antenna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2006, 01:21 AM   #1 (permalink)
Ralph
Guest
Posts: n/a
View Ralph's Photo Gallery
antenna
Is it possible to replace the steel part of the Corolla radio antenna
without removing the wiring?
I have a good used antenna. When removing it at the wreckers I had to
disassemble most of the scrap car's dash, in order to un-thread and take out
the wiring. If I could separate the steel rod ftom the plastic mounting
block (at the pilar) I would save a lot of installation work.
Your expert comments are invited,
- Jack
Old 11-14-2006, 02:52 PM   #2 (permalink)
Vash The Stampede
Guest
Posts: n/a
View Vash The Stampede's Photo Gallery
Re: antenna
On Tue, 14 Nov 2006 02:21:09 -0500, Ralph wrote:
[color=blue]
> - Jack[/color]
You don't mention what's broken or missing on your car. The mast itself
unscrews from the base. It sounds like you need the other part.
You also don't mention what year or model (even though it's a "Corolla",
there were different models in the 80's and 90's). Is it a Roof mount
antenna, a pillar mount, or a fender mount? Makes a difference. The worst
part is making sure the antenna is grounded properly; if it's not, FM
range won't be very far, and AM will suck (worse than it does!)
Old 11-14-2006, 02:58 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: antenna
"Ralph" <nospam@thanks.com> wrote in message
news:45596e70_2@news.cybersurf.net...[color=blue]
> without removing the wiring?[/color]
Assuming that the "steel part" of the antenna you are referring to is the
antenna mast and the "wiring" is the coaxial cable and assuming that you
have the antenna that is mounted in the A-pillar, then you should be able to
change the mast and coaxial cable without having to disassemble most of the
dashboard. Unplug the RCA connection of the old antenna from the back of
the radio, securely fasten some string to the end of the old coax with many
winds of tape, then pull the old mast and coax out. When the string shows
up where the mast is mounted, attach the string to the replacement antenna
coax and pull the string to get the coax back to the back of the radio.
Depending on what year and model, the job should not take more than 10 ~ 15
minutes.
Your other alternative is to cut the coax and put connectors on the coax.
You will have to get male and female connectors, and IMO, that connection
may degrade the signal from the antenna as well as possibly causing rattles.
Ray O
Old 11-14-2006, 11:53 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
Re: antenna
news:455aa508_1@news.cybersurf.net...[color=blue]
> Thanks for your replies.
> Yes, it's the mast that snapped. The Corolla is a 1992 LE and the antenna
> is in the front driver's pillar.
> The coax on the 'donor' wreck was routed high up and toward the cowl,
> under the dash. After I unplugged it from the radio, it would not pull
> free. As I incrementally removed more and more of the dash at the
> wreckers, feesding the coax along, it was still sticking right up to the
> point where it was finally disappearing into the base of the pillar (in
> the driver's foot well area).
> I am worried that I will need to take apart my whole car to replace this!
> I am going to attempt the string trick Ray O. Perhaps as a 'fish' I will
> use some re-bar wire I have here, which won't cut itself on steel corners.
> Reception is so bad now it won't make any difference.
> This is why people use coathangers!!
> I wish that I couyld just slide a new mast into the plastic mount at the
> pillar.
> Thanks again,
> Jack[/color]
You're welcome and good luck! BTW, when you tape the string to the coax, be
generous with electrical tape on the junction so that it doesn't snag.
Ray O
Old 11-15-2006, 04:51 PM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: antenna
On Wed, 15 Nov 2006 00:26:17 -0500, Ralph wrote:
[color=blue]
> The coax on the 'donor' wreck was routed high up and toward the cowl, under
> the dash. After I unplugged it from the radio, it would not pull free. As
> I incrementally removed more and more of the dash at the wreckers, feesding
> the coax along, it was still sticking right up to the point where it was
> finally disappearing into the base of the pillar (in the driver's foot well
> area).
> I am worried that I will need to take apart my whole car to replace this! I
> am going to attempt the string trick Ray O. Perhaps as a 'fish' I will use
> pillar.
> Thanks again,
> Jack[/color]
Have you pulled the old one out of your car yet?!?!
If not, get a piece of wire or, pull the old antenna out of the pliiar,
and cut the wire. Get some GOOD electrical tape and tape the end of the
new antenna to the cut end of the old antenna. GENTLY!!! pull the old wire
from inside the car, making sure not to detach the new wire from the old
one. It should pull right through. You may want to wrap a wire from the
old one to the new one and then join it together with electrical tape.
It wull bind at some point, but just keep pulling GENTLY and it will pull
through.
Use a star washer on the screws of the new antenna, or it won't ground
properly.
BB code is Off
Smilies are Off
[IMG] code is Off
Original Wires for Factory Power Antenna... JayMax03 Audio, Video, and Security - Tech 3 06-22-2006 01:02 AM
Can't get stations... Antenna help!! nat77 Camry & Solara Lounge 10 05-17-2005 10:24 PM
S2000 Antenna Conversion funboy102 Camry & Solara Lounge 18 01-22-2005 02:12 PM
S2000 Antenna HELP! phat555 Camry & Solara Lounge 25 01-25-2002 07:00 PM
