Re: Landcruiser Power Outlet Relay
"PTCA" <not@this.address> wrote in message
news:ghsdj2d12f79aemejq81vkmrplateet2vn@4ax.com...[color=blue]
> I'm trying to make the 12v power outlets in my 2003 Landcruiser live
> all the time. I can't find the power outlet relay in the fuse panel at
> all. The fix for Tundras doesn't seem to work for the Landcruiser
> because I can't tell which one is the relay for the power outlets.
> Does anyone know where it is located or what it is labeled?
> Thanks,
> Chris[/color]
The 12 volt power outlets in Toyotas are generally not powered through a
relay, just through a fuse. The fuse should be in the fuse box under the
driver's side of the dash. I think it might be labeled "cig" or "lighter"
or something along those lines.
Ray O
