First of all,if there is sludge,dirt or any material at all that
requires the trans to be flushed,you have much bigger problems than a
valve body. The trans should never have a need to be flushed of
material of any kind if your tranny is in good condition.It would have
to be metal,clutch material,or a combination of both.When you change
fluid and filter,thats pretty much how you get your first hint of what
condition your trans is in.If there is lots of metal filings or clutch
flakes or sludge(probably combination of both),then you are not far
away from trans failure.
davemac wrote:[color=blue][color=green]
> > Does this sound like a valve body problem? If so, how hard is it to
> > replace (with a remanufactured unit)? Is this something that can be
> > done in a few hours by a non-professional without specialized tools?
> > Thanks,
> > Tripurari[/color]
> It could be your valve body, but it could be other things too such as a
> bad accumulator, etc. I would check your throttle pressure cable first
> along with a line presure test on the trans to see what is happening to
> the pressure during the stall tests and normal shifting. If it is out
> of spec, then an adjustment or replacement of the throttle presure
> cable could bring it back in line. You can easily do this yourself by
> buying a pressure gauge kit off Ebay for $35 (Page Autosupply).
> As to replacing the valve body: Yes you can do it yourself, but you
> need to be mechanically experienced and meticulous because there are
> many parts and steps you need to go thru to get the valve body off and
> back on. It can be done, but it IS a challenge and will take you 6+
> hrs the first time most likely. You will also need a ATSC trans manual
> for your transmission and need to spend several hours familiarizing
> yourself with the removal and installation procedures. As well, you
> need an accurate torque wrench that can do in-lbs. And of course, you
> should not mind having trans fluid all over you and your garage floor.
> Unless you have balls and like a challenge, I would not recommend
> re-building the valve body yourself. I say this because I have done it
> and would not do it again. Why? There are all kinds of problems you
> can run into such as the trans service manual not being up to date on
> the latest changes, parts falling on the floor and getting damaged,
> stuck valve plugs, wrong re-assembly or messing parts up (and there are
> LOTS or parts!), stuck or bonded gaskets, etc. You can buy a reman'ed
> valve body from Phoenix hard parts for around $200 with a core return
> on your old one. They test it on a dedicated hydraulic
VB tester to
> make sure it works properly. If you go that route, be sure to call
> them and ask them about the shift solenoids and whether they are also
> included. If not, I would recommend a new solenoid kit also from
> bulkparts online. While in there, you should also replace the o-rings
> and seal on the 3 large accumulators in case one of those has a blown
> ring.
> cheers,
> dave mc[/color]
