"FJ" <sec4251@remove the remove yahoo.com> wrote in message
news:g7n8l21be9q74ilge88llh54s13o4uiqkv@4ax.com...[color=blue]
> 'Filtermag work well with a 4 runner ?
> It is recommended by the folks who make the Royal Purple synthetic
> oil.
> There is a magnet for the transmission and another for the
> differential.
> If they do work well, any suggestions as to the large or small being
> more appropriate or the 4 runner (2006) transmission and differential?[/color]
In my opinion, a magnetic drain plug, and/or a magnet in the base of the
transmission is a good idea. I don't think the magnet on the engine oil
filter is particularly useful. I don't believe it will catch anything
important that the filter would not take care of. A lot of the stuff in your
oil that is damaging to your engine is not magnetic (silicon, carbon,
aluminum), so a filter magnet is not going to have any effect on those
contaminants. There will be some iron particles in the oil (mostly wear
debris from the rings and cylinder walls), but these particles are likely to
be blocked by the filter, if they ever leave the base pan. If you are
worried about iron particles in your engine oil, why not install a magnetic
drain plugs. With one of these, you'll be able to quickly see if you are
getting a lot of larger iron particles in the oil whenever you change your
oil.
In the case of a transmission, you are likely to get a lot more in the way
of iron "chunks." A magnet in the sump will retain these and prevent them
from going back through the transmission. I've had several automatic
transmissions that came from the factory with rather large magnets in the
transmission sump. There is a lot of steel on steel contact in a
transmission that can generate debris of a size that can be damaging.
Regards,
Ed White
[url]http://home.mindspring.com/~ed_white/[/url] - my automotive opinions
[url]http://home.mindspring.com/~ed_white/id7.html[/url] - my oil filter comparison
> oil.
> differential.
> [url]http://www.filtermag.com/products.php[/url][/color]
The transmission already has a magnet, and I think the diff does too.
On Fri, 10 Nov 2006 18:00:19 -0600, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:g7n8l21be9q74ilge88llh54s13o4uiqkv@4ax.com...[color=green]
>> oil.
>> differential.
>The transmission already has a magnet, and I think the diff does too.[/color]
Ray O and Ed, thanks,
Ray, does the existing transmission magnet need to be cleaned
periodically ? and can you tell me if it is internal or external (I
would assume internal)
(Maybee the Royal Purple synthetic folks make or have some ownership
in Filtermag and are pushing it ?) the Royal Purple synthetic folks
state that the oil filter mag will help prevent a catastrophic engine
destruction should a major engine malady come about...
Ed, I did look at your pages, and am impressed. I probably have missed
it, but what is your pick for best and second best air filter for (for
example) the 2006 4runner ?
news:gt8al21tttkiiooq2jlrmu0s7cqduikgfs@4ax.com...[color=blue]
>[color=green]
>>news:g7n8l21be9q74ilge88llh54s13o4uiqkv@4ax.com...[color=darkred]
>>> oil.
>>> differential.
> would assume internal)[/color]
The transmission fluid should be drained and refilled according to the
schedule in your owner's manual. Some people advocate removing the
transmission pan and changing the screen when the fluid is changed, but that
is not specified as periodic maintenance, and I don't bother with my own
vehicles. If you elect to remove the pan, the magnets are in the bottom of
the inside of the pan and can be cleaned off. I would not bother replacing
the screen; a cleaning should be sufficient.
[color=blue]
> destruction should a major engine malady come about...[/color]
The theory is good, however, if a part of the engine like the camshaft or
lifters fails catastrophically, I would still disassemble the engine to
inspect bearing surfaces. If you are changing your oil in accordance with
the manufacturer's maintenance schedule, the likelihood of a catastrophic
engine failure are pretty slim.
I always use Toyota oil filters and have not had a problem.
[color=blue]
> FJ
>[/color]
Your best bet for an air filter is the OEM filter. "High performance"
filters like I&NO are made to pass a greater volume of air, and in order to
achieve the greater volume, it has to trap fewer particles. This results in
more rapid engine wear and oil contamination, which a filter magi will not
trap. If you are looking for longevity, stick to OEM.
On Fri, 10 Nov 2006 22:13:13 -0600, "Ray O"
[color=blue]
>news:gt8al21tttkiiooq2jlrmu0s7cqduikgfs@4ax.com...[color=green]
>>[color=darkred]
>>>> oil.
>>>> differential.
>[color=green]
>[color=green]
>> FJ
>>[/color]
>trap. If you are looking for longevity, stick to OEM.[/color]
Thanks, Ray. I appreciate the response. With 4 million Toyota's sold
last year, Toyota should likely have figured out the best air filter
for the purpose. I will be using synthetic and a comparable oil filter
for synthetic.
If the magnets had that kind of value on the oil filters, it would not
be expensive to add them to all Toyotas and other makes.
news:g13el2doe9lk8u73nd601ernr6s3vp28d2@4ax.com...[color=blue]
>[color=green]
>>news:gt8al21tttkiiooq2jlrmu0s7cqduikgfs@4ax.com...[color=darkred]
>>>>> oil.
>>>>> differential.
>>that
>>of
>>replacing
>>[color=darkred]
>>[color=darkred]
>>> FJ
>>>[/color]
>>to
>>in
> for synthetic.
> this page is what I was looking at, originally:
> [url]http://www.royalpurple.com/sport_truck/sport_truck.html[/url]
> thanks,
> FJ
>[/color]
IMO, Toyota brand oil filters are reasonably priced, about the same as a
mid-grade aftermarket filter. If you have a V6 and want a little more
capacity, try the Toyota OEM filter for the V8, if the same filters are not
specified.
When I searched around to see what you were talking about, I happened across
the same page.
If you decide to use synthetic, note that the owner's manual and faq pages
on Toyota's web site recommend that you do not increase the oil change
interval.
On Sun, 12 Nov 2006 16:05:33 -0600, "Ray O"
[color=blue]
>news:g13el2doe9lk8u73nd601ernr6s3vp28d2@4ax.com...[color=green]
>>[color=darkred]
>>>>>> oil.
>>>>>> differential.
>>>that
>>>of
>>>replacing
>>>> FJ
>>>to
>>>in
>> for synthetic.
>> thanks,
>> FJ
>>[/color]
>specified.
>the same page.
>interval.[/color]
Thanks again, Ray. the last paragraph has me intrigued. I don't really
mind the higher cost of the synthetic, and don't mind changing it at
5k, which is the US 4runner manual interval.
But the vaunted calling card of synthetic is much longer intervals
between changes.
If there a factor beyond the usual assumptions as to the value of the
5K changes in synthetic oil (such as Mobil 1 or Royal Purple), such as
other components which would not do well without 5K changes, I am
indeed interested.
news:adtil29icqblj9c123u73rrkgf71ebsqja@4ax.com...[color=blue]
>[color=green]
>>news:g13el2doe9lk8u73nd601ernr6s3vp28d2@4ax.com...[color=darkred]
>>>>>>> oil.
>>>>>>> differential.
>>>>>>> differential?
>>>>that
>>>>of
>>>>replacing
>>>>or
>>>>with
>>>>catastrophic
>>>>> FJ
>>>>to
>>>>results
>>>>in
>>>>not
>>> for synthetic.
>>> thanks,
>>> FJ
>>>[/color]
>>not
>>specified.
>>across
>>the same page.
>>interval.[/color]
> between changes.
> indeed interested.
>[/color]
I am not a specialist in the properties of oil. You will get a lot of
people speculating and guessing this and that, but most of it is
speculation.
I will give the same advice I used to give customers who asked me about
extended oil change intervals: If you want the automaker to warrant the car
if something goes wrong, follow the automaker's maintenance requirements and
recommendations. If you want the oil company to warrant the engine, go
ahead and follow the oil company or oil filter maker's recommendations. By
the way, in 15 years of working for an automaker, I have seen oil companies
and oil filter companies pay for exactly 0 engine repairs or replacements.
On Tue, 14 Nov 2006 15:08:09 -0600, "Ray O"
[color=blue]
>news:adtil29icqblj9c123u73rrkgf71ebsqja@4ax.com...[color=green]
>>[color=darkred]
>>>>>>>> oil.
>>>>>>>> differential.
>>>>>>>> differential?
>>>>>that
>>>>>of
>>>>>replacing
>>>>>or
>>>>>with
>>>>>catastrophic
>>>>>> FJ
>>>>>to
>>>>>results
>>>>>in
>>>>>not
>>>> for synthetic.
>>>> thanks,
>>>> FJ
>>>not
>>>specified.
>>>across
>>>the same page.
>>>interval.[/color]
>> between changes.
>> indeed interested.
>>[/color]
>speculation.
>and oil filter companies pay for exactly 0 engine repairs or replacements.[/color]
Hi Ray,
-Never intended to rile you up. It was a purely mechanical question.
You have much more experience with mechanics than I and I wondered if
there was a factor that I was missing. The warranty value is enough
for me.
Best wishes,
FJ
PS - any idea where the physical location of the thermometer (not
thermostat) is in the 4runner ? It must be reading the air, as the
temperature on the dashboard readout drops when getting going on the
freeway. It would unlikely be a surface reading thermometer...
news:v4ell2l44uods5i664j9c8f8b43cttmlb2@4ax.com...[color=blue]
>[color=green]
>>news:adtil29icqblj9c123u73rrkgf71ebsqja@4ax.com...[color=darkred]
>>>>>>>>> oil.
>>>>>>>>> differential.
>>>>>>>>> being
>>>>>>>>> differential?
>>>>>>>>too.
>>>>>>but
>>>>>>that
>>>>>>own
>>>>>>bottom
>>>>>>of
>>>>>>replacing
>>>>>>> engine
>>>>>>or
>>>>>>to
>>>>>>with
>>>>>>catastrophic
>>>>>>> missed
>>>>>>> (for
>>>>>>> FJ
>>>>>>order
>>>>>>to
>>>>>>results
>>>>>>in
>>>>>>not
>>>>> for synthetic.
>>>>> thanks,
>>>>> FJ
>>>>not
>>>>specified.
>>>>across
>>>>the same page.
>>>>pages
>>>>interval.
>>> between changes.
>>> indeed interested.
>>>[/color]
>>speculation.
>>car
>>and
>>By
>>companies
> Hi Ray,
> for me.
> Best wishes,
> FJ[/color]
No problem, I was not riled up, just trying to present an additional logical
reason to choose OEM over aftermarket filters. I am not saying that an
aftermarket filter maker will not cover damage caused by their filters, just
that I have not heard of a case where they did.
[color=blue]
>[/color]
The exterior ambient air sensors on Toyotas are usually located under the
bumper, in front of the radiator. IIRC, it looks like a mini-horn.
