Leave em in or replace....advice please - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2006, 06:17 PM   #1 (permalink)
doncee
Guest
Posts: n/a
View doncee's Photo Gallery
Just replaced plugs on my 94 pick up w\ 22re engine. As
always have done in the past I purchased the plugs from my
trusty Toyota dealer. Had done this previously in 2002 but this
time after I removed the old plugs realized that the new plugs
were different. Checked the depth\etc of the new plug & it
matched, so went ahead & installed the new ones & fired up the
truck & it ran just fine. Just assumed that they had changed the
plug to a newer design. Couple days later was passing by the
dealer & drove in & found the same parts guy & asked him when
they changed to the new plug & design & he says they hadn't!!!
Turns out he had the platinum(iridium) plugs in the wrong slot &
had picked them up by mistake.
My question now is should I remove the platinums & replace
them w\ the correct plug, which by the way, they gave me @ no
charge or just leave them alone. Truck is running fine w\ the
platinums installed but service manager said he would be afraid
that over a long period of time may do some damage cause they
are a "hotter" plug than the conventional ones.
Advice needed from those of you that know how this may
affect my engine would be appreciated.
Thanks
dc
Old 10-13-2006, 12:19 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Leave em in or replace....advice please
"doncee" <nodbcspam9814wanted@charter.net> wrote in message
news:Xns985AB07AD64C1medbcSWBEll@216.196.97.131...[color=blue]
> Thanks
> dc[/color]
The automaker specifies certain plugs for a reason, the most important being
fit and heat. If you can find out the specifications for heat range for the
plugs that are installed in your truck and compare them with the correct
plugs and they are the same, then you can leave them in. If you cannot find
out the info or you want to be absolutely positively sure that they do not
harm your engine, swap the plugs for the correct ones.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
ignition leads replace one or the lot???? 94_v6_camry 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-29-2006 02:07 PM
Replace Bearing and Camper costs $492 kdyj 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-01-2006 04:27 PM
need advice how to replace the washer flui tank mitsubishi_powe Camry & Solara Lounge 5 02-16-2006 07:32 PM
Newbie Toyota maintenence advice xsaabguy Camry & Solara Lounge 0 03-07-2003 07:44 AM
