99 corolla hesitation issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2006, 08:37 PM   #1 (permalink)
Adam
Guest
Posts: n/a
View Adam's Photo Gallery
Hi all,
i was wondering if any of you can help me identify this problem my 99
corolla hesitates every most of the time i step on the gas as if it not
getting enough gas to the engine. i changed the spark plugs, spark plug
wires, added fuel injector fluid and it is still happeneing. since the
fuel filter is in the tank and is irreplaceable, how can i have my car
stop hesitating when i try to speed up?
thanks
Old 10-11-2006, 12:47 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 99 corolla hesitation issue
"Adam" <aelbizri@ameriquest.com> wrote in message
news:1160527022.268188.225080@e3g2000cwe.googlegroups.com...[color=blue]
> Hi all,
> thanks
>[/color]
Several things can cause the hesitation: incorrect base ignition timing;
incorrect spark plugs; some aftermarket spark plugs and spark plug wires;
dirty MAF sensor; manifold vacuum leak; leak in the snorkel between the MAF
sensor and throttle body; dirty fuel injectors; bad fuel pump; bad fuel
pressure regulator; clogged fuel filter; clogged fuel pickup; contaminated
fuel filter; incorrectly installed timing belt/chain.
Your best bet at resolving the issue is to have the vehicle diagnosed by a
Toyota dealer service department or competent independent technician.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 06:19 PM
99 corolla V3 dasrightbrian Introduce Yourself Here 0 04-13-2006 08:44 PM
New ECU for a Corolla 99 Gargola15 Archived Corolla threads 0 09-02-2005 12:43 AM
'99 corolla gear questions tmoney5 Archived Corolla threads 0 07-01-2005 01:18 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
