, it appears a bit left of center. Its not so
obvious from the top view.
If I move the crank shaft so the cam timing mark is more center (which
is a literally a millimeter of movement towards the right), the crank
moves a few degrees. I don't have much faith in the plastic timing
cover tho...when I removed it, it had some damage that I repaired -
therefore its shape may not be 100%.
In any case, my big concern and question is whether the pics fall
within the realm of acceptability. I was sure that it was lined up
when I did the job...but at tight angles its kinda tough to see
straight on.
Thank you all again. You guys are the only mechanics I trust.
Tom
BB code is Off
Smilies are Off
[IMG] code is Off
Timing questions tracyf Camry & Solara Lounge 11 03-23-2006 11:28 PM
Hi... ? on 5s-fe cam timing advance. AVL92CAMRY Camry & Solara Lounge 4 10-01-2005 06:23 PM
Timing Belt Trouble Anti325 Camry & Solara Lounge 15 06-07-2005 06:36 PM
Question about the Cam and Crank Angle Sensors T28miata Camry & Solara Lounge 7 10-16-2003 02:37 AM
Bluetop 4A-GE Cam Timing... wunderboy Hardcore Tech and Competition 3 07-28-2003 03:00 PM
