5W-30 instead of 10W-30? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2006, 10:09 PM   #1 (permalink)
J
Guest
Posts: n/a
View J's Photo Gallery
I was reading an article about how to slightly increase your gas
mileage. One thing that it said was to make sure you use the proper oil
for your engine. The '90 Celica I have is recommended to use 5W-30 oil
but since I have had it, I have always filled it with 10W-30. I
remember having other vehicles in the past where 5W-30 was recommended
but 10W-30 was used.
Should I be using 5W-30 and not 10W-30? If I switched to the "correct"
oil, is it possible that I would notice some slight improvement?
Thanks!
Old 10-28-2006, 10:28 PM   #2 (permalink)
larwe
Guest
Posts: n/a
View larwe's Photo Gallery
Re: 5W-30 instead of 10W-30?
J wrote:
[color=blue]
> but 10W-30 was used.[/color]
If the numbers mean what they say, you should only notice a performance
difference inside the small window while your vehicle is coming to
operating temperature. At nominal crankcase temp, both are a 30wt oil.
I doubt you would notice the difference at the pump.
However, if you're in an area where the temperatures get low in the
winter, you should probably be using the 5w30 anyway.
Old 10-29-2006, 01:08 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"J" <omnineko@yahoo.com> wrote in message
news:1162091356.980815.66240@e3g2000cwe.googlegroups.com...[color=blue]
> Thanks!
>[/color]
You should use the weight and grade of oil that is recommended by the
automaker. It is possible, though not very likely, that you would notice
some slight improvement in fuel economy by using 5W-30 instead of 10W-30.
5W-30 offers better lubrication when first starting the engine than 10W-30,
so bottom line, stick to the automaker's recommendations.
Ray O
Old 10-29-2006, 04:16 PM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
On a 17 year old car with normal mileage - I'd stick with the 10W30 --- even
10w40 in hot summer months if in southern states..
> Thanks!
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
5w 30 in the summer ditchin 2nd Generation (2005+) 17 08-14-2006 09:15 PM
5W or 10W, and other oil questions darksparkz General Discussion 3 04-11-2006 11:51 AM
Main 30 Amp fuse blows as soon as ignition turned on pwilliams5 Camry & Solara Lounge 5 01-09-2006 05:01 PM
Scion VIP @ Hot Import Nights - Boston - April 30, 2005 ScionVIP Scion Events 3 04-11-2005 02:16 PM
Blarg.... nothing to do for 30 days. Piddy Off Topic 19 02-10-2005 11:48 PM
