Help!!! I dont know what's wrong - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2006, 11:46 AM   #1 (permalink)
socorro_9@hotmail.com
Guest
Posts: n/a
View socorro_9@hotmail.com's Photo Gallery
I have a 1998 Corolla CE with approx. 139,000 miles on it. Its a five
speed and I noticed lately that the gears do not shift good. I have to
push hard on the gas in order for it to go. In fact, I think that all
my gears are like that...a long passing gear before it catches. What
is that, the transmission or the clutch?
Old 11-02-2006, 12:16 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Help!!! I dont know what's wrong
<socorro_9@hotmail.com> wrote in message
news:1162486007.797238.119610@i42g2000cwa.googlegroups.com...[color=blue]
>[/color]
When you say that the gears "do not shift good" do you mean that it is
difficult to put the gearshift lever into position or do you hear a grinding
noise when shifting?
check the fluid level in the clutch master cylinder next to the brake master
cylinder in the engine compartment.
Ray O
Old 11-02-2006, 04:06 PM   #3 (permalink)
Guest
Posts: n/a
Ray O wrote:[color=blue]
> news:1162486007.797238.119610@i42g2000cwa.googlegroups.com...[color=green]
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
No, the gears shift into position well, its just that the gears do not
catch upon shifting. When it finally gets into gear, the engine revs,
but the car does not speed up.
Old 11-02-2006, 06:20 PM   #4 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
If this is his first clutch with 139k miles, he got his money's worth.
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:e5e0f$454a5ffb$44a4a10d$21600@msgid.meganewsservers.com...[color=blue]
> news:1162501585.779336.109680@b28g2000cwb.googlegroups.com...[color=green]
>> Ray O wrote:[color=darkred]
>>> > to
>>> grinding
>>> master
>>> Ray O
>>[/color]
> That sounds like a worn clutch or worn pressure plate.
> Factors that cause rapid clutch wear are drivers who are relatively new to
> driving a vehicle with a manual transmission, excessive slipping of the
> clutch, drive frequently in stop-and-go traffic, downshift frequently,
> frequent start on inclines, and holding the car on an incline by slipping
> the clutch instead of using the brake.
> Ray O
>[/color]
Old 11-02-2006, 10:15 PM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Thu, 02 Nov 2006 15:15:35 -0600, Ray O wrote:
[color=blue]
>>> grinding
>>> master
>>> Ray O
>>[/color]
> the clutch instead of using the brake.[/color]
Hey, Ray, I always downshift. Have been since I bought my first Toyota.
What do you mean by "Downshift Frequently"?
I have 259,000 on the ORIGINAL clutch on my Corolla, and the Corolla
before that went 235,000 on the original clutch!
Old 11-02-2006, 10:25 PM   #6 (permalink)
Cathy F.
Guest
Posts: n/a
View Cathy F.'s Photo Gallery
"Hachiroku" <Trueno@AE86.gts> wrote in message
news:pan.2006.11.02.21.15.07.220712@AE86.gts...[color=blue]
>[color=green]
>> news:1162501585.779336.109680@b28g2000cwb.googlegroups.com...[color=darkred]
>>> Ray O wrote:[/color]
>> to
> before that went 235,000 on the original clutch![/color]
When I had Corolla manuals, I also downshifted fairly often instead of
braking, & would often hold the car on a hill by slipping
the clutch. Never had the cars beyond 6 years or the high mileage you've
had, but never had any clutch probs, either.
Cathy
[color=blue]
>[/color]
Old 11-02-2006, 10:27 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Sounds like you've worn the clutch out.
>[/color]
Old 11-02-2006, 10:27 PM   #8 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:1162501585.779336.109680@b28g2000cwb.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> news:1162486007.797238.119610@i42g2000cwa.googlegroups.com...[color=darkred]
>> >[/color]
>> grinding
>> master
>> Ray O
>[/color]
DEFINITELY a worn clutch.
Old 11-02-2006, 11:15 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
>[color=green]
>>>> > to
>>>> > all
>>>> grinding
>>>> master
>>>> Ray O
>>>[/color]
>> to
>[/color]
Well, you can slow down the car by downshifting or you can slow down by
applying the brakes. If you downshift at higher RPM, then you are wearing
the clutch more than if engine and transmission speed are matched. Of
course, on long downhills, downshifting is preferable to letting the brakes
fade. Personally, I'd rather do a brake job than a clutch job. ;-)
Ray O
Old 11-02-2006, 11:17 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
"Cathy F." <clfr@adelphiadot.net> wrote in message
news:GfmdnWHZWPkTK9fYnZ2dnUVZ_oidnZ2d@giganews.com...[color=blue]
> news:pan.2006.11.02.21.15.07.220712@AE86.gts...[color=green]
>>[color=darkred]
>>> to
>>> slipping
> Cathy
>[/color]
Brakes are much cheaper to service than replacing the clutch. Downshifting
instead of braking and holding the car on a hill by slipping the clutch are
the worst things you can do for clutch life. You sold your clutch problems
to someone else.
Ray O
Old 11-02-2006, 11:19 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:5-WdnVTZWeakKtfYnZ2dnUVZ_rednZ2d@ez2.net...[color=blue]
>>> > to
>>> grinding
>>> master
>>> Ray O
>>[/color]
>[/color]
Or a bad pressure plate, which in terms of repair cost, is about the same.
Ray O
Old 11-02-2006, 11:24 PM   #12 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:VsudnZbkZqOKJdfYnZ2dnUVZ_qKdnZ2d@giganews.com...[color=blue]
> news:stednaCsNdEzKtfYnZ2dnUVZ_rqdnZ2d@ez2.net...[color=green]
>> news:GfmdnWHZWPkTK9fYnZ2dnUVZ_oidnZ2d@giganews.com...[color=darkred]
>>>>> new to
>>>>> the
>>>>> slipping
>>> you've had, but never had any clutch probs, either.
>>>[/color]
>> That's because you sold the clutch problems to the next buyer.[/color]
> Only if they kept it basically forever, is my guess.
> Cathy
>[/color]
Hachi's experience is a bit of an anomoly. Most people get about 100k ~ 150k
miles from a clutch. I can get over 200k, and I'm certain there are others
on this board that also get high miles from a clutch, but I think this board
attracts regular participants that drive better than the general population.
Most folks would need a clutch at intervals that match yours, you just get
rid of the car before you realize the clutch needs to be replaced. (No
dissing intended.)
And, as a point of order, I do not attribute downshifting with short clutch
life. If one is inclined to goos the gas pedal a bit and raise the RPMs so
the engine and transmission (in the new gear) are going at about the same
speed, the wear on the clutch is not a factor. Using the clutch as a
hill-holder is definitely a bad practice in terms clutch life.
Old 11-02-2006, 11:30 PM   #13 (permalink)
Jeff Strickland
Guest
Posts: n/a
news:48374$454ac33c$47c2b532$32482@msgid.meganewsservers.com...[color=blue]
> news:5-WdnVTZWeakKtfYnZ2dnUVZ_rednZ2d@ez2.net...[color=green]
>>>> > to
>>>> > all
>>>> grinding
>>>> master
>>>> Ray O
>>>[/color]
>>[/color]
> Or a bad pressure plate, which in terms of repair cost, is about the same.[/color]
Yes, and it's the same work to get far enough to know one or the other, AND
most of us would replace both at the same time.
And, if one has to ask, they probably do not know the clutch from the
pressure plate, and the distinction is more confusing than simply lumping
all of the parts into "clutch."
Old 11-03-2006, 02:10 AM   #14 (permalink)
Danny G.
Guest
Posts: n/a
View Danny G.'s Photo Gallery
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message news:a6171$454ac33b$47c2b532$32482@msgid.meganewsservers.com...[color=blue]
> "Cathy F." <clfr@adelphiadot.net> wrote in message news:GfmdnWHZWPkTK9fYnZ2dnUVZ_oidnZ2d@giganews.com...[color=green]
>> "Hachiroku" <Trueno@AE86.gts> wrote in message news:pan.2006.11.02.21.15.07.220712@AE86.gts...[color=darkred]
>> When I had Corolla manuals, I also downshifted fairly often instead of braking, & would often hold the car on a hill by slipping
>> the clutch. Never had the cars beyond 6 years or the high mileage you've had, but never had any clutch probs, either.
>> Cathy
>>[/color]
> Brakes are much cheaper to service than replacing the clutch. Downshifting instead of braking and holding the car on a hill by
> slipping the clutch are the worst things you can do for clutch life. You sold your clutch problems to someone else.
> Ray O
If your good at shifting then there is no wear changing gears. Heck I'd bet my paycheck
that I could jump into any typical car and not even use the clutch when shifting gears
smooth enough no one would notice.
Old 11-03-2006, 10:17 AM   #15 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
news:HuadnVn9I6VQWNfYnZ2dnUVZ_qSdnZ2d@ez2.net...[color=blue]
> news:48374$454ac33c$47c2b532$32482@msgid.meganewsservers.com...[color=green]
>> news:5-WdnVTZWeakKtfYnZ2dnUVZ_rednZ2d@ez2.net...[color=darkred]
>>>>> >five
>>>>> > to
>>>>> > all
>>>>> > What
>>>>> grinding
>>>>> master
>>>>> Ray O
>>>[/color]
>> same.[/color]
> AND most of us would replace both at the same time.[/color]
As well as throwout and pilot bearings. It's false economy to "go inside" a
clutch and NOT replace any parts which typically wear out, regardless of
their condition, particularly with a front wheel drive car.
Mike Harris
Austin TX
BB code is Off
Smilies are Off
[IMG] code is Off
WTF is wrong with americian girls Aaagogo Off Topic 29 02-25-2005 12:58 AM
Anything look wrong with this picture? MrRavenX Archived Corolla threads 8 02-18-2005 05:04 PM
whats wrong with this mix? alex Off Topic 12 02-01-2005 01:13 AM
Something wrong with my compressor... Rasco Camry & Solara Lounge 1 11-08-2004 04:58 PM
Color of seat covers wrong amerikim Camry & Solara Lounge 0 11-06-2004 10:40 PM
