Toyora Previa Heat Problem 1994 LE 2wd - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2006, 03:23 PM   #1 (permalink)
farmerblanche@gmail.com
Guest
Posts: n/a
View farmerblanche@gmail.com's Photo Gallery
We have some heating problems with our Toyota Previa. The heat only
works sometimes - only when we are driving and not when we are stopped.
And only sometimes when we are driving. Even if we are idling there is
no heat. Also Our air conditioning has not worked for the last year so
I don't know if that can effect it as well.
Any help on what to look into would be greatly appreciated. I already
have a Previa repair manual so if someone could point me in the right
direction that would be great
Cheers
Blair Mac
Old 10-18-2006, 03:40 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Toyora Previa Heat Problem 1994 LE 2wd
<farmerblanche@gmail.com> wrote in message
news:1161202995.564826.189240@i42g2000cwa.googlegroups.com...[color=blue]
> Cheers
> Blair Mac
>[/color]
What does the coolant temperature gauge on the instrument cluster show? If
it shows low, then the thermostat may be stuck open. Check the engine
cooling section of the repair manual.
If the coolant temperature gauge shows normal temperatures, then the heater
control valve may not be opening because it is blocked or the control wire
is disconnected or broken, or the heater core may be clogged, or the damper
control wire may be disconnected or broken. Check the HVAC section in the
repair manual.
Ray O
Old 10-18-2006, 03:43 PM   #3 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
> works sometimes -[/color]
Most likely cause is the thermostat is stuck open. Bet the engine temp
fluctuates quite a bit too.
MIGHT be the water pump impeller has corroded away as well.
May just be low coolant level. Could be the main rad hoses or heater hoses
are soft and restricting flow.
[color=blue]
>Also Our air conditioning has not worked for the last year.[/color]
Separate problem, commonly caused by the O-rings in the a/c hose fittings
leaking. May be the hoses themsleves. Get a quote on refurbing your system,
converting to r143a if required. Sit down befoe you get the numbers...
Your starting point is a new set of hoses and clamps, a thermostat, and a
flush / refill of the whole cooling system.
SD
Old 10-18-2006, 03:49 PM   #4 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
> Cheers
> Blair Mac[/color]
Blair,
I'm writing in generalizations because I'm not terribly familiar with the
Previa van but here are some generalizations which may help you diagnose the
problem.
Your heater core is a mini-radiator behind the dash. Hot coolant passes
from the engine through the heater core; the heater fan blows air through
the fins which warms it. There's a valve, activated by the dash "cold-hot"
lever through a cable, which opens to let coolant flow through the core.
There are three things that can go wrong with this system: The coolant
flowing through the core isn't itself hot, the coolant is not flowing
through the core, or the air to be warmed is not passing through the core.
The most potentially damaging is the first, as it likely means that your
engine is not running at the correct temperature. If the temperature gauge
is reading low you may have a thermostat stuck in the open position or
perhaps completely removed by a previous owner / inept mechanic.
The coolant may not be flowing through the core properly. Find the valve -
look at the firewall and there will be two hoses (about the size of a garden
hosepipe) coming from the dash. One will go to somewhere on the engine; the
other will go to a device on the firewall - that's your valve. See if you
can manipulate it to the open position manually and check whether that
solves your problem. If so it's just a matter of adjusting or replacing the
cable control. If not, you can bypass the valve altogether. If you get
heat the problem is with the valve itself.
Still no heat? The core itself may be clogged. You can try removing the
hoses from the dash and running water through the heater core through a
hosepipe (this all from the firewall side of the engine compartment). Don't
use a lot of pressure; just see if a stream of water flows through the core.
If so, your problem likely lies elsewhere. If not, you'll have to replace
the heater core.
Finally, it's possible that the hoses going to the core itself are clogged.
I have not personally seen this happen but it is a possibility.
If it appears that hot coolant is flowing through the core, your problem may
be with airflow. The core's fins are fine and can become clogged with hair,
dust bunnies etc., particularly if you have pets. I replaced an evaporator
(the air conditioning equivalent of the heater core) in my 95 Tacoma last
year and was dismayed at how much cat hair had accumulated, simply from
being carried into the truck from my clothes.
This should give you a start.
Mike Harris
Austin TX
Old 10-18-2006, 03:56 PM   #5 (permalink)
Guest
Posts: n/a
thanks you all for your insight I will be trying to fix it tommorrow
and will let y'all know
Cheers
Blair
BB code is Off
Smilies are Off
[IMG] code is Off
1995 Previa MINIVAN LE S/C All Trac AWD Annabelle Vehicles 0 10-14-2006 05:20 PM
Toyota Corolla 2000 LE - battery problem? hyankov Archived Corolla threads 4 09-09-2006 01:20 AM
98 Camry LE Problem (Odometer stuck at 0) Prophecy 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-28-2004 01:58 AM
FS: 1994 Toyota Camry V6 LE BTL Vehicles 3 05-12-2003 12:43 AM
DARK GREEN 1994 V6 LE CAMRY FOR SALE !! SkyLiNE Vehicles 0 08-31-2002 10:46 PM
