Aftermarket Alternator - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2006, 11:00 AM   #1 (permalink)
peanut28001
Guest
Posts: n/a
View peanut28001's Photo Gallery
I just purchased an aftermarket Stinger alternator for my 98 toyota 4
runner. It now installed however I still have to jump my truck off in
the mornings to get to work. Can someone please shed alittle light on
this subject for why I'm having this problem. I have a competition
style style car stereo in my truck.
Old 11-08-2006, 11:17 AM   #2 (permalink)
Mike Harris
Guest
Posts: n/a
View Mike Harris's Photo Gallery
Re: Aftermarket Alternator
"peanut28001" <peanut28001@yahoo.com> wrote in message
news:1163005250.073346.274660@h54g2000cwb.googlegroups.com...[color=blue]
> style style car stereo in my truck.[/color]
I can't give a course on automotive charging systems but assuming the
alternator was installed correctly and is charging the system, you either
have a battery that's not holding a charge or you have something draining
power when the ignition is off.
To check the first, a "quick and dirty" check is to measure the battery
voltage across the terminals (ignition off). If you're getting anything
less than 12.6 volts this might be an indication of a bad battery. To check
the second, disconnect the battery negative terminal when you get home; see
if the truck starts when you reconnect it in the morning. If so you can use
an ammeter and pull fuses to isolate the problem circuit.
Mike Harris
Austin TX
Old 11-08-2006, 11:19 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
>[/color]
You may get some guesses, but nobody can give you a definitive answer
without more information or looking at the truck itself. You should check
alternator output to see if it puts out at least 14 volts. If the battery
was left in a discharged state for too long or if the battery is more than 5
years old, then the battery may need replacement.
Other possible causes are loose cables/ground, corrosion on the battery
clamps, incorrect alternator, bad voltage regulator.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Big Alternator vs. Second Battery Corollacrazy42 Audio, Video, and Security - Tech 20 06-30-2006 09:57 PM
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 01:25 AM
Gen 2 Alternator jefe 1st & 2nd Generation (1983–1986 & 1987-1991) 8 01-27-2005 03:47 PM
extra battery 97avalonxls Audio, Video, and Security - Tech 9 09-20-2004 12:09 PM
AfterMarket Alternator grafix616 Camry & Solara Lounge 10 09-10-2002 09:00 PM
