why prius front tire pressure higher than rear? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-14-2006, 11:10 AM   #1 (permalink)
perfb@yahoo.com
Guest
Posts: n/a
View perfb@yahoo.com's Photo Gallery
prius tire pressure spec says 35 psi front, 33 psi rear
just wondering what the technical reason for this is?
do other cars do this too?
Old 10-14-2006, 02:05 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: why prius front tire pressure higher than rear?
<perfb@yahoo.com> wrote in message
news:1160842203.607730.180060@i42g2000cwa.googlegroups.com...[color=blue]
>[/color]
My guess is that since the Prius is front wheel drive, the higher pressure
will help improve fuel economy. Lower pressure in the rear reduces some of
the ride harshness.
It is more common to see higher tire pressure specified for the rear tires,
especially for rear wheel drive vehicles, because that is where the cargo is
usually carried.
Ray O
Old 10-14-2006, 03:05 PM   #3 (permalink)
Dick Byrd
Guest
Posts: n/a
View Dick Byrd's Photo Gallery
The front axle of a front-wheel drive car carries 55%-65% of the total car
weight, requiring more air pressure in the front tires.
Additionally, the front axle is carrying 80%-90% of the total car weight
under heavy braking, when the "weight-shift" causes the car to nosedive from
the deceleration.
Dick
>[/color]
Old 10-14-2006, 03:37 PM   #4 (permalink)
Ron Sleeter
Guest
Posts: n/a
View Ron Sleeter's Photo Gallery
>[/color]
Put in 42 front, 40 rear for maximum mpg.
Old 10-14-2006, 03:48 PM   #5 (permalink)
A Sherman
Guest
Posts: n/a
View A Sherman's Photo Gallery
"Ron Sleeter" <Tondaleo@hotmail.com> wrote ...[color=blue][color=green]
>>[/color]
> Put in 42 front, 40 rear for maximum mpg.[/color]
I did this to try to compensate for the tread wearing more at the edges
than at the center. I can't say that I've seen any difference in mpg.
Al
2005 with 20K miles
Old 10-14-2006, 07:54 PM   #6 (permalink)
Andrew Stephenson
Guest
Posts: n/a
View Andrew Stephenson's Photo Gallery
In article <StCdnQnsRooC16zYnZ2dnUVZ_oGdnZ2d@comcast.com>
[email]Tondaleo@hotmail.com[/email] "Ron Sleeter" writes:
[color=blue]
> news:1160842203.607730.180060@i42g2000cwa.googlegroups.com...[color=green]
> > do other cars do this too?[/color]
Um. I mis-read the pressure chart on my Prius and over-inflated
the tyres. Fortunately, not long afterwards I happened to visit
the dealer/garage (the same that gave out champagne to compensate
for a recall's "hassle") and happened to mention the pressure I'd
used... A strained look crossed the face of the dealer-bod, who
suggested that he take the car aside and adjust the pressure down
to what was _actually_ recommended on the chart. He did and the
mpg stayed much the same: currently getting around 57mpgUK. OTOH
I suspect tyre life and the safety of my ride improved. (FWIW, I
don't have the tyre pressure tables handy.)
(BTW, 57 mpgUK == 45.6 mpgUS.)
Andrew Stephenson
Old 10-16-2006, 01:44 PM   #7 (permalink)
perfb@yahoo.com
Guest
Posts: n/a
I read elsewhere about this use of 42 psi for mileage, but it seems to
me it would compromise safety by decreasing skid threshold in the event
of a rapid stop and/or rapid maneuver on wet roads?
Ron Sleeter wrote:[color=blue]
> >[/color]
Old 10-16-2006, 02:10 PM   #8 (permalink)
Bill
Guest
Posts: n/a
View Bill's Photo Gallery
news:1161024292.134048.136190@k70g2000cwa.googlegroups.com...[color=blue]
>[/color]
Maybe by one percent. Proper inflation is important to minimize the
possibility of bruise breaks from hitting pot holes and stress fractures
leading to a thrown tread. The 42/40 pressures recommended by many (I use
these pressures) are within my tire's rating.
Old 10-16-2006, 02:17 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
>[/color]
I have never heard of the term "skid threshold" but if you are talking about
the point at which the tires lose traction with the road surface or
something like the coefficient of friction, then the higher tire pressure
doesn't compromise safety. There are so many variables that affect tire
performance and tire life that a change in 1 variable will be offset by
changes in others.
Ray O
[color=blue]
> Ron Sleeter wrote:[color=green]
>> news:1160842203.607730.180060@i42g2000cwa.googlegroups.com...[color=darkred]
>> >[/color]
>[/color]
Old 10-16-2006, 11:51 PM   #10 (permalink)
Carl Powell
Guest
Posts: n/a
View Carl Powell's Photo Gallery
My wife and I have noticed that the difference between the 35 lbs that my
dealer uses and the 41 I put in at the next fill-up is about the difference
between 42.x and 47.x Avg.MPG. We have never had any problem with traction.
Here in Tidewater VA we run about 60/40 interstate/street. I-64 is concrete
mostly with longitudinal drain groove cutting. (don't know if that makes any
difference or not, but it makes some nifty 'whistling' at 60 when the
pavement is new and the grooves are just put down.)
Carl Powell
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:74db6$4533db37$44a4a10d$929@msgid.meganewsservers.com...[color=blue]
> news:1161024292.134048.136190@k70g2000cwa.googlegroups.com...[color=green]
>>[/color]
> about the point at which the tires lose traction with the road surface or
> changes in others.
> Ray O
>[color=green]
>> Ron Sleeter wrote:[color=darkred]
>>[/color]
>[/color]
Old 10-17-2006, 06:36 AM   #11 (permalink)
B A R R Y
Guest
Posts: n/a
View B A R R Y's Photo Gallery
[email]perfb@yahoo.com[/email] wrote:
[color=blue]
>[/color]
My 2005 4WD Access Cab Tacoma does the same.
Old 10-17-2006, 11:51 AM   #12 (permalink)
mark_digital©
Guest
Posts: n/a
View mark_digital©'s Photo Gallery
>[/color]
It's to keep your high-beams high enough off the ground.
mark_
Old 10-18-2006, 01:26 AM   #13 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On 14 Oct 2006 09:10:03 -0700, "perfb@yahoo.com" <perfb@yahoo.com>
wrote:
[color=blue]
>just wondering what the technical reason for this is?[/color]
Because more weight is in the front of the car than the rear, so
with a light load you want the pressure a bit higher at the heavy end
to keep the tire wear even.
I'll bet it calls for 35 and 35 if you have four or five passengers
and a full load in the trunk for a trip - and if not, that's where I'd
put it. If the sidewalls allow higher, I'd bump them both up to the
maximum pressure if you are carrying a maximum load.
[color=blue]
Lots of cars do, some far more pronounced than that two-pound split.
Whenever all the weight is at one end, the tire pressures have to be
staggered to match.
My Chevrolet Corvair (rear engine aft of RWD axle) has a severe rear
weight bias and calls for 14 PSI front, 28 PSI rear. (With radials, I
ran it at 18/32.) The early VW Beetle and Porsche 911 series have the
same layout and a similar rear pressure higher stagger.
--<< Bruce >>--
Old 10-18-2006, 07:45 AM   #14 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Wed, 18 Oct 2006 06:26:37 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
> --<< Bruce >>--[/color]
With a slightly different reaction to the throttle.....
Scott in Florida
Old 10-18-2006, 11:53 AM   #15 (permalink)
mrv@kluge.net
Guest
Posts: n/a
View mrv@kluge.net's Photo Gallery
[email]perfb@yahoo.com[/email] wrote:[color=blue]
something to do with weight distribution.
I tried running my Classic Prius with the same pressures front and
rear. I didn't do that for long - the car felt like it would fishtail
at a panic stop, whereas with a +2 or +3 psi difference in the front it
would stick those same panic stops. (Beware of those Dunkin Donut
shops in the morning commute!)
[color=blue]
My cousin's Chevy Malibu is 29 psi front, 26 psi rear.
BB code is Off
Smilies are Off
[IMG] code is Off
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
Tire pressure tips EKam Hardcore Tech and Competition 29 12-20-2005 11:28 AM
Group BUY: Whiteline RSB rear sway bar tlam617 Camry & Solara Lounge 32 02-11-2005 02:52 PM
Pro Comp Tire Seperation Causes Crash Z71sc Feedback: Buyers, Sellers, and Vendors 0 10-19-2004 05:01 PM
