Carina E transmission oil change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2006, 08:04 AM   #1 (permalink)
Hans O. Reimer Hansen
Guest
Posts: n/a
View Hans O. Reimer Hansen's Photo Gallery
Can somebody provide me with instruction/drawings or (preferred) pictures on
how to change the transmission oil?
Carina E 1993 manual transmission.
Old 10-29-2006, 08:13 AM   #2 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
Re: Carina E transmission oil change
"Hans O. Reimer Hansen" <hansoluf@dohn-nordborg.dk> wrote in message
news:4544b4e6$0$12625$edfadb0f@dread14.news.tele.dk...[color=blue]
> on how to change the transmission oil?
>[/color]
Very cheap source of service info - you can buy one day of access here:
[url]http://www.techinfo.toyota.com/[/url]
Old 10-30-2006, 01:11 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Sun, 29 Oct 2006 15:04:35 +0100, Hans O. Reimer Hansen wrote:
[color=blue]
> Carina E 1993 manual transmission.[/color]
Should be a drain at the botoom of the tranny, and a fill on the side.
Loosen the fill to let the stuff come out easier, and then remove the
drain.
Oh, and this stuff is thicker than Auto Tranny fluid, so it is probably
best done warm.
Replace the plug and the gasket, and then, using the proper grade gear
oil, open the fill plug on the side fully, and fill until it JUST starts
to run out. If you have a 'greaser' it will be that much easier; what I do
is put a piece of hose over the tip of the bottle (it has a 'nipple' on
it) get the bottle as high as you can and squeeze the bottle. You'll
probably need a few quarts; get one quart more than you need in order to
fill the bottle enough to fill the tranny! (You'll only be able to get
about 2/3 of a bottle in this way!).
Of course, I'm describing a RWD car here. If yours is FWD, you'll probably
have no trouble filling the tranny! There *ARE* some advantages to FWD!
Old 10-30-2006, 07:34 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Hachiroku" <Trueno@ae86.gts> wrote in message
news:I7s1h.3979$dx4.2951@trndny05...[color=blue]
>[color=green]
>> on
> drain.
> best done warm.
>[/color]
I'm pretty sure that the Carina is FWD. Also, confirm the correct oil to
use - some manual transmissions use ATF instead of gear oil.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
First Oil Change Completed...Question ScionXA2006 xA Forum 4 10-18-2006 12:25 PM
DIY Oil Change joewildlife 1st Generation (2000–2006) 5 05-16-2006 11:59 AM
1998 Prius Transmission Oil Leakage hannah Prius Forum 3 12-10-2005 02:13 PM
