Transmission Flush for a 1998 Sienna ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2006, 02:47 PM   #1 (permalink)
Pierre Nys
Guest
Posts: n/a
View Pierre Nys's Photo Gallery
I have a 98 Sienna XLE with 150K miles on it. How often should I flush
transmission? I last did it at 104K. Also any info on high mileage
maintenace activities for these cars?
Tks in advance,
pln
Old 10-27-2006, 02:55 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Transmission Flush for a 1998 Sienna ?
"Pierre Nys" <pierrenys@hotmail.com> wrote in message
news:Gnt0h.24498$GR2.14329@tornado.texas.rr.com...[color=blue]
> Tks in advance,
> pln[/color]
If you have been getting the transmission flushed at 36 to 48k intervals,
then you should continue at those intervals. OTOH, if the fluid has only
been changed or has not been changed for a long time, then a fluid change is
a safer bet.
Ray O
Old 10-27-2006, 03:07 PM   #3 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
> Tks in advance,
> pln[/color]
Check your owners manual. IIRC Toyota recommends 2 years / 60K miles for
gearbox fluids and coolant but that's just off the top of my head. Brake
fluid is a good thing to change at about the same interval although I don't
think the manual calls for this.
As someone who drives nothing but high mileage vehicles, I can say that more
frequent inspection is probably the most important for continued safe and
reliable operation. Get into the habit of checking oil and other fluids
every day before you drive it. About once a month or so go over the whole
van to inspect suspension components, rubber/plastic components including
brake lines, and anything else that might leak or break - CV joint boots,
shaft seals, bearings, etc., as well as look for things such as burnt out
bulbs, loose wires, corroded battery terminals, rust spots on the chassis
and so on.
Thirty seconds a day and an hour or so a month is well spent if it prevents
a breakdown.
Mike Harris
Austin TX
BB code is Off
Smilies are Off
[IMG] code is Off
DIY flush transmission fluid popeye08 Camry & Solara Lounge 6 07-02-2010 11:10 AM
Is transmission flush recommended for certification ? abose1t Camry & Solara Lounge 6 10-14-2006 11:44 AM
2007 Sienna Upgrades Thundercat Toyota News 7 09-27-2006 11:12 AM
transmission flush andyjl Camry & Solara Lounge 20 07-21-2005 11:13 AM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
