Engine Swap 4Runner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2006, 12:38 PM   #1 (permalink)
ali79shine@gmail.com
Guest
Posts: n/a
View ali79shine@gmail.com's Photo Gallery
Engine Swap 4Runner
OK I know I may sound stupid but here I go!
I am lookinf for information for my husband! Our engine blew in our
4Runner and he's ttrying to figure out if he should rebuild or swap out
for a V6 or V8. Has anyone done this or does anyone have a website to
recommend?
PLEASE HELP
Confused & trying to get help!
Old 10-19-2006, 12:56 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Engine Swap 4Runner
<ali79shine@gmail.com> wrote in message
news:1161279485.021689.6780@h48g2000cwc.googlegroups.com...[color=blue]
> recommend?
> PLEASE HELP
>[/color]
It would be useful if you also posted the model year, engine type, and where
you are located - U.S., Europe, etc.
Installing a different type of engine from the one that originally came with
the vehicle involves a lot of modifications.
For example, if your generation 4Runner was not offered with a V8, then you
will have to modify the engine mounts and cooling system and change the
engine control computer and transmission. If you change the transmission,
you will probably also have to change the transfer case if it is a 4 wheel
drive. This can easily spend $10,000 on modifications on top of the price
of a new engine.
Even if 4Runners were offered with both 4 and 6 cylinder engines, you will
probably still need to change the computer and transmission, so plan on
spending at least $5,000 on top of the price of a new engine.
If your engine is rebuild-able, then rebuilding it is the least costly
option.
Ray O
Old 10-19-2006, 01:05 PM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
> recommend?
> PLEASE HELP
> Confused & trying to get help![/color]
What are your goals, your budget, your (his) skill level?
The least expensive and easiest is to directly replace what's in there
already with a certified used engine. The next alternative is to get a
"long block" which are usually sold on an exchange basis. If you use your
truck as a daily driver, both are "weekend" projects and will get you back
on the road soonest.
Rebuilding your blown engine might or might not be cheaper than the long
block swap, depending on mileage and what parts were damaged when it "blew."
The advantage is that you can make your own decision on marginal parts -
replace them for increased life and reliability or run with them for reduced
costs. You can also make any mods that you may feel are appropriate for
your use - different cam, high volume oil pump, etc.
Swapping requires more knowledge, skill and money. If yours is a 4cyl and
you swap in a V6 from a 4Runner so equipped it may be fairly painless as far
as swaps go, but you may have to upgrade wiring, computer, suspension,
radiator, charging system etc - and maybe even the transmission - to the V6
model. I honestly don't know what it would entail not having done this swap
but it could be anywhere from "drop it in and go" to requiring some fairly
significant modification.
As far as a V8 swap goes, this is most complicated yet. Depending on what
engine you want to put in (Toyota, Chevy, ??) you may need adaptors, upgrade
of the entire drivetrain, suspension, brakes, cooling system, firewall,
frame... and what you end up with, again depending on the skill level of the
one doing the work - will either be a professional, safe and clean looking
installation, or it may be a total hack job. I have to warn that I've seen
far more of the latter than the former, when done by people with little or
no experience, and if your state requires inspections a "hack job" may not
be certified as safe.
Mike Harris
1995 Tacoma 2WD 2.4L
1987 Corolla
1963 Willys Wagon 4WD SBC conversion
Old 10-19-2006, 02:38 PM   #4 (permalink)
Guest
Posts: n/a
[email]ali79shine@gmail.com[/email] wrote:[color=blue]
> recommend?
> PLEASE HELP
OK Here's more info-
94, TOYOTA, 4RUNNER, 5 SPEED TRANY, 3.0L V6 ENGINE
Old 10-19-2006, 02:39 PM   #5 (permalink)
Guest
Posts: n/a
Ray O wrote:[color=blue]
> news:1161279485.021689.6780@h48g2000cwc.googlegroups.com...[color=green]
> > recommend?
> > PLEASE HELP
> >[/color]
> of a new engine.
> option.
> Ray O
> (correct punctuation to reply)[/color]
Old 10-19-2006, 02:45 PM   #6 (permalink)
Guest
Posts: n/a
OK- this helps alot, BUT which is the best route to take! We've got the
money to do it all but what's the best one?? Is he better off to just
rebuild? He's planning on swapping out the tranny too to a 7R4 Tranny!
He's just hung up on "what's the best way"
Mike Harris wrote:[color=blue]
> > recommend?
> > PLEASE HELP
> Mike Harris
> 1987 Corolla
> 1963 Willys Wagon 4WD SBC conversion[/color]
Old 10-19-2006, 02:47 PM   #7 (permalink)
Guest
Posts: n/a
We've got the money, He's got the skill, and we've got time! Thanks for
your info! Anything else you can recommend???? Thanks!!!
> Mike Harris wrote:[color=green]
> > news:1161279485.021689.6780@h48g2000cwc.googlegroups.com...[color=darkred]
> > > recommend?
> > > PLEASE HELP
> > Mike Harris
> > 1987 Corolla
> > 1963 Willys Wagon 4WD SBC conversion[/color][/color]
Old 10-19-2006, 03:16 PM   #8 (permalink)
Mike Harris
Guest
Posts: n/a
Top posted, but she did it first ... sorry folks.
(sigh) That question can't be answered without knowing what your goals are
for the truck.
Are y'all happy with the truck in its stock configuration? If so,
rebuilding the existing engine or replacing it with the identical "crate"
engine is the "best" way.
Do y'all want to turn it into some wort of fire breathing dragstrip eater?
Not *my* first choice of vehicles for this but whatever floats your boat.
Dropping in a blown 454 rat motor, TH400 and Ford 9" rear end is the "best"
way. Get out your checkbook.
How about towing? I'm kind of partial to the Detroit Diesel 6V-92 Turbo
with the Allison HT transmission. With 1100 ft/lbs of torque you could
climb trees with it - that's the "best" way. *Really* get out your
checkbook.
If you don't want to go to these extremes, as Ray O pointed out, swapping a
V8 - even a Toyota V8, might end up costing $10K or more. For that kind of
money, the "best" way would be to rebuild or replace the existing 3.0L
engine, sell the nice, stock 4Runner, and buy yourself a Tundra with the V8
already in it.
Mike Harris
Austin TX
news:1161287109.067167.175380@e3g2000cwe.googlegroups.com...[color=blue]
>> > recommend?
>> > PLEASE HELP
>> your
>> back
>> "blew."
>> reduced
>> and
>> far
>> V6
>> swap
>> fairly
>> what
>> upgrade
>> the
>> looking
>> seen
>> or
>> not
>> Mike Harris
>> 1987 Corolla
>[/color]
Old 10-19-2006, 05:24 PM   #9 (permalink)
Guest
Posts: n/a
> for the truck.
> checkbook.
> already in it.
> Mike Harris
> Austin TX
> news:1161287109.067167.175380@e3g2000cwe.googlegroups.com...[color=green]
> > Mike Harris wrote:[color=darkred]
> >> > recommend?
> >> > PLEASE HELP
> >> your
> >> back
> >> "blew."
> >> reduced
> >> and
> >> far
> >> V6
> >> swap
> >> fairly
> >> what
> >> upgrade
> >> the
> >> looking
> >> seen
> >> or
> >> not
> >> Mike Harris
> >> 1987 Corolla
> >> 1963 Willys Wagon 4WD SBC conversion[/color][/color][/color]
Well Mike- Our goal is to have a vehicle that will go to and from work,
and also on the weekends climb some hills, do a little
crawling.................But still have some power too! As it was... it
was so POWERLESS on the road! My husband has been getting into this
whole 4x4ing thing, and it has to have the power to make it uphill, he
had also been talking about making it into an automatic.[color=blue][color=green]
> >[/color][/color]
Old 10-19-2006, 05:32 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:1161296664.419986.124720@e3g2000cwe.googlegroups.com...[color=blue]
>[/color]
<snipped>[color=blue]
> had also been talking about making it into an automatic.[color=green][color=darkred]
>> >[/color][/color]
>[/color]
If you want to go crawling, think about the FJ Cruiser, new 4Runner with V8,
or Land Cruiser. For what it would cost to change the V6 to a V8 and
change the transmission to an automatic, you could probably fix or replace
your current engine, sell the vehicle, and then get a brand new vehicle and
then you will have everything fresh from the factory instead of something
that will be difficult to repair or sell later.
Ray O
Old 10-19-2006, 11:38 PM   #11 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Thu, 19 Oct 2006 12:56:19 -0500, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
>news:1161279485.021689.6780@h48g2000cwc.googlegroups.com[/color]
>> I am looking for information for my husband! Our engine blew in our
>> recommend?[/color]
>the vehicle involves a lot of modifications.[/color]
The OP is using Google Groups, so their being in the USA is a fairly
safe assumption...
The way the US laws are written, it is very difficult to swap a
different size or year engine and still pass the biennial emissions
checks if you live in the areas where they are required. The
California laws are fraught with a whole system of special referee
inspections, CARB Exemption inspections for aftermarket exhaust
manifolds and cat converters, one-year exemptions...
It is possible to go through a series of special inspections and
hearings, and be told to either (Pick One:) put the car back the way
it was built, make impossible modifications to bring an older engine
up to the newer emissions regulations that go with the vehicle, scrap
the car, or sell it out of the area.
They enforce the laws by denying you the tags.
[color=blue]
>of a new engine.
>option.[/color]
If your engine is NOT rebuildable - for instance it threw a
connecting rod through the side of the engine block - the next best
thing is to get a matching year and model good used engine from a
junkyard, and have that used engine rebuilt and installed. Or pay the
engine rebuilders the "core charge", they will go find another good
block to use for the next person.
If you or your mechanic rebuilds the same model year and type
engine, and restores the car to factory specs as originally built, the
State can't make trouble for you. As long as the emissions systems
are complete and function properly, and the tailpipe tests come up as
clean as they require or better.
The "Low mileage Used Japanese Engines" they sell can be trouble -
they may be the same basic engine model, but there are slight
differences between the Japanese-market cars and the American-market
cars - often they do not "just drop right in and work" as advertised,
your mechanic will end up modifying things to fit.
Installing any used engine in your car is a crapshoot - you never
really know HOW used it was until you get it bolted in and running.
And if the replacement engine turns out to need a rebuild, then you
have to take it out of the car again to do the work.
Better to have it opened up and gone through before installing it
the first time, then you should get 100K plus miles without a hitch.
Oh, and don't just decide to sell it As Is unrepaired - I can almost
guarantee that you'll take a financial bath. Better to put in a good
engine and repair the car, drive it a few years, and then sell it
while it is still in good running condition, that's when you'll get
top dollar for the car.
--<< Bruce >>--
Old 10-19-2006, 11:46 PM   #12 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On 19 Oct 2006 12:38:47 -0700, "ali79shine@gmail.com"
<ali79shine@gmail.com> wrote:
[color=blue]
>94, TOYOTA, 4RUNNER, 5 SPEED TRANY, 3.0L V6 ENGINE[/color]
WHERE Are You Located? If you are in the Greater Los Angeles or
Bay Area of California, or certain areas in New York or New Jersey,
there are rather draconian Smog Laws to navigate through.
Make big changes to the car that don't fit inside those laws, like
dropping a V-8 in where a 4-cylinder used to live, and they take away
the license plates at the next smog-check inspection.
--<< Bruce >>--
Old 10-20-2006, 07:27 AM   #13 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Fri, 20 Oct 2006 04:46:49 GMT, Bruce L. Bergman
<blPYTHONbergman@earthlink.invalid> wrote:
[color=blue]
>[color=green]
> --<< Bruce >>--[/color]
Another reason to live in Florida....
Scott in Florida
Old 10-20-2006, 09:49 AM   #14 (permalink)
Mike Harris
Guest
Posts: n/a
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:9b668$4537fd14$44a4a10d$20486@msgid.meganewsservers.com...[color=blue]
> news:1161296664.419986.124720@e3g2000cwe.googlegroups.com...[color=green]
>>[/color]
> <snipped>[color=green]
>> had also been talking about making it into an automatic.[color=darkred]
>>> >[/color]
>>[/color]
> V8, or Land Cruiser. For what it would cost to change the V6 to a V8 and
> and then you will have everything fresh from the factory instead of
> something that will be difficult to repair or sell later.
> Ray O
I agree.
Mike Harris
Austin TX
Old 10-20-2006, 10:22 AM   #15 (permalink)
Guest
Posts: n/a
Oh no we're good we live in Eastern Washington state
Bruce L. Bergman wrote:[color=blue]
>[color=green]
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
engine swap ? toywanabe 89-95 Toyota Pickup/Hilux 36 09-08-2009 05:42 PM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Engine Swap fendercontender Hardcore Tech and Competition 7 11-21-2004 10:30 AM
4Runner engine swap Cisco General Discussion 4 06-23-2002 07:55 PM
