Re: Camry vibrates, when breaks applied.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-23-2006, 07:05 PM   #1 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
<kavita.kale@gmail.com> wrote in message
news:1161643448.366984.101390@b28g2000cwb.googlegroups.com...[color=blue]
> Hi All,
> I have a 1998 Toyota Camry. Few days back I had a problem with it..
> When I applied breaks at lights (Gradual Brakes ... no sudden stop)..
> It started hobbling.. ie Vibrating. It started in that "vibrating"[/color]
You need a brake job.
Your description is that of worn rotors. More accurately, warped rotors.
Thias happens in part as a result of very little brake pad material
remaining on the brake pads. (The brake material disipates heat as well as
provide friction.)
Sometimes, the rotors can be turned (machined) to make them true again, but
some automakers make them too thin for this in an effort to save weight. In
any case, if they can be turned (machined on a lathe) the machine operator
MUST measure them first to see if they are going to be thick enough at the
end of the process to warrant startign the process.
Brake rotors vary wildly in price, but my guess is that you should be able
to find them for somewhere in the $50 to $100 price range.
Good luck. And, they're brakes, not breaks.
[color=blue]
> mode. I felt like it will not make till my home. On my way home,
> whenever I applied brakes, it did same thing.. Somehow I brought it
> home (by not applying breaks all way) and next day morning took to
> mechanic.. He examined it.. and car ran just fine.. No traces of last
> days vibrating and stuff.. Mechanic couldn't figure out anything....
> This was almost 2 months back.. And today again it did the same
> thing... ie started vibrating when I applied brakes...
> Any guesses what could be wrong? and why is it so random and not
> consistent?
> Any advice is highly appreciated since I hardly know anything about
> cars.
> Thanks.
>[/color]
Old 10-23-2006, 08:24 PM   #2 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Easy to warp rotors by tighting rims with a service station rattle air
gun --- vice diagonally and finally with a torque wrench.
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:HridnedKlqR4xaDYnZ2dnUVZ_u-dnZ2d@ez2.net...[color=blue]
> news:1161643448.366984.101390@b28g2000cwb.googlegroups.com...[color=green]
>> Hi All,
> provide friction.)
> but some automakers make them too thin for this in an effort to save
> weight. In any case, if they can be turned (machined on a lathe) the
> machine operator MUST measure them first to see if they are going to be
> thick enough at the end of the process to warrant startign the process.
>[color=green]
>> consistent?
>> cars.
>> Thanks.
>>[/color]
>[/color]
Old 10-25-2006, 09:31 PM   #3 (permalink)
Heaving Weasel
Guest
Posts: n/a
View Heaving Weasel's Photo Gallery
In article <HridnedKlqR4xaDYnZ2dnUVZ_u-dnZ2d@ez2.net>,
"Jeff Strickland" <crwlr@yahoo.com> wrote:
[color=blue]
> > Hi All,
> provide friction.)
>[/color]
I would be surprised if warped rotors would come and go--once they are
warped, my experience is that they vibrate EVERY time you apply the
breaks.
Old 10-25-2006, 11:00 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Heaving Weasel" <heavingweasel@yahoo.com> wrote in message
news:heavingweasel-CF3910.22312325102006@news.iglou.com...[color=blue]
>[color=green]
>> news:1161643448.366984.101390@b28g2000cwb.googlegroups.com...[color=darkred]
>> > Hi All,
>> as
>> provide friction.)
>> but
>> In
>> operator
>> the
>> able
>>[/color]
> breaks.[/color]
If the rotors or drums are warped, then the pulsation should be repeatable,
that is, under the same load, same speed, same amount of brakes applied. If
the rotors are glazed, then the vibration can come and go. In my
experience, rotors become glazed or warped most often when the driver
gradually applies the brakes over long distances or uses the left foot to
apply the brakes. In any event, have the brakes checked for warpage or
glazing.
Ray O
Old 10-26-2006, 12:08 PM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Wed, 25 Oct 2006 22:31:23 -0400, Heaving Weasel wrote:
[color=blue]
>[color=green]
>> > Hi All,
>> provide friction.)
>>[/color]
> breaks.[/color]
I had this happen to a set of Chinese rotors I put on my old Celica.
The pedal was pulsing badly when I bought the car, so I did new rotors and
pads all the way around, and it went away.
A few months later, the pulsating was back. I said screw it, I'll live
with it. A couple weeks later it stopped again, never to return!
Now, there is another thing that can be happening here, and that is old
calipers. The slide might be sticking and freeing itself. The sensation
when a slide sticks can be pulsating brakes, or imitate the effects of a
broken bead.
When I did the fronts on my Mom's car a coulpe weeks ago, the calipers
looked real good (the car is 20 years old, with 84,000 miles). They didn't
look new obviously, but they did look good. I checked the sliders and they
were stuck; light pressure freed them. So I put some Sil-Glide on them and
reinstalled everything.
I think I caught them just before they were going to start locking up...
BB code is Off
Smilies are Off
[IMG] code is Off
FS: Misc Gen 4 Camry parts (engine/interior/exterior) got_trd Car Parts for Sale 41 08-01-2007 03:10 PM
What are you really missing with your Camry!!! smt_007 Camry & Solara Lounge 10 02-28-2006 11:01 PM
GEn 4 camry solars glow guages ona gen 4 reg camry mystickid 3rd & 4th Generation (1992–1996 & 1997–2001) 15 05-18-2005 05:06 PM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
