2000 Sienna brakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 09:47 AM   #1 (permalink)
Jack
Guest
Posts: n/a
View Jack's Photo Gallery
2000 Sienna brakes
2000 Sienna brakes: does this car have ticklers on the brakes so that you
can hear when the brakes need to be replaced?
Old 11-02-2006, 11:07 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 2000 Sienna brakes
"Jack" <floydwilliams@comcast.net> wrote in message
news:13zjo9kg8lwv7.1ndkilarbqdyk.dlg@40tude.net...[color=blue]
> can hear when the brakes need to be replaced?[/color]
I do not know if the Sienna has wear indicators or not. The wear indicators
are part of the brake pad so even if the original pads had wear indicators,
if aftermarket pads were installed, they may not.
Even if the vehicle has wear indicators, it is not a good idea to rely on
wear indicators to tell if you need brake pad replacement because the
indicators are only on the inner pads, and if the brakes wear unevenly or
the slide gets stuck, then you may never hear the squeal. The best way to
check brake pad wear is to visually inspect them.
On the other hand, if you are hearing the squeal from the wear indicators,
it is a good idea to have them checked out.
Ray O
Old 11-02-2006, 12:48 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Thu, 02 Nov 2006 10:07:40 -0600, Ray O wrote:
[color=blue]
> news:13zjo9kg8lwv7.1ndkilarbqdyk.dlg@40tude.net...[color=green]
> it is a good idea to have them checked out.[/color]
It's been a while since I replaced OEM brake pads...well, actually, not.
My Mom's Camry had OEM pads in it, and I think it had wear indicators on
both pads.
I know when you get AM pads from CarQuest it has a wear indicator on both
pads.
BB code is Off
Smilies are Off
[IMG] code is Off
New wheels for a 2000 Sienna 94SRUNNER 1st Generation (1998-2003) 2 09-29-2006 12:59 AM
2007 Sienna Upgrades Thundercat Toyota News 7 09-27-2006 12:12 PM
2000 Sienna XLE remote program?? bridger Audio, Video, and Security - Tech 0 04-23-2004 04:26 PM
2000 Sienna security system problems sixpackbird Audio, Video, and Security - Tech 3 03-15-2004 10:00 PM
2000 Camry brakes khopkins 3rd & 4th Generation (1992–1996 & 1997–2001) 6 08-14-2003 02:14 AM
