Re: Toyota - no start -turns over - got gas- got power - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-06-2006, 09:15 AM   #1 (permalink)
carcrazy42
Guest
Posts: n/a
View carcrazy42's Photo Gallery
Update!
We've loosening bolts and got part of the timing belt cover off just
enough to see that the timing belt is in there and in one piece. Looks a
little worn but definitely not broke.
Old 11-06-2006, 10:00 AM   #2 (permalink)
Kurt Krueger
Guest
Posts: n/a
View Kurt Krueger's Photo Gallery
carcrazy42 wrote:
[color=blue]
> Update!
>[/color]
So the belt actually moves when you crank the engine? I've had prefectly
good looking belts with stripped teeth where it engaged the crankshaft.
Old 11-06-2006, 11:00 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"carcrazy42" <herecomesthesun64@nospamyahoo.com> wrote in message
news:f9a4f85a3ae6c04d8e5186f62b04c0f8@localhost.talkaboutautos.com...[color=blue]
> Update!
>[/color]
Make sure the ignition is off, disconnect the coil from the distributor, and
using the crankshaft pulley bolt, turn the engine clock-wise. The belt
should turn the camshaft pulley and the camshaft pulley should rotate. If
it does not, the belt is bad.
Ray O
Old 11-06-2006, 11:48 AM   #4 (permalink)
carcrazy42
Guest
Posts: n/a
Some teeth are missing. When cranking the engine, the belt doesn't move.
Old 11-06-2006, 12:04 PM   #5 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
news:5cc34b1981f31ff9d473db88872aff81@localhost.talkaboutautos.com...[color=blue]
> Some teeth are missing. When cranking the engine, the belt doesn't move.[/color]
You looking for advice or just bragging? If the former, model, year and
engine would be helpful.
If your "belt doesn't move," and I'm assuming you mean the accessory drive
belts, either the starter is not turning the flywheel / flex plate - and
missing teeth would cause that, or you have serious internal engine damage
e.g. broken crankshaft.
Replace the starter and/or ring gear, or replace the engine.
Mike Harris
Austin TX
Old 11-06-2006, 01:47 PM   #6 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Mon, 06 Nov 2006 10:15:19 -0500, carcrazy42 wrote:
[color=blue]
> Update!
> little worn but definitely not broke.[/color]
With the cover loose, and your fingers out of the way, spin the engine
(crank it over)
My belt looked fine, too...but the teeth had broken off at the bottom gear!!
Old 11-06-2006, 04:15 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Mike Harris" <harrisremovethiswest@sbcglobal.net> wrote in message
news:yOK3h.841$6t.576@newssvr11.news.prodigy.com...[color=blue]
> news:5cc34b1981f31ff9d473db88872aff81@localhost.talkaboutautos.com...[color=green]
> Mike Harris
> Austin TX[/color]
[color=blue]
> I think the OP is talking about the timing belt, not the accessory drive
> belt.[/color]
Ray O
Old 11-06-2006, 04:16 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
>[/color]
Assuming you are talking about teeth missing on the timing belt and not on
the crankshaft or camshaft pulley, you need a new timing belt.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
F@ck Exxon Mobil-1... turbos17 2nd Generation (2005+) 62 02-01-2006 08:51 PM
Discount on all TWM Toyota Short Shifters! TWM Performance General Discussion 0 05-19-2005 09:20 AM
We have the power to reduce gas prices! EuroCamz General Discussion 32 04-10-2004 05:53 PM
