How much pressure is in the transmission cooler hoses leading to the radiator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-31-2006, 06:49 PM   #1 (permalink)
Mark
Guest
Posts: n/a
View Mark's Photo Gallery
I just replaced the radiator on my 95 Camry 4 cyl. I used new hoses
for the upper and lower radiator feeds and 2 new hoses for the
transmission cooler. I had a little trouble with the new transmission
cooler hoses engaging them as far onto the fitting as I would like.
The clamp is defnintly on over the bump in the fitting. I believe
these hoses are not under high pressure.
Is this correct? How much pressure is on the trany fluid that passes
through the tranny cooler hoses?
thanks
Mark
Old 10-31-2006, 07:32 PM   #2 (permalink)
Mark
Guest
Posts: n/a
Re: How much pressure is in the transmission cooler hoses leading to the radiator
Mark wrote:[color=blue]
> thanks
> Mark[/color]
Old 10-31-2006, 07:43 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Mark" <makolber@yahoo.com> wrote in message
news:1162338578.378899.38460@e64g2000cwd.googlegroups.com...[color=blue]
> thanks
> Mark
>[/color]
The ATF is not under high pressure when it is traveling to the transmission
cooler. High pressure lines will not be held in place with a spring clamp
and are usually threaded.
The pressure going to the transmission cooler is probably under 20 PSI.
Ray O
Old 10-31-2006, 09:05 PM   #4 (permalink)
dsguy
Guest
Posts: n/a
View dsguy's Photo Gallery
> Mark wrote:[color=green]
> > thanks
> > Mark[/color][/color]
i'm not sure about your car, but a lot of cars can have anywhere in the
range of 50-150 psi going through those lines. standard trans hoses and
properly fastened clamps will be okay.
Old 10-31-2006, 11:08 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Tue, 31 Oct 2006 18:43:02 -0600, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
>news:1162338578.378899.38460@e64g2000cwd.googlegroups.com...[/color]
[color=blue][color=green]
>> through the tranny cooler hoses?[/color]
>The pressure going to the transmission cooler is probably under 20 PSI.[/color]
But remember that doesn't apply as a blanket rule to all cars, and
it's good that you thought to check.
As an example, on some old GM Powerglide transmissions the cooler
line pressure is low in Neutral and Drive - but it spikes to around
150-200 PSI when you shift into Reverse, and can blow cooler hoses
that aren't made to handle that much pressure.
Even at 150 PSI with 1/4" hose the hose fittings don't have to be
too special, besides having a positive retaning bump or 'arrowhead'
groove as a retainer, and the hose has to be clamped past the bump
with wide worm-drive clamps to make sure it can't come off.
(No 'wire spring' clamps, not enough clamping force.)
But when you get much higher in pressure than that, or larger hoses
that will see the effects sooner, you have to go to a mechanically
clamped hose fitting system of some sort. Notably the ones using the
Aeroquip design (or equivalent) if you want to field assemble the hose
and fittings.
They have a threaded mandrel 'nut' that clamps the outer sheath of
the hose into the fitting, so it can't pull out short of severe abuse
- things like a motor mount shearing and the hose tries to hold the
engine in the car...
--<< Bruce >>--
Old 11-01-2006, 07:36 AM   #6 (permalink)
Mark
Guest
Posts: n/a
Bruce L. Bergman wrote:[color=blue]
> <rokigawaATtristarassociatesDOTcom> wrote:[color=green]
>[color=green][color=darkred]
>[/color]
So does anybody know what the pressure is for the 95 Camry?
Mark
Old 11-01-2006, 08:30 AM   #7 (permalink)
Don Bruder
Guest
Posts: n/a
View Don Bruder's Photo Gallery
In article <1162346712.695964.158380@b28g2000cwb.googlegroups.com>,
"dsguy" <sfrisby2000@yahoo.com> wrote:
[color=blue]
> > Mark wrote:[color=darkred]
> > > thanks
>[/color]
Likewise, I'm not sure about the particular car being discussed, but
when vibration against one of the clips holding it to the frame ate a
pinhole in the metal line of an 80's vintage Ford F-150, and started
spewing tranny-juice all over bottom of the driver's side exhaust
manifold one evening far from home (I thought the freakin' engine had
caught fire, the smoke was so heavy!) I found that 3-4 wraps of typical
black electrical tape was an adequate "until the parts places open in
the morning and I can get a new piece of line" repair. Ended up not
having any option but to drive it for almost 4 days before being able to
actually crawl under and fix it proper, and when I did, found that
leakage after applying the tape was close enough to zero, and the tape
showed no inclination to "blow out". So for that case, the answer is
"comparatively low". Mileage is all but certain to vary from one setup
to the next, though - I have no doubts that there are vehicles out there
running high pressure to the cooler, and that such rides would have
popped the tape almost instantly.
Don Bruder - [email]dakidd@sonic.net[/email] - If your "From:" address isn't on my whitelist,
or the subject of the message doesn't contain the exact text "PopperAndShadow"
somewhere, any message sent to this address will go in the garbage without my
ever knowing it arrived. Sorry... <http://www.sonic.net/~dakidd> for more info
Old 11-01-2006, 09:31 AM   #8 (permalink)
Al Bundy
Guest
Posts: n/a
View Al Bundy's Photo Gallery
dsguy wrote:[color=blue]
> > > thanks
> properly fastened clamps will be okay.[/color]
I've been using rubber fuel line and hose clamps for years so there
can't be much pressure. Cooler kits often come with similar hoses and
clamps.
Old 11-01-2006, 12:28 PM   #9 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On 1 Nov 2006 04:36:25 -0800, "Mark" <makolber@yahoo.com> wrote:
[color=blue]
>Bruce L. Bergman wrote:[color=green]
>> <rokigawaATtristarassociatesDOTcom> wrote:[color=darkred]
>> >news:1162338578.378899.38460@e64g2000cwd.googlegroups.com...[/color][/color][/color]
[color=blue][color=green][color=darkred]
>> it's good that you thought to check.[/color]
>So does anybody know what the pressure is for the 95 Camry?[/color]
Look above (a little closer) for the answer - I snipped it down to
only the relevant bits for ease of reading comprehension. ;-)
Ray was a District Service Manager for Toyota for many years, and
went through all the same training as the line technicians...
He can't give you an exact figure, obviously, but "under 20 PSI" for
the models of transmissions offered in that vintage Camry is more than
"close enough for Gummint Work".
Any purpose-made hose that they shipped with a trans cooler kit, the
rubber compounds used can handle the fluid without deteriorating and
should be fine, they are usually rated at 100 PSI or better in those
small sizes. The hose ratings should be printed on the side of the
hose, and on the package.
You do NOT want to use regular "fuel line" or "heater hose" - that
is NOT meant for transmission fluid, and will go bad and leak/burst on
you much faster than the right hose.
--<< Bruce >>--
Old 11-01-2006, 12:40 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:oblhk25b3kqj85b3eidfn2r41n5cnae9nb@4ax.com...[color=blue]
>[color=green]
>>Bruce L. Bergman wrote:[color=darkred]
>>> >> passes
> --<< Bruce >>--
>[/color]
Actually, "under 20 PSI" is just a guess on my part, I can check a factory
service manual when I get home tonight. IIRC, the pressure going to the ATF
cooler is much lower than internal line pressures, which is how I came up
with 20 PSI.
Ray O
Old 11-01-2006, 01:50 PM   #11 (permalink)
Built_Well
Guest
Posts: n/a
View Built_Well's Photo Gallery
cooler hoses leading to the radiator? I can answer
that very simply: more pressure than what's in the
President's Mini-Me when he's "helping out" Laura. [laughter]
Like Sharx, the President is also a Nominal Hetero [chuckle]
Posted via a free Usenet account from [url]http://www.teranews.com[/url]
Old 11-01-2006, 03:39 PM   #12 (permalink)
Comboverfish
Guest
Posts: n/a
View Comboverfish's Photo Gallery
Ray O wrote:
[color=blue]
> with 20 PSI.[/color]
You are correct about your pressure guestimate, the cooler circuit
pressure is regulated (reduced) in the valve body. I suspect you will
not find a spec on cooler pressure, but if you do let me know. The
only spec I have ever seen in any model/year Toyota RM is for line
pressure under various conditions.
Toyota MDT in MO
Old 11-01-2006, 03:55 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
"Comboverfish" <comboverfish@yahoo.com> wrote in message
news:1162413557.969680.21250@b28g2000cwb.googlegroups.com...[color=blue]
> Ray O wrote:
>[color=green]
>> factory
>> ATF
> Toyota MDT in MO
>[/color]
I don't recall ever seeing a spec on cooler pressure either, just line
pressures.
Where have you been? We can use your help for those few posters who actually
have problems!
Ray O
Old 11-01-2006, 04:39 PM   #14 (permalink)
Comboverfish
Guest
Posts: n/a
Ray O wrote:
[color=blue]
> pressures.
> have problems![/color]
I typically only reply to rec.auto.tech but sometimes a poster will
query multiple groups so my reply and followups go to all groups
involved.
The Toyota group has really turned me off for a while now with the OT
junk and those few idiot regulars that try to ruin it for everyone. At
rec.auto.tech the idiots are easier to shoe away, or so it seems :)
Good to hear from you, Ray.
Toyota MDT in MO
Old 11-01-2006, 04:59 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
news:1162417166.078871.139700@e64g2000cwd.googlegroups.com...[color=blue]
> Ray O wrote:
>[color=green]
>> pressures.
>> actually
> involved.
> Toyota MDT in MO
>[/color]
I could also do without all the OT stuff at alt.autos.toyota! I'll have to
check out rec.auto.tech.
Thanks,
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Which transmission cooler hose of 2003 Echo is outlet? sifan Yaris, Vitz and Echo Forum 0 07-29-2004 08:37 PM
Transmission cooler anyone? |PuNiSh3R| Archived Corolla threads 22 02-12-2004 11:33 PM
transmission pressure |PuNiSh3R| Hardcore Tech and Competition 2 02-10-2004 05:19 PM
Mister Transmission in Markham Im_a_dickhead Feedback: Buyers, Sellers, and Vendors 4 07-31-2002 10:43 PM
no more frowning on A/T cars! Go! project trueno General Discussion 12 12-14-2001 10:54 AM
