TTY? Are these on all Toyotas? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2006, 12:39 AM   #1 (permalink)
Hammo
Guest
Posts: n/a
View Hammo's Photo Gallery
Greetings again Brains Trust!
I was wondering about the prevalence of the Torque to Yield Bolts (TTY)
(specifically head bolts) on Toyotas.
Firstly, when did they become common parts, was this during the move to
alloy heads?
secondly, how can you tell what they look like? Are they stamped TTY, or
should it just be assumed they are "them"?
Cheers
Hammo
Old 10-23-2006, 12:04 PM   #2 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Re: TTY? Are these on all Toyotas?
Ray O, 10/23/2006, 12:48:06 PM,
<4fc69$453cf55e$44a4a10d$4127@msgid.meganewsservers.com> wrote:
[color=blue]
> "Hammo" <hbaj2006@aapt.net.au> wrote in message
> news:C16292A9.31A1%hbaj2006@aapt.net.au...[color=green]
> > (TTY) (specifically head bolts) on Toyotas.
> > move to alloy heads?
> >[/color]
> I believe that Toyota refers to torque to yield bolts as plastic
> region bolts. I do not remember exactly when they became common, but
> my guess is around 20 years ago.
>[color=green]
> > TTY, or should it just be assumed they are "them"?
> > Cheers
> > Hammo
> >[/color]
> AFAIK, those bolts do not look any different. Toyota repair manuals
> have a section where they explain bolt torque based on marks/patterns
> on the head. In the section on head removal and installation, they
> will specify that the old head bolts be discarded and new ones used
> in the case of plastic region bolts.
> If in doubt, I would assume that they are them ;-)[/color]
I know about graded bolts but not these. What are TTY bolts? Are they
a bolt that has a spring action in it that only tightens down to a
certain torque rating?
Old 10-23-2006, 01:52 PM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:4fc69$453cf55e$44a4a10d$4127@msgid.meganewsservers.com...[color=blue]
>> alloy heads?
>>[/color]
> I believe that Toyota refers to torque to yield bolts as plastic region
> bolts. I do not remember exactly when they became common, but my guess is
>[color=green]
>> Cheers
>> Hammo
>>[/color]
> AFAIK, those bolts do not look any different. Toyota repair manuals have
> a section where they explain bolt torque based on marks/patterns on the
> head. In the section on head removal and installation, they will specify
> that the old head bolts be discarded and new ones used in the case of
> Ray O
> (correct punctuation to reply)
>[/color]
TTY bolts offer 2 to 3 times the clamping force as conventional bolts, and
do so much more uniformly than conventional bolts because its the
deformation of the bolt material, not the torque, which determines final
clamping force.They're used with alloy heads and required with some advanced
head gaskets.
I don't think they're labeled specifically but they look longer and thinner
than "conventional" bolts. If your manual specifies a "torque plus degree"
for final tightening of head bolts, chances are good that you've got TTY
bolts. For example, "torque to 120 ft lbs then turn an additional 90
degrees."
In any case, head bolts are fairly cheap. Even if you have "conventional"
head bolts you're more likely to get more accurate and even torque values
using new ones instead of old.
Mike Harris
Austin TX
Old 10-24-2006, 06:52 AM   #4 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
Mike Harris wrote:
[color=blue]
> TTY bolts offer 2 to 3 times the clamping force as conventional bolts, and[/color]
How would they do that without more torque or a different thread
pattern?
A TTY bolt it torqued to the point where it passes the elastic
(recoverable) stretch point and heads into the plastic region. Once
this has happened the tension in the bolt barely increases at all
despite the stretching. This is handy during assembly due to the fact
that anything from poor lubrication to a notch in the thread can cause
the correct torque reading but incorrect clamping force on a normal
non-stretch bolt (torque used to overcome friction instead of clamping
the head down). By specifying that the bolt should be taken into the
plastic region by a certain amount you know that the minimum clamping
load has been applied to get it past elastic deformation but it cant
really over-clamp because its now deforming plastically which is a
more-or-less constant tension plateau until just before ultimate
failure of the bolt.
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota's Simple Slim cuts Camry costs EKam Toyota News 9 03-01-2006 05:55 PM
Toyota's 16th Annual Opportunity Exchange lexusis350 Toyota News 0 11-01-2005 03:17 PM
New Rochelle Toyota Buying Back Used Toyotas??? 99camryLE Toyota Dealers 6 10-18-2005 07:50 PM
Toyotas in your lifetime? xpeed Off Topic 16 12-03-2004 09:23 PM
Toyota's global strategy looks inward rolla-XRS Toyota News 7 11-29-2004 03:55 PM
