2002 Avalon heater problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2006, 08:46 AM   #1 (permalink)
bejay53@msn.com
Guest
Posts: n/a
View bejay53@msn.com's Photo Gallery
Hi folks,
I have a problem that appeared gradually last month. when I first strt
driving the car, less than 2 miles, I have plenty of heat. After I hit
the highway (5-6 miles), the heat drops off to "warm". I have to raise
the temp to 80+ to get anything.
Dealer replaced thermostat and cleaned sensors in cabin. Still no go.
Anybody seen this or have suggestions?
Thanks,
Bejay
Old 10-31-2006, 11:28 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2002 Avalon heater problem
<bejay53@msn.com> wrote in message
news:1162302416.541549.263330@b28g2000cwb.googlegroups.com...[color=blue]
> Hi folks,
> Thanks,
> Bejay
>[/color]
You are describing the symptoms of a bad thermostat or bad cabin sensors so
I can understand why the dealer took the actions you described. Did they
check the cabin sensor output? Did they check the ambient air sensor output
(located under the front bumper somewhere)?
Technical Service Bulletin AC009-04 outlines the procedure for checking
various sensors for the AC system.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
98 Avalon Starter Problem alien4ever 1st Generation (1995-1999) 10 10-07-2010 12:10 PM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-30-2008 12:33 AM
Transmission Problem 97 Avalon GarWil99 1st Generation (1995-1999) 10 06-02-2007 05:55 PM
2006 Avalon Problem Starting loliver 1st Generation (1995-1999) 7 06-02-2006 01:22 AM
Heater core problem? 89_3SFE Celica Forum 2 06-09-2004 06:36 PM
