"C. E. White" <cewhite3@removemindspring.com> wrote in message
news:455b289f@kcnews01...[color=blue]
> "Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
> news:d182e$455a3405$44a4a10d$14214@msgid.meganewsservers.com...[color=green]
>> "Herbert" <h.m.mueller2901@t-online.de> wrote in message
>> news:1163536420.771295.198400@e3g2000cwe.googlegroups.com...[color=darkred]
>>> Andrew Stephenson schrieb:
>>>> In article <1163394112.356049.170180@m7g2000cwm.googlegroups.com>
>>>> [email]h.m.mueller2901@t-online.de[/email] "Herbert" writes:
>>>> > does anyone have experience with unbalanced tires driving the
>>>> > Prius at about 100 km/h? [...]
>>>> If a tyre was unbalanced, at 100 Km/h wouldn't it produce a shake
>>>> that could be felt through the car body as a whole, especially on
>>>> a good road? The Prius is generally smooth-running, although its
>>>> suspension is quite firm, more EUian (and JPian?) than USian, and
>>>> might let you feel such movements. (
AFAIK, the trade-off benefit
>>>> of firmer suspension is better road-holding. Have we an expert?)
>>>> Andrew Stephenson
>>> Hello Andrew
>>> my question is when you have an unbalanced tire if one can feel it at
>>> the steering wheel, since Prius has no mechanical contact with the
>>> wheels, the Prius (and some other Toyota cars) use "steering by wire",
>>> e.g. the steering wheel sensor drives an electric motor, hence there is
>>> no mechanical contact to the front wheels.
>>>[/color]
>> I am pretty sure that Toyota does not currently produce any "steer by
>> wire" vehicles.
>> Note that "steer by wire" means that there is no mechanical connection
>> between the steering wheel and the steering rack, which is connected to
>> the front wheels.
>> Electric power steering (which the Prius and the 2007 LS 470 have) means
>> that the power steering pump is driven by an electric motor, not a
>> belt-driven pulley,[/color]
> Does the Prius have a hydraulic pump? I used to own a Saturn Vue that had
> "electric" power steering. There was no hydraulic pump. An electric motor
> was connected directly to the sterring shaft and provided the assist. I
> assume this is what the Prius does as well, but since I have not actually
> wokred on a Prius, I can't be sure. The electric power sterring in the Vue
> was mostly devoid of feel, but I got used to it. It wasn't nearly as dead
> feeling as the power steering from a early 70's Chrysler product.[/color]
Good question, I do not know how the power steering in a Prius works. I had
assumed, perhaps incorrectly, that it had a hydraulic pump that was driven
by an electric motor, like the MR2 had. Perhaps someone with a Prius can
ansewer?
[color=blue]
>[color=green]
>> but there is still a steering shaft connecting the steering wheel to the
>> steering rack. In the the Prius and 2007 LS, the steering wheel is
>> connected to a steering shaft which is connected to a steering rack which
>> is connected to the rack ends, which are connected to the front wheels.[/color]
> My Saturn Vue was this way as well. It still had a conventional rack and
> pinion steering system, the "electric" part was just an assist. This is
> not a true fly by wire system. I do have three farm tractors that have
> "fly by hydraulic" sterring systems. There is no mechnical link between
> the steering wheel and the front wheels. The front wheels are moved solely
> by hydraulic cylinders that are activated by steering wheel movement.
> Regards,
>[/color]
The hydraulic steering systems sound like the setup that some larger
forklifts have, where the hydrostatic drive pump also provides steering and
other duties.
Ray O
