Re: Failed Mot Exhaust Emission. Can anyone exlplain the following result please.
<johnsmile123@hotmail.com> wrote in message
news:1162074456.302162.84390@h48g2000cwc.googlegroups.com...[color=blue]
>I have a Toyota Carina E (petrol, 1995). It failed the MOT's emission
> test.
> The results are listed below and would like your expert opinion as to
> what
> do you think is wrong.
> 200k Miles on the clock, runs perfectly well. Good mpg. The expensive
> lambda sensor is 3 yrs old. Engine type 4A-FE. The cat was hot when
> tested. No engine check light flashing on the dashboard. Slight
> vibration on the wheel at 70 MPH.
> What if i just take the air filter element out for the emission test?
> It worked for my D reg Micra EVERY time. Anyony tried it with these
> morden ECU cars ?
> Thank you in advance.
> Oil temp >= 60 C cooling fan cut in
> Fast idle Test: FAIL
> Engine Speed 2350-2650 Rpm 2400 Rpm Pass
> CO: <= 0.30 % vol 0.97 % vol Fail
> HC: <= 200 ppm vol 160 ppm vol Pass
> Lambda 0.970-1.030 0.983 Pass
> Second Fast Idle Test: FAIL
> Engine speed 2350-2650 Rpm 2470 Pass
> CO: <= 0.30 % vol 0.74 % vol Fail
> HC: <= 200 ppm vol 125 ppm vol Pass
> Lambda 0.970-1.030 0.995 Pass
> Natural Idle Test: PASS
> Engine Speed 650-850 Rpm 770 Rpm Pass
> CO: <= 0.50 % vol 0.48 % vol Pass
> Overal Result: FAILED[/color]
High carbon monoxide (CO) comes from an incorrect air/fuel mixture.
Removing the air filter should not affect the result in a modern fuel
injected engine because the air flow sensor is after the air filter element.
High CO can come from over-advanced ignition timing, leaking fuel injectors,
a bad MAF sensor, PCV, evaporative emissions system problem, or bad oxygen
(lambda) sensor.
Since the car seems to be running well, I would start by checking lambda
sensor voltage and MAF voltage and compare with factory spec.
Ray O
