carina e engin bush replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2006, 05:46 AM   #1 (permalink)
johnsmile123@hotmail.com
Guest
Posts: n/a
View johnsmile123@hotmail.com's Photo Gallery
I have a 1995 toyota carina e , engin type 4A-FE. I need to change the
engin bush. Can i do it myself by supporting the engin with a jack and
undo those bolts from the engin bush arm (3bolts) and then the middle
bolt from the bush and push the round rubber bush out and replace it?
This bush is just above the steering rack and it is very hard to see by
the way.
Any advice please.
Thankyou in advance
Old 10-15-2006, 11:30 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: carina e engin bush replacement
<johnsmile123@hotmail.com> wrote in message
news:1160909165.333959.9010@e3g2000cwe.googlegroups.com...[color=blue]
> the way.
> Any advice please.
> Thankyou in advance
>[/color]
The problem with supporting the engine with a jack is that you run the risk
of crushing the oil pan. You may be able to support the engine and
transmission on the bell housing, or you can rent or borrow an engine
support that supports the engine from above. Most likely, you will be able
to change the part without having to use the jack, other than lining up the
bolts.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
5S-FE Timing Belt Replacement mskhan18 Camry & Solara Lounge 8 05-30-2006 11:31 AM
Bush Turns to Rita's Hit on Oil Industry (oh, its about oil, let me show my face arou SolaraTRD Off Topic 0 09-26-2005 08:09 AM
97 Rear stabilizer bush. replacement Jeff423 1st Generation (1995-1999) 2 01-21-2005 07:57 AM
why would anyone vote bush??? JDAN Off Topic 161 11-16-2004 12:28 PM
Whiteline Bushings speedemn Camry & Solara Lounge 18 04-01-2002 06:58 PM
