Re: Just Bought 96 Camry 2.2L
"Ralph Shapiro" <ralph.shapiro@sonoma.edu> wrote in message
news:Q4PYg.41$4L4.9963@okeanos.csu.net...[color=blue]
> Just bought this Camry with 82K on the clock.
> There are a couple of problems with this car.
> 1) RF power door lock doesn't work from inside. Turn the key in the
> drivers
> door, all doors but the RF unlock.
> 2)RR window doesn't work from drivers door.[/color]
Using a wiring diagram, check the master switch on the driver's door. If
the master switch checks out, then check check the door lock solenoid and
power window motor.
[color=blue]
> 3) Won't idle cold. Will start on a click, but I need to hold the idle up
> for about two minutes before car will run on it's own.[/color]
Check the idle air control valve.
[color=blue]
> I read through the manuals and timing belt change is 60K in Severe use,
> what
> is normal use miles for change? What beside the belt is good to change at
> the same time? Average cost, in hours, for this.[/color]
I would change the timing belt at around 90k. While you are at it, get the
accessory drive belt and water pujkp changed. A lot of Toyota dealers
advertise timing belt specials so check with your local dealers.[color=blue]
> What about valve adjustment? My Chilton manual (poor book) indicates shims
> and buckets to adjust. Is this so? At what miles do the valves get
> adjusted?
Yes, the car has buckets and shims. I would get valves adjusted at 120K,
flat rate time is probably 2 hours.
[color=blue]
> Can anybody provide some assistance on these issues? Doesn't seem like a
> car
> with 82K should be like this, this is why I bought it!
> Thanks for any help!
>[/color]
Ray O
