strange alternator faliure Corolla '90 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 03:10 AM   #1 (permalink)
kaabdalis
Guest
Posts: n/a
View kaabdalis's Photo Gallery
Hi
I posted a couple of month ago about my bad alternator. Eventually I
replaced the alternator with
an old one that i bought (app $30) at a scrap yard.
It was the diodes that had failed on the original alternator.
however, the "new" alternator failed after approximatly 1.5 month.
The diodes had failed on this alternator as well.
I went back to the scrapyard and bought another one which (knock on
wood) has worked fine
for the last six months.
My question:
Was it bad luck? Or could it be somekind of hidden fault that burnt
the diodes on the first two alternators?
I thought that diodes were pretty robust and shouldn't fail so easy.
Bad grounding?
Water splash?
To tight belt?
Bad wirering to the voltageregulator?
/Rickard
Old 11-07-2006, 07:01 AM   #2 (permalink)
n5hsr
Guest
Posts: n/a
View n5hsr's Photo Gallery
Re: strange alternator faliure Corolla '90
"kaabdalis" <barrud@gmail.com> wrote in message
news:1162890603.529499.169730@k70g2000cwa.googlegroups.com...[color=blue]
> Hi
> My question:
> Bad grounding?
> Water splash?
> To tight belt?
> /Rickard
>[/color]
OK, were the alternators NipponDenso, or AC-Delco? Makes a difference.
Charles of Schaumburg
Old 11-07-2006, 10:47 AM   #3 (permalink)
kaabdalis
Guest
Posts: n/a
uhhm,
I'm not really sure, but it kind of looks like this
[url]http://image.racepages.com/live/F400089003ND.JPG[/url]
n5hsr skrev:
[color=blue]
> news:1162890603.529499.169730@k70g2000cwa.googlegroups.com...[color=green]
> > Hi
> > My question:
> > Bad grounding?
> > Water splash?
> > To tight belt?
> > /Rickard
> >[/color]
> Charles of Schaumburg[/color]
Old 11-07-2006, 12:25 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> Hi
> My question:
> Bad grounding?
> Water splash?
> To tight belt?
> /Rickard
>[/color]
Toyotas are very consistent, so a problem that appears in one is likely to
appear in another. Conversely, Toyotas do not have a lot of odd,
one-of-a-kind problems.
Any of the things you listed can shorten the life of an alternator or its
components.
Ray O
Old 11-07-2006, 06:25 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On 7 Nov 2006 01:10:03 -0800, "kaabdalis" <barrud@gmail.com> wrote:
[color=blue]
>My question:
>Bad grounding?
>Water splash?
>To tight belt?
>Bad wirering to the voltageregulator?[/color]
All of the above can be it, but the first thing to check is the
battery. If it's "out of warranty" (48 month battery that's more than
4 years old based on the manufacture date code stamp/sticker) get it
load tested.
Batteries go bad just on time alone. And with weak cells, they'll
overload the alternator by demanding full output constantly.
Too tight a belt usually trashes the ball bearings in the alt.
--<< Bruce >>--
Old 11-08-2006, 01:14 AM   #6 (permalink)
kaabdalis
Guest
Posts: n/a
Thanx for your suggestion. I will check out the battery.
Best regards
Rickard
Bruce L. Bergman skrev:
[color=blue]
>[color=green]
> >My question:
> >Bad grounding?
> >Water splash?
> >To tight belt?
> load tested.
> --<< Bruce >>--[/color]
Old 11-08-2006, 06:58 AM   #7 (permalink)
Asbjørn
Guest
Posts: n/a
View Asbjørn's Photo Gallery
On mine there were bad (oxidized?) connections both between the alternator
and the battery, and between the battery minus and the ground
(transmission).
But it may well be a bad battery.
Asbjørn
news:1162970060.041315.280080@e3g2000cwe.googlegroups.com...[color=blue]
> Best regards
> Rickard
>[color=green]
>>[color=darkred]
>> >My question:
>> >Bad grounding?
>> >Water splash?
>> >To tight belt?
>> load tested.
>[/color]
Old 11-08-2006, 02:42 PM   #8 (permalink)
kaabdalis
Guest
Posts: n/a
Ok, did this problem damage your Alternator?
I did some resistance measurements between the alternator and the
battery.
It seems normal to me.
How do I check if my battery is faulty?
The battery seems ok since I could start and drive the car when the
alternator was broken.
I drove at least 30km with two start without any problem.
/Rickard
Asbjørn skrev:
[color=blue]
> (transmission).
> Asbjørn
> news:1162970060.041315.280080@e3g2000cwe.googlegroups.com...[color=green]
> > Best regards
> > Rickard
> >[color=darkred]
> >> >My question:
> >> >Bad grounding?
> >> >Water splash?
> >> >To tight belt?
> >> load tested.
> >[/color][/color]
Old 11-08-2006, 02:57 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
news:1163018569.605985.294980@m73g2000cwd.googlegroups.com...
battery.
/Rickard
You can check if your battery is faulty by performing a load test and
checking the specific gravity of each cell.
Your battery may have been OK before, but driving 30 km with a broken
alternator can ruin the battery unless you have a deep cycle battery. You
may have damaged the battery, which in turn damaged the replacement
alternator.
Ray O
Old 11-08-2006, 03:00 PM   #10 (permalink)
kaabdalis
Guest
Posts: n/a
Ok, I understand,
How do I set up a load test?
On 8 Nov, 21:57, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:[color=blue]
> "kaabdalis" <bar...@gmail.com> wrote in messagenews:1163018569.605985.294980@m73g2000cwd.googlegroups.com...
> battery.
> /Rickard
> alternator.
> Ray O
> (correct punctuation to reply)[/color]
Old 11-08-2006, 03:37 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:1163019602.365625.110410@k70g2000cwa.googlegroups.com...[color=blue]
> Ok, I understand,
>[/color]
To load test a battery, you need a device that puts a load on the battery,
cleverly called a load tester. I call them load toasters because they glow
like a toaster's elements when you hook them up to the battery.
Load testers range from $30 to over $1,000 and unless I intended to check a
lot of batteries, I would not invest in one. A lot of auto parts store,
including Sears, will check your battery for free, including load testing.
Ray O
[color=blue]
> On 8 Nov, 21:57, "Ray O" <rokigawaATtristarassociatesDOTcom> wrote:[color=green]
>> battery.
>> /Rickard
>> You
>> alternator.
>> Ray O
>[/color]
Old 11-08-2006, 08:56 PM   #12 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Wed, 8 Nov 2006 15:37:27 -0600, "Ray O"
>news:1163019602.365625.110410@k70g2000cwa.googlegroups.com...[/color]
[color=blue][color=green]
>> Ok, I understand, How do I set up a load test?[/color]
>including Sears, will check your battery for free, including load testing.[/color]
You can buy an inexpensive and perfectly serviceable load tester at
Harbor Freight for $30-ish. Or have it done.
You want to see about 12.6 Volts on the battery with the engine off
and no loads on it - if it can't even manage that, even after you put
a trickle charger on overnight to make sure it's charged, the battery
is toast.
Then you clip the Load Tester cables to the battery posts and turn
on the load bank to put 30 to 60 amps of load on the battery, and
watch the battery output voltage - it shouldn't dip down more than
about a volt, inside the 'Green' area of the tester's voltmeter.
If it drops two to four volts fast, you probably have a bad cell.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
90 corolla GTS FWD relay box wiring 89 tercel racer Archived Corolla threads 0 05-30-2006 02:40 AM
Removing Rear Speakers of '90 Corolla eastcoastmowers Archived Corolla threads 3 08-20-2005 05:04 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Wheel size on a 90 Corolla 4 door touringcamry Archived Corolla threads 5 06-07-2004 04:10 AM
4A-FE to 7A-FE - 90 corolla dx wagon Heyman-FX16GTS Hardcore Tech and Competition 0 07-26-2003 10:53 PM
