Re: How to Test Backup Switch?
"O.B." <funkjunk@bellsouth.net> wrote in message
news:12lp4v04kqupo5b@corp.supernews.com...[color=blue]
> For a 1982 Tercel with a manual transmission, the backup lights are not
> working. The bulbs are in working condition, but they are getting no
> juice when backing up. I recently had the clutch rebuilt by an automotive
> shop. So I verified that the connection to the backup switch in the
> transmission was still intact. My next guess is to test the switch. It
> has two wires.
> How do I go about testing the backup switch?[/color]
Unplug the wires from the backup switch, put the transmission in reverse,
and with an ohm meter or continuity tester, check for continuity between the
two terminals on the switch.
If you have a 12 volt tester, then with the ignition on but the engine off
and the transmission in reverse, check for 12 volts going into and out of
the switch.
Ray O
