"Andrew Stephenson" <ames@deltrak.demon.co.uk> wrote in message
news:1162779368snz@deltrak.demon.co.uk...[color=blue]
> In article <051120061936532451%Masked@mm.m>
> [email]Lady_Purse-Wader@yahoo.co.uk[/email] "Masked" writes:
>[color=green]
>> We bought our Prius new in Aug 05. [...][/color]
> Then don't mess about with it yourself. Leave it to the dealer,
> as
AFAIK you are safely inside the warranty period.
>[color=green]
>> Alas, tonight I backed the Prius out of the garage, turned it
>> off while I closed the garage door, and attempted to restart
>> it. [...][/color]
> Apart from caution over theft or kids/pets/idiots engaging Drive
> (despite the built-in safeties), you don't need to turn off the
> dashboard in such circumstances. Switching off/on is not a huge
> drain on things (
AFAIK, NB); and even leaving loads like the a/c
> running is covered by the car minding the state of charge itself.
>[color=green]
>> Should I risk trying to recgarge the 12v battery through the
>> specified terminal in the engine compartment's fusebox?[/color]
> If you were about to do the work yourself, you'd still need to be
> sure the 12v battery was squiffed. Has the battery been examined
> in the ways usual for trad lead/acid cells (without infringing on
> the dealer's territory)? (Eg, electrolyte level, terminal volts,
> general condition; maybe Ray O has some suggestions there.) But,
> as you are leaving it to your friendly local dealer (yes?), don't
> do more than look at it from a distance.
> BTW, I assume (as you didn't say otherwise) that you were able to
> open the boot (US:trunk)? If so the 12v battery is okay, because
> it provides the power to unlock the hatch when you pull up on the
> lifting point: the mildly squishy feel is your fingers pressing a
> switch.
> Andrew Stephenson
>[/color]
It sounds like the 12 V battery is discharged. The OP can try jumping or
charging per the instructions in the owner's manual. If it is still under
warranty, I'd let the dealer handle it.
Ray O
