The brochure says 20 gal (US gal I assume since who else uses gal for
anything)
The Owner's Manual on page 498 says 21 US gal and 17.5 Imperial gal/
Canada - once upon a time.
Twice I have had an exact fuel gauge reading of 13.5 US gal to fill
from a 1/4 tank reading. This of course implies a 4/3 x 13.5 -> 18.0
gal fuel tank!
Is this a matter of inflation or what?
My mileage is consistent 26 mil/gal at 70 mph on HWY.
but only about 14.3 mil/gal city and very short 1-4 mile trips to
stores etc. but no idling in traffic congestion.
"MO full name" <nospam@hole.org> wrote in message
news:u3eqj21537mne3dn2nqm3jdrruc3r437u1@4ax.com...[color=blue]
> What is Actual fuel tank capacity of 06 Sienna?
> anything)
>[/color]
There are Imperial gallons, used by Imperialists? ;-)
If the brochure is from Toyota Motor Sales, U.S.A., then it is probably safe
to assume that they mean U.S. gallons and it is also probably safe to assume
that in the event of a difference between the owner's manual and the
brochure, the owner's manual is more likely to be correct because the folks
who produce the brochures are not technical people.
[color=blue]
> gal fuel tank!
> Is this a matter of inflation or what?[/color]
The fuel gauge is not an accurate indicator of measurement of fuel in the
tank, and movement of the fuel gauge is not linear. The fuel sender is
basically a float on an arm, much like the float that controls water
entering your toilet tank, and the float moves in an arc. The fuel tank is
generally not symmetrical and has an odd shape, so although the float will
indicate the level in the tank, it does not necessarily indicate volume of
fuel in the tank.
[color=blue]
> stores etc. but no idling in traffic congestion.[/color]
I'm not sure if you have a question or not, but if you are questioning why
there is such a large discrepancy between city and highway mileage, it is
because an engine is least fuel-efficient and puts out the highest emissions
during the first few miles after a cold start. When the engine is first
started cold, additional fuel is needed to keep it running smoothly, so idle
speed is higher. When the engine is first started, the O2 sensors have not
warmed up enough to work, so the computer uses a "default" value to
determine how much fuel to deliver, rather than how much is actually needed.
Also, when the engine is first started, the transmission holds lower gears a
little longer and does not shift into overdrive until the engine has begun
to warm up. Holding the transmission in lower gears helps the engine warm
up faster so emissions are reduced, at the cost of fuel economy.
If you want to improve your city mileage, save up all your short trips and
combine them into longer trips if possible. For example, after the engine
has warmed up, you can probably travel 5 miles in the amount of fuel
consumed during the first 2 miles of travel after a cold start.
Your decent highway fuel economy indicates that everything seems to be
running efficiently.
On Mon, 23 Oct 2006 23:03:11 GMT, MO full name <nospam@hole.org> wrote:[color=blue]
> The actual amount of fuel that can be sucked out of the tank (and
> used) does make a difference on the Left Side with our great distances
> between many pumps or towns - say late at night. I know one should
> not run far below 1/4 tank.[/color]
I've been way below 1/4 tank...
Do you happen to have the trip computer with its "Estimated Distance to
Empty" ? My wife's 2005 sienna does, and it seems to be pretty accurate
as long as the type of driving is similar. (In other words, driving 300
miles highway and then doing a bunch of errands in town will fool the
computer and could get you into trouble.)
My wife is the main driver of the sienna so she knows best on range and
fuel capacity, but we frequently take 350+ mile highway trips with no
worry about running empty. The tank does seem to be right about the 20
gallon size in our 2004. I know it is more than 19g. :) If I had to
guess, I'd have guessed 20 or 21 gallons.
I don't know if T changed the tank since 2004, or if T uses different
tanks with different packages. Mine is a pretty basic 8 seater.
sdb
Wanted: Omnibook 800 & accessories, cheap, working or not
sdbuse1 on mailhost bigfoot.com
I put in 19.7 US gallons at one fill. Or course I had my fingers
crossed when I pulled up to the pump!
Dan
MO full name wrote:[color=blue]
> anything)[/color]
Your mistake is that you assume 1/4 tank on the guage is an accurate
reading. THE ONLY JOB of the fuel guage is to let you know how long you have
before you have to lace up your sneakers and start walking. The guage is
RELATIVE information, not acutal.
If you get 20 mpg, and can carry 40 gallons, then you have a 400 mile range.
That is the only really important thing you need to know. This tidbit can be
helpful if you've gone 326 miles, and the sign reads NEXT SERVICE 75 MILES.
Personally, I stop and buy a few gallons.
> anything)
> gal fuel tank!
news:mmhqj2ts4nf6ka0jc94h2jbkfg6gsmbt9o@4ax.com...[color=blue]
> On Mon, 23 Oct 2006 17:29:18 -0500, "Ray O"
> <rokigawaATtristarassociatesDOTcom> wrote:
>[color=green]
>>news:u3eqj21537mne3dn2nqm3jdrruc3r437u1@4ax.com...[color=darkred]
>>> anything)
>>>[/color]
>>safe
>>assume
>>folks
>>[color=darkred]
>>> gal fuel tank!
>>is
>>fuel in the tank.
>>[color=darkred]
>>emissions
>>idle
>>not
>>needed.
>>a
>>running efficiently.[/color]
> This vehicle has given me more satisfaction than anything I purchased
> in regent memory. Good attention to details and great ride on the
> hwy.
> not run far below 1/4 tank. T seems indifferent to what numbers are
> used by them. Perhaps there was a real simple answer.
> As for city fuel economy - some people are fans of letting the car
> warm up for say 5 min before they get in it and drive anywhere.
> Is this anything other than false economy and superstition?[/color]
Starting a car and letting it warm up for 5 minutes or even 1 minute before
getting in and driving anywhere is a waste of fuel. If you want to improve
fuel economy, get in the car, fasten your seat belt, adjust the mirrors, and
do whatever else your routine includes before starting the engine. When you
start the engine, wait for the engine RPM to stabilize, usually less than 5
seconds, put the transmission in gear, and start driving.
[color=blue]
> I was surprised to see just how great the difference was in mileage
> between short and long trips in a modern car.[/color]
The big difference is due to the many short trips, where the engine barely
warms up and the transmission does not shift into overdrive. The
transmission is probably geared for good acceleration around town and lower
RPM on the highway. 2 things that will make a significant improvement in
fuel economy are combining the short trips so that the engine is warmed up
for more of the driving, and allowing the transmission to upshift by
accelerating a little more slowly and lifting your foot off the throttle
just before you get to your cruising speed. The transmission will shift to
a higher gear a little sooner, and doing that routinely will make a
difference. My Lexus has a 4 liter V8, my commute is 10 miles of suburban
driving, and I get 19 ~ 20 MPG around town, about 25 MPG on the highway. I
check MPG on every tank so I know if there is a dropoff in performance and I
need to check things out. If we trade cars and my wife or one of my kids
drive it for just 1 day, the fuel economy on that tank will drop to 17 ~ 18
MPG. My advice is to be cognizant of what gear the transmission is in and
let it shift to high gear as soon as you can.
On Mon, 23 Oct 2006 18:06:04 -0700, Jeff Strickland <crwlr@yahoo.com> wrote:[color=blue]
> If you get 20 mpg, and can carry 40 gallons, then you have a 400 mile range.[/color]
Uhhh... :)
sdb
Re: ! 19 Re: Actual fuel tank capacity of 06 Sienna
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:dfedd$453e3c86$44a4a10d$20803@msgid.meganewsservers.com...[color=blue]
> "MO full name" <nospam@hole.org> wrote in message news:mmhqj2ts4nf6ka0jc94h2jbkfg6gsmbt9o@4ax.com...[color=green]
>>[color=darkred]
>>>> anything)
>>>> gal fuel tank!
>>>fuel in the tank.
>> hwy.
> Starting a car and letting it warm up for 5 minutes or even 1 minute before getting in and driving anywhere is a waste of fuel.
> If you want to improve fuel economy, get in the car, fasten your seat belt, adjust the mirrors, and do whatever else your routine
> includes before starting the engine. When you start the engine, wait for the engine RPM to stabilize, usually less than 5
>[color=green]
> The big difference is due to the many short trips, where the engine barely warms up and the transmission does not shift into
> overdrive. The transmission is probably geared for good acceleration around town and lower RPM on the highway. 2 things that
> will make a significant improvement in fuel economy are combining the short trips so that the engine is warmed up for more of the
> driving, and allowing the transmission to upshift by accelerating a little more slowly and lifting your foot off the throttle just
> before you get to your cruising speed. The transmission will shift to a higher gear a little sooner, and doing that routinely
> will make a difference. My Lexus has a 4 liter V8, my commute is 10 miles of suburban driving, and I get 19 ~ 20 MPG around town,
> about 25 MPG on the highway. I check MPG on every tank so I know if there is a dropoff in performance and I need to check things
> out. If we trade cars and my wife or one of my kids drive it for just 1 day, the fuel economy on that tank will drop to 17 ~ 18
> MPG. My advice is to be cognizant of what gear the transmission is in and let it shift to high gear as soon as you can.
> Ray O
> (correct punctuation to reply)
>[/color]
Off topic but... Wonder what kind of MPG the Lexus would get peddle to the metal (WFO) everywhere?
"Danny G." <dandog@pacbell.net> wrote in message
news:EDL0h.24453$7I1.13771@newssvr27.news.prodigy.net...[color=blue]
>[/color]
<snipped>
[color=blue][color=green]
>> barely warms up and the transmission does not shift into overdrive. The
>> lower RPM on the highway. 2 things that will make a significant
>> engine is warmed up for more of the driving, and allowing the
>> your foot off the throttle just before you get to your cruising speed.
>> that routinely will make a difference. My Lexus has a 4 liter V8, my
>> town, about 25 MPG on the highway. I check MPG on every tank so I know
>> if there is a dropoff in performance and I need to check things out. If
>> fuel economy on that tank will drop to 17 ~ 18 MPG. My advice is to be
>> Ray O
>>[/color]
> 8)
>[/color]
If you floored the pedal at every start, my guess is 12 to 15 MPG.
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:2c83f$4543b80d$47c2b532$4644@msgid.meganewsservers.com...[color=blue]
> "Danny G." <dandog@pacbell.net> wrote in message news:EDL0h.24453$7I1.13771@newssvr27.news.prodigy.net...[color=green]
>>[/color]
> <snipped>
>[color=green][color=darkred]
>>> the driving, and allowing the transmission to upshift by accelerating a little more slowly and lifting your foot off the
>>> throttle just before you get to your cruising speed. The transmission will shift to a higher gear a little sooner, and doing
>>> that routinely will make a difference. My Lexus has a 4 liter V8, my commute is 10 miles of suburban driving, and I get 19 ~ 20
>>> MPG around town, about 25 MPG on the highway. I check MPG on every tank so I know if there is a dropoff in performance and I
>>> need to check things out. If we trade cars and my wife or one of my kids drive it for just 1 day, the fuel economy on that tank
>>> will drop to 17 ~ 18 MPG. My advice is to be cognizant of what gear the transmission is in and let it shift to high gear as
>>> soon as you can.
>>> Ray O
>>>[/color]
>> 8)
>>[/color]
> Ray O
>[/color]
