On 19/10/06 12:42 PM, in article [email]1161225750snz@deltrak.demon.co.uk[/email], "Andrew
Stephenson" <ames@deltrak.demon.co.uk> wrote:
[color=blue]
> In article <C15D1432.EDF6%hbaj2006@aapt.net.au>
> [email]hbaj2006@aapt.net.au[/email] "Hammo" writes:
>[color=green]
>> [...] However, the wire that connects the lot (to my
>> understanding) is supposed to be putting out 5 volts.
>> This wire fluctuates between 0-10 volts. [...][/color]
> I have not seen the circuit, so this wild-ass guess may be 100%
> wrong. But it smells like a 5-volt stabiliser chip is not doing
> its job. Either it has blown (and
AFAIK semiconductors usually
> fail short-circuit, meaning the unregulated input is being sent
> straight through to what should be the 5v regulated output) or
> the ground connection has become open-circuit (which could be
> caused by (eg) a mechanical break or corrosion).
> The physical form of stabilisers depends on the power handled:
> either what looks like a low power transistor (three wire leads
> going into a plastic blob) or a medium-power transistor (three
> robust wires going into a flattened package, whose other edge has
> a metal tab screwed onto metalwork, commonly with some insulation
> between the tab and metalwork).[/color]
Thanks for the help/suggestion.
Cheers
H
