2000 Sienna Whirring Sound - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2006, 12:24 PM   #1 (permalink)
Lorakai
Guest
Posts: n/a
View Lorakai's Photo Gallery
I have this new problem with a 2000 Sienna I purchased as a pre owned
with warranty on Oct 13.
Just last week I noticed a Whirring sound right after I start the car,
and also even if I don't crank the engine. I can hear the sound even
when I just put the key on the on position. I took it down to Toyota as
soon as I started hearing the sound. He said the sound was normal, and
that it was just my starter winding down. I questioned it, but they
said they couldn't fix what wasn't broken. At that time we did not
experiment with turning the key in just the on position to hear it.
Does anyone know what this sound could be related to, and if in fact it
is normal?
The sound was not there for the first two weeks when we purchased the
car, it only suddenly appeared about a week ago. The whirring sound can
be felt in the steering wheel, and on the pedals if I lightly rest my
foot on them but don't actually depress them. The sound is coming from
the left side of the engine I believe.
Also,... if it is the starter winding down, why do I hear it when I
only put the key in the on position?
Thanks,
Juliet
Old 10-28-2006, 12:27 PM   #2 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Re: 2000 Sienna Whirring Sound
Lorakai, 10/28/2006,1:24:06 PM, wrote:
[color=blue]
> as soon as I started hearing the sound. He said the sound was normal,
> and that it was just my starter winding down. I questioned it, but
> they said they couldn't fix what wasn't broken. At that time we did
> not experiment with turning the key in just the on position to hear
> it.
> it is normal?
> can be felt in the steering wheel, and on the pedals if I lightly
> rest my foot on them but don't actually depress them. The sound is
> coming from the left side of the engine I believe.
> Thanks,
> Juliet[/color]
My 2000 Sienna has a sound when I put it in the ON position also. I
wouldn't call it a whirring sound but more like Whoomp sound. It's
almost like a vacuum pump or something activating itself.
Old 10-28-2006, 12:50 PM   #3 (permalink)
Lorakai
Guest
Posts: n/a
>[color=blue]
> almost like a vacuum pump or something activating itself.[/color]
That sounds about right,.. thanks for checking through your own Sienna.
I would say the sound is like a whoooooom.
So if your hearing it, it mightbe normal then,.. what do you think?
J
Old 10-28-2006, 12:54 PM   #4 (permalink)
badgolferman
Guest
Posts: n/a
Lorakai, 10/28/2006,1:50:56 PM, wrote:
[color=blue][color=green]
> Sienna. I would say the sound is like a whoooooom.
> So if your hearing it, it mightbe normal then,.. what do you think?[/color]
It's certainly a strange "normal" -- wouldn't you say?
I've had the van a year and a half and it hasn't had any problems. My
only complaint is its bad gas mileage.
Old 10-28-2006, 02:37 PM   #5 (permalink)
Tim S
Guest
Posts: n/a
View Tim S's Photo Gallery
> Just last week I noticed a Whirring sound right after I start the car,[color=blue]
> is normal?[/color]
ABS does a self-check on key on. you can hear this on some cars, could just
be that you didn't notice it for the first few weeks.
T
Old 10-28-2006, 03:08 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Lorakai" <jmcoggins@comcast.net> wrote in message
news:1162056246.675057.169010@f16g2000cwb.googlegroups.com...[color=blue]
> is normal?
> Thanks,
> Juliet
>[/color]
It is difficult to identify a sound without actually hearing it, but if it
lasts about 3 to 5 seconds, then you may be hearing the antilock brake (ABS)
actuator and pump doing a self-check. When the ignition is turned on, it
powers up and cycles, and during the first 10 feet or so of vehicle
movement, the ABS computer is looking for equal signals from each of the
wheel speed sensors. If one or more of the sensors does not give the same
signal or no signal, then the ABS check light will come on.
If you want to confirm if you are hearing the ABS actuator, set the parking
brake, open the hood, and being very careful to keep away from moving parts
like belts and fans, put your hand on the ABS actuator while someone
switches the ignition to the on position without starting the engine. You
should be able to feel it vibrate a little. ABS actuator location varies
from vehicle to vehicle, in Toyotas, it is usually a silver cube about 6 ~8
inches per side with a bunch of steel tubing sticking out. BTW, if you have
traction control, the ABS actuator also controls that function as well.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Odd Whirring Sound 94 Toyota Pickup SR5 4x4 pickup sr5 89-95 Toyota Pickup/Hilux 2 02-17-2006 06:40 AM
odd sound kadsworld xB Lounge 3 02-05-2006 06:41 PM
Finally got the sound that I was looking for. (Exhaust) trdspeedwayblue 2nd Generation (2005+) 21 07-17-2005 02:05 PM
Loud Sound.. simplysic Archived Corolla threads 10 01-18-2005 12:34 PM
Rattling sound at low rpm (AE92 4A-FE) ssrrww Archived Corolla threads 13 11-23-2004 10:14 AM
