Help! RAV4 heater fan - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2006, 01:53 PM   #1 (permalink)
bushman
Guest
Posts: n/a
View bushman's Photo Gallery
'96 RAV4 AC/H fan has quit after one setting has been dead for a while. My
question: is it the fan motor, is the relay below the fan for the fan or is
it the switch that is bad? I figure that you folks have the conventional
wisdom and experience with this problem. I did push on all the connectors
and pulled and pushed that relay, the fan started and ran for 30 minutes.
Thanks in advance. - Allen
Old 11-07-2006, 02:01 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Help! RAV4 heater fan
"bushman" <askme@askme.com> wrote in message
news:Qu54h.4304$Bl1.974@tornado.tampabay.rr.com...[color=blue]
> is it the switch that is bad? I figure that you folks have the
> conventional wisdom and experience with this problem. I did push on all
> the connectors and pulled and pushed that relay, the fan started and ran
> for 30 minutes. Thanks in advance. - Allen[/color]
Besides the items you listed, other possible causes are the resistor pack
and the wiring.
If you want to properly identify the problem, you should invest in a
volt/ohm meter if you do not already have one.
If there is another relay identical to the fan relay, you can try swapping
them to see if the swapped item starts acting up, or you can pull the relay,
apply 12 volts to the control voltage, and see if there is continuity
through the switched side. If the relay is passing power, then check for
power going into and out of the resistor pack. I suspect that the resistor
pack is the problem.
Ray O
Old 11-08-2006, 05:47 AM   #3 (permalink)
bushman
Guest
Posts: n/a
OK I will poke around with the tester. Where is the resistor pack?
-Allen
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:5095f$4550e626$44a4a10d$6699@msgid.meganewsservers.com...[color=blue]
> news:Qu54h.4304$Bl1.974@tornado.tampabay.rr.com...[color=green]
>> My question: is it the fan motor, is the relay below the fan for the fan
>> or is it the switch that is bad? I figure that you folks have the
> and the wiring.
> relay, apply 12 volts to the control voltage, and see if there is
> continuity through the switched side. If the relay is passing power,
> then check for power going into and out of the resistor pack. I suspect
> that the resistor pack is the problem.
> Ray O
>[/color]
Old 11-08-2006, 06:49 AM   #4 (permalink)
Asbjørn
Guest
Posts: n/a
View Asbjørn's Photo Gallery
In the fan housing, I'll guess.
Asbjørn
news:8tj4h.6628$sv1.690@tornado.tampabay.rr.com...[color=blue]
> -Allen
> news:5095f$4550e626$44a4a10d$6699@msgid.meganewsservers.com...[color=green]
>> news:Qu54h.4304$Bl1.974@tornado.tampabay.rr.com...[color=darkred]
>> and the wiring.
>> swapping them to see if the swapped item starts acting up, or you can
>> pull the relay, apply 12 volts to the control voltage, and see if there
>> is continuity through the switched side. If the relay is passing power,
>> Ray O
>>[/color]
>[/color]
Old 11-08-2006, 09:20 AM   #5 (permalink)
bushman
Guest
Posts: n/a
That is the it was on my FX. Had to replace the fan. Thanks. - Allen
"Asbjørn" <asbjust@frisurf.no> wrote in message
news:epudnVu6hOPQT8zYRVnzvQ@telenor.com...[color=blue]
> Asbjørn
> news:8tj4h.6628$sv1.690@tornado.tampabay.rr.com...[color=green]
>> -Allen
>> news:5095f$4550e626$44a4a10d$6699@msgid.meganewsservers.com...[color=darkred]
>>>> fan or is it the switch that is bad? I figure that you folks have the
>>>> ran for 30 minutes. Thanks in advance. - Allen
>>> pack and the wiring.
>>> power, then check for power going into and out of the resistor pack. I
>>> suspect that the resistor pack is the problem.
>>> Ray O
>>>[/color]
>>[/color]
>[/color]
Old 11-08-2006, 10:14 AM   #6 (permalink)
Asbjørn
Guest
Posts: n/a
I do not know for sure about the RAV4 (I have not got mine yet),
but on my former Corolla I unscrewed the resistor pack from the fan housing
and repaired the broken resistors with crimping cable connectors
because normal soldering will probably melt.
Asbjørn
news:YAm4h.12102$q45.8738@tornado.tampabay.rr.com...[color=blue]
> news:epudnVu6hOPQT8zYRVnzvQ@telenor.com...[color=green]
>> Asbjørn
>> news:8tj4h.6628$sv1.690@tornado.tampabay.rr.com...[color=darkred]
>>> -Allen
>>>>> while. My question: is it the fan motor, is the relay below the fan
>>>>> for the fan or is it the switch that is bad? I figure that you folks
>>>>> have the conventional wisdom and experience with this problem. I did
>>>>> push on all the connectors and pulled and pushed that relay, the fan
>>>>> started and ran for 30 minutes. Thanks in advance. - Allen
>>>> Ray O
>>>[/color]
>>[/color]
>[/color]
Old 11-08-2006, 10:44 AM   #7 (permalink)
Ray O
Guest
Posts: n/a
> -Allen
>[/color]
On every car I've seen, the resistor pack that controls blower fan speed is
in or in front of the blower.
Ray O
[color=blue]
>> and the wiring.
>> Ray O
>>[/color]
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
My Electric Fan Mod is Complete! Pb 2nd Generation (2005+) 116 08-13-2009 11:34 PM
Heater Fan switch isktarum 1st & 2nd Generation (1983–1986 & 1987-1991) 6 09-25-2006 08:43 PM
1987 pickup heater fan resistor location? firestorm1 Pre-88 Toyota Pickup/Hilux 3 06-03-2006 03:27 PM
2006 RAV4 Features & Pricing [Canadian Spec] rolla-XRS Toyota News 19 01-03-2006 11:37 AM
