Toyota Wiper Inserts for a 1990 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2006, 02:41 PM   #1 (permalink)
mike.siegel@gmail.com
Guest
Posts: n/a
View mike.siegel@gmail.com's Photo Gallery
I went in for inspection and they demanded I get new wiper blades. I
shrugged, figured they could use a change and let them put them on.
A week later when it actually rained, I tried to use my new wipers and
one fell off. Let me tell you this is alot of fun going 50 in the
rain.
Long story short, it looks like one arm is missing a part that connects
to the female end of the wiper arm, the part that holds the pin in.
The arm itself is intact, and I have the pin, it just slides right out
again. The other arm has one, it looks newish so I figure the must be
available after market.
So, where can I find one and what the heck is it called? (wiper
insert?)
Thanks,
-Mike
Old 11-09-2006, 05:27 PM   #2 (permalink)
Lee Richardson
Guest
Posts: n/a
View Lee Richardson's Photo Gallery
Re: Toyota Wiper Inserts for a 1990 Corolla
Find your receipt and take it back to the ones that botched the job and
demand that they fix it.
Lee Richardson
Mech-Tech
<mike.siegel@gmail.com> wrote in message
news:1163104890.969800.270180@e3g2000cwe.googlegroups.com...[color=blue]
> rain.
> insert?)
> Thanks,
> -Mike
>[/color]
Old 11-09-2006, 08:40 PM   #3 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
> rain.
> insert?)
> Thanks,
> -Mike
>[/color]
I'm assuming you're too far from the car dealer to make it worth going back
and making a loud obnoxious scene (which you should, because they tried to
kill you), at 8:00 AM when LOTS of people are dropping their cars off. If
this is correct, I'd call it a learning experience, and go buy your own new
set of wipers from an auto parts store. Anco and Trico wipers usually come
with a little packet of parts to help fit their products to different wiper
arms. Bring a few tools and try installing the blades in the parking lot. If
something's missing, go back into the store, and someone will probably give
you whatever you need to finish the job.
Don't EVER go back to the dealer whose mechanics tried to kill you. And,
save the extra parts from the wiper package. I have 20 years' worth of them.
They'll come in handy on a future car.
Old 11-10-2006, 06:31 AM   #4 (permalink)
Guest
Posts: n/a
Yeah, I'm trying to find a receipt. Honestly my first instinct is to
go yell at them but never let them touch my car again.
I bought a new pair of blades, it doesnt seem the blades are the
problem. Its the doo-hicky that attaches the blades to the arm. It
seems to be missing from one side (it holds the pin tight for a female
connection). From what I've been reading, generally it seems people
just replace the inserts in toyotas because actually replacing the
metal portion of the blade is bound to cause problems.
JoeSpareBedroom wrote:[color=blue]
> news:1163104890.969800.270180@e3g2000cwe.googlegroups.com...[color=green]
> > rain.
> > insert?)
> > Thanks,
> > -Mike
> >[/color]
> They'll come in handy on a future car.[/color]
Old 11-10-2006, 07:03 AM   #5 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
I've never had a problem replacing the whole metal portion. I don't do it
for any particular reason, except the fact that I rarely see just the blades
available.
The arms have a U-shaped bend at the end. Every set of wipers I've ever
bought has come with the necessary parts to match that shape. It's not
rocket science. However, dirt & salt can build up in there, making it a
bitch to take apart, especially with cold fingers. So, I spray some white
lithium grease on a Q-tip, and wipe all the mating surfaces with that stuff.
That makes future disassembly a little easier.
news:1163161899.852675.105030@m73g2000cwd.googlegroups.com...[color=blue]
> JoeSpareBedroom wrote:[color=green]
>> news:1163104890.969800.270180@e3g2000cwe.googlegroups.com...[color=darkred]
>> > rain.
>> > insert?)
>> > Thanks,
>> > -Mike
>> >[/color]
>> back
>> to
>> new
>> come
>> wiper
>> If
>> give
>> them.
>[/color]
Old 11-10-2006, 05:32 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
>[/color]
The problem is, the blades to not attach to the arm in an intuitive way. I
think I can do a brake job a lot faster than I can change wiper blades.
Changine inserts is a lot easier and cheaper.
Ray O
[color=blue]
>> > rain.
>> > insert?)
>> > Thanks,
>> > -Mike
>> >[/color]
>> back
>> to
>> new
>> come
>> wiper
>> If
>> give
>> them.
>[/color]
Old 11-11-2006, 07:55 AM   #7 (permalink)
---MIKE---
Guest
Posts: n/a
View ---MIKE---'s Photo Gallery
When I need new wipers, I go to VIP Auto (discount store). They send
someone out to put the new wiper blade in. It's easy for them because
they know what they are doing.
---MIKE---[color=blue][color=green]
>>In the White Mountains of New Hampshire
>> (44° 15' N - Elevation 1580')[/color][/color]
Old 11-11-2006, 08:51 AM   #8 (permalink)
Vash The Stampede
Guest
Posts: n/a
View Vash The Stampede's Photo Gallery
On Thu, 09 Nov 2006 12:41:31 -0800, mike.siegel wrote:
[color=blue]
> rain.
> insert?)
> Thanks,
> -Mike[/color]
If you get a decent wiper blade, like Bosch or Trico, they give you about
3 parts inside the bag to adapt the blade to your car. You remove the
screws, and then clip the new one directly on! It even has a hole so you
can screw it in if you wish. Did you get the absolutely cheapest ones you
could find?
And, changing inserts is a royal PITA. You can get then at AutoZone or
Wal*Mart. But you have my sympathy!
Pick up some Band-Aids while you're there, too!
Old 11-11-2006, 08:52 AM   #9 (permalink)
Vash The Stampede
Guest
Posts: n/a
On Fri, 10 Nov 2006 04:31:39 -0800, mike.siegel wrote:
[color=blue]
> metal portion of the blade is bound to cause problems.[/color]
Nah. Like I said, buy a good one. There will be a pice that clips or
screws onto the arm and fits the blade. Once you've put the clip on the
arm, new blades snap in and out.
[color=blue]
>> > rain.
>> > insert?)
>> > Thanks,
>> > -Mike
>> >[/color]
>> They'll come in handy on a future car.[/color][/color]
Old 11-11-2006, 01:14 PM   #10 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sat, 11 Nov 2006 08:55:34 -0500, [email]twinmountain@webtv.net[/email]
(---MIKE---) wrote:
[color=blue]
> ---MIKE---[color=green][color=darkred]
> >> (44° 15' N - Elevation 1580')[/color][/color][/color]
I think Toyota is getting away from the rubber inserts.
That was always fun (no two were done the same way).
Scott in Florida
BB code is Off
Smilies are Off
[IMG] code is Off
Discount on all TWM Toyota Short Shifters! TWM Performance General Discussion 0 05-19-2005 09:20 AM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Toyota Hits Record CDNVITZ General Discussion 0 02-06-2004 01:27 AM
