Oddest thing happened to me yesterday: I went to the car, unlocked the
drivers door and the handle snapped in two as I lifted it! The piece
that came off is about 3/4 of the entire handle. Has anybody ever had
this happen and is the replacement difficult?
"Jimbo" <jfroche@gmail.com> wrote in message
news:1161006853.633368.13290@i3g2000cwc.googlegroups.com...[color=blue]
> Thanks.
>[/color]
It has never happened to me but I've seen cars that it has happened to.
Replacement is not difficult. When you get the new handle, also get the
clip that attaches the handle to the rod because the clip is pretty
inexpensive and is likely to break when you take it apart. You will need a
10 mm wrench, Phillips screwdriver, and some duct tape.
Raise the window all the way up and remove the interior door panel and the
plastic sheet underneath. Don't worry if the plastic rips - you can repair
it with duct tape when you put it back together. Unclip the rod from the
handle - if the clip breaks, then you already have a replacement on hand.
The handle is held in place with a couple of nuts, my guess is that they are
10 mm. Remove the nuts, pull the handle off from the outside, and reverse
the process.
On Mon, 16 Oct 2006 06:54:16 -0700, Jimbo wrote:
[color=blue]
> Thanks.[/color]
Yeah, what Ray said!
You will also see a round black dot about the size of a half dollar. If
you peel this VERY CAREFULLY you'll be able to reseal it. That's the
access to one of the 10mm nuts, the other is through the door (after you
remove tha panel, of course!)
Hachiroku wrote:[color=blue]
>[color=green]
> > Thanks.[/color]
> remove tha panel, of course!)[/color]
Thanks for your advice. It doesn't sound too difficult. I picked up
the handle (which cam ewith a clip) from my local dealer last night
who had it in stock. It cost CAD56 which wasn't too bad :) I asked
about the frequency of the handle breaking and they said they get an
occasional request but often enough that they keep 1 or 2 in stock.
Tomorrow evening I'm going to do the job.
On Tue, 17 Oct 2006 09:45:02 -0700, Jimbo wrote:
[color=blue]
> Hachiroku wrote:[color=green]
>>[color=darkred]
>> > Thanks.[/color]
> Tomorrow evening I'm going to do the job.[/color]
1. What year Tercel is it?
2. $56!!!! Next time, go to a Junkyard! I got one for $7 US!!!
>[color=green]
> > Hachiroku wrote:[color=darkred]
> >> > Thanks.
> 2. $56!!!! Next time, go to a Junkyard! I got one for $7 US!!![/color]
It's a 97 and, yes, I'd normally use a breakers except none of the
local ones had a handle available. Anyway, I tried to remove the door
liner today and found one screw inside the inner handle which I
removed, I then pulled the liner from the front of the door, across the
bottom but got stuck coming up the back of the door. Is there another
screw in there somewhere?
On Sat, 21 Oct 2006 15:39:22 -0700, Jimbo wrote:
[color=blue]
>>[color=darkred]
>> >> > Thanks.
> Thanks.[/color]
Let's see if I can remember...it's been four years!
There are two .covers. you have to remove, they pop out with a
screwdriver, and there are two large brass colored screws under them. I
think there is aslo a screw in the little indentation you pull the door
closed with...I don't think it has a cover over it, and there is a screw
behind the hadle you pull to open the door. I believe that's it! Then you
grasp the bottom, pull out until the panel frees, and then lift up.
You may want to remove the cover over where the mirror mounts to the door,
but it's not really necessary.
And, while you're in there, replace the speakers with some 4 ohm 2 ways, 5
inches or so! ;)
