1992 Corolla Wagon AWD - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2006, 02:24 AM   #1 (permalink)
deliperrot@yahoo.com
Guest
Posts: n/a
View deliperrot@yahoo.com's Photo Gallery
Hi:
This is the second posting. I now know how to explain problem.
When my car travels below 100Km/hr it wont stall. If I travel for
10minutes over 100Km/hr it will stall coming off an exit. It will
stall like this regardless if the OD is in or out, in neutral or drive
or while coasting and braking. When I try to start it while giving a
little gas it will start then want to stall. If I start it with not
gas and just let turn over and over and over it will catch and start
running normally again. AS the car is near mint I want to fix this
issue. I've heard of the lock up torque converter solenoid, the
converter itself maybe the fuel line circuit (electrical or mech??)
Please email me ASAP winter is here and I want this to be fixed. In
fact I want to drop it off friday if I can em some clue on where to
look.
thanks
d
Old 10-26-2006, 12:50 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1992 Corolla Wagon AWD
<deliperrot@yahoo.com> wrote in message
news:1161847446.536712.66940@e3g2000cwe.googlegroups.com...[color=blue]
> Hi:
> look.
> thanks
> d
>[/color]
No e-mail, just ng post...
The torque converter lockup is not the fuel line circuit.
Check to see if the exhaust gas recirculation (EGR) valve is sticking in the
applied position. If you do not know how to do that, then unplug the vacuum
line from the EGR valve and plug the vacuum line with a large golf tee or
screw. If the problem clears up, then check the EGR to see if it is
sticking or if the vacuum control for the EGR has a problem.
Ray O
Old 10-26-2006, 05:06 PM   #3 (permalink)
Guest
Posts: n/a
Hi:
I meant that it could be either of those 3 things. Where is the EGR
valve located on this particular car?
Can I test drive with that valve not hooked up?
thanks
Ray O wrote:[color=blue]
> news:1161847446.536712.66940@e3g2000cwe.googlegroups.com...[color=green]
> > Hi:
> > look.
> > thanks
> > d
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
Old 10-26-2006, 11:46 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1161900367.515008.316100@b28g2000cwb.googlegroups.com...[color=blue]
> Hi:
> thanks
>[/color]
I doubt if the torque converter lockup circuit or the fuel pump circuit is
causing the car to die.
I don't know for sure where the EGR valve is located on your particular car,
but in general they are located near the exhaust manifold or intake manifold
manifold with a metal tube running to the exhaust manifold, a silver or
rusty silver in color, about the shape of a hockey puck, but smaller in
diameter.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
Would any parts off an 88 Celica GT fit my 88 Corolla wagon? Infinitrium Archived Corolla threads 2 10-27-2006 07:44 AM
94 corolla wagon speakers oldwagon Archived Corolla threads 9 08-31-2005 01:55 PM
