brake pedal problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2006, 03:58 AM   #1 (permalink)
ykutluay@gmail.com
Guest
Posts: n/a
View ykutluay@gmail.com's Photo Gallery
brake pedal problem
I have an 89 toyota corolla with a brake problem:
Pressing down the brake pedal, with a relatively low amount of
pressure, the pedal seems to have gone all the way down, as i can feel
the pedal hitting a bottom and hear the knocking sound. However, at
this point, even at around 10 - 20 mph speeds car continues to move
forward and can't get the tires to skid.
When I press down a lot harder beyond that point, even though the pedal
doesn't seem to go any further, I can get tires to skid. But I mean..
really a lot of pressure compared to what I know how brakes should be.
I don't really feel the problem when driving normally, but a hard brake
reveals that I need to do some extra thinking other than reflexes in
case of emergencies.
Any one had the same problem or have any ideas?
Thanks.
Old 10-13-2006, 12:41 PM   #2 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Re: brake pedal problem
[email]ykutluay@gmail.com[/email] wrote:[color=blue]
> pressure, the pedal seems to have gone all the way down[/color]
Master cylinder - rebuild or replace
Old 10-13-2006, 12:45 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<ykutluay@gmail.com> wrote in message
news:1160726307.142196.222000@m7g2000cwm.googlegroups.com...[color=blue]
> Thanks.[/color]
I recommend that you not drive the car and have it diagnosed by a competent
technician ASAP. Possible causes are worn brake linings and / or
mis-adjusted rear drum brakes, leaking caliper or wheel cylinder, or bad
master cylinder.
Ray O
Old 10-13-2006, 11:17 PM   #4 (permalink)
: P
Guest
Posts: n/a
View : P's Photo Gallery
I agree...you've got a bad Master Cylinder. The problem you describe is
called Pedal Fade. (Brakes seem to work fine under highway driving
conditions, but in city stop & go traffic, the pedal goes to the floor.)
Probably better to replace with a new one instead of a rebuilt. The Master
Cylinder body is aluminum and probably has some pitting in the bore. Also
the steel pistons inside have worn away some of the anodizing, which caused
the pitting problem.
<nospampls2002@yahoo.com> wrote in message
news:1160757715.668932.34150@f16g2000cwb.googlegroups.com...[color=blue]
> [email]ykutluay@gmail.com[/email] wrote:[color=green]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
2001 soft brake pedal problem Lunar Mist 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-14-2006 10:48 PM
Some problem with accelerator pedal tonysun23 3rd & 4th Generation (1992–1996 & 1997–2001) 6 08-04-2006 03:27 AM
Brake and Tranny Problem fastwrx 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-01-2006 07:33 PM
need quick help! brake problem ag3nt911 Archived Corolla threads 1 11-29-2005 01:07 AM
