Landcruiser Glow plug timer 60 series??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-20-2006, 09:41 PM   #1 (permalink)
Lee
Guest
Posts: n/a
View Lee's Photo Gallery
Wondering where the glow plug preheat timer is situated in a 60 series 1985
model landcruiser???
any help would be great
thanks
Old 10-20-2006, 10:52 PM   #2 (permalink)
Lee
Guest
Posts: n/a
Re: Landcruiser Glow plug timer 60 series???
I found it in the passenger kickplate
Does anybody have the testing procedure from the workshop manual for the
timer unit?
It has 13 pins out.
Id love a copy
thanks
"Lee" <lee@allway.net.au> wrote in message news:1161400604.318829@teuthos...[color=blue]
> 1985 model landcruiser???
> thanks
>[/color]
Old 10-21-2006, 12:47 AM   #3 (permalink)
Toby Ponsenby
Guest
Posts: n/a
View Toby Ponsenby's Photo Gallery
On Sat, 21 Oct 2006 12:11:20 +0930, Lee blathered on:
[color=blue]
> thanks[/color]
The relay you're looking for is behind the passenger LHS kick panel.
BTW, it probably isn't malfunctioning:-)
Old 10-21-2006, 02:56 AM   #4 (permalink)
John_H
Guest
Posts: n/a
View John_H's Photo Gallery
Lee wrote:
[color=blue]
>timer unit?
>It has 13 pins out.[/color]
The glow plug control circuit is in the engine manual, presumably
yours is the 2H? In any case there won't be any specific test
procedure for the timer in isolation.
The fact you've got 13 pins suggests that what you've probably found
is the timer plus the relay. It's also likely to be a simple matter
of deciding where the problem is from the fault symptoms... which you
haven't indicated.
John H
Old 10-21-2006, 09:56 AM   #5 (permalink)
the_dawggie
Guest
Posts: n/a
View the_dawggie's Photo Gallery
Lee wrote:[color=blue]
> thanks[/color]
I can only help with 'lux stuff, which I have all the docs on. Just
about to go to bed - can look too see if similar. Check your glow
plugs - prolly burnt out.
Old 10-23-2006, 01:44 AM   #6 (permalink)
the_dawggie
Guest
Posts: n/a
the_dawggie wrote:[color=blue]
> Lee wrote:[color=green]
> > thanks[/color]
> plugs - prolly burnt out.[/color]
'lux has a 9 pin connector with 6 pins used ... indicator lamp,
relay feed, ignition, speed sensor (?), ground, charge fuse.
Euro versions seem to use around 10 pins from the docs, so
that might be using a different connector, and be what you are
after.
I've got some L/C factory manual I'll check too when I get home.
Other than that web, search might turn up stuff.
Old 10-23-2006, 02:41 AM   #7 (permalink)
John_H
Guest
Posts: n/a
>speed sensor (?)[/color]
Coolant temperature sensor more likely -- the usual culprit when the
timer doesn't time correctly.
John H
Old 10-23-2006, 04:57 AM   #8 (permalink)
the_dawggie
Guest
Posts: n/a
John_H wrote:
[color=blue]
> haven't indicated.[/color]
Found what I've got at home, the manuel ToyCo PN 36044E,
which shows BJ60 and HJ60.
Weird however, as the timer only has four wires as far as I can see...
(sorry
for the picture qual, however I've got a crap cam and no scanner) ....
[url]http://img99.imageshack.us/my.php?image=im000125ww6.jpg[/url]
It does not appear that the timer does anything but control the lamp,
the
starter switch does has a position for plugs?
Old 11-28-2006, 07:21 PM   #9 (permalink)
vw_rum@hotmail.com
Guest
Posts: n/a
View vw_rum@hotmail.com's Photo Gallery
Lee,
Are you visually using the glow plug light as an indicator to "start",
or are waiting for the relay to cut out before starting. The light and
the relay appear to be independent, and often the light goes out too
quick.
Do you have the later HJ60 with the extra preheat glow plugs in the
manifold?
regards
Grahame
> Basically my problem is I have to turn the ignition key on and off 6 times
> and then it will start which seems to indicate the circuit is not glowing
> for long enough.
> I have checked the glow plugs already.
> Ive lived with this problem for 4 yrs
> regards Lee
> "Lee" <lee@allway.net.au> wrote in message news:1161400604.318829@teuthos...[color=green]
> > thanks
> >[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
OEM VIP RS Series Security System '05 Toyota Tacoma: Is it plug and play ? lotust 2nd Generation (2005+) 7 10-05-2005 12:25 AM
60 Series Flowmaster for Camry Theo Camry & Solara Lounge 6 05-12-2004 06:45 PM
