Ray O wrote:
(without checking the manual - from someone who only works on their own
vehicle))[color=blue]
> ABS - antilock braking system
> ATF - automatic transmission fluid
> BVSV - bimetal vacuum switching valve
> CO - carbon monoxide
> CO2 - carbon dioxide
> ECM - electronic control module
> ECT - electronically controlled transmission
> EFI - electronic fuel injection
> EGR - exhaust gas recirculation
> ESA
> HC - hydrocarbon
> LF - left front
> LH - left hand
> LR - left rear
> MAF - mass air flow
> MAP - manifold absolute pressure
> NAP
> NOx - nitrous oxide
> NUMMI - new united motor manufacturing inc.
> OBD II - on board diagnostics version 2
> OD - overdrive
> PDC - I know PDQ
> POE
> RF - right front
> RH - right hand
> RR - right rear
> SADS
> SRS - supplemental restraint system
> SSM
> SST - special service tool
> TMC - Toyota motor corporation
> TMCC
> TMD
> TMIS
> TMS
> TSB - technical service bulletin
> TVIS (air bag related?)
> TVSV - thermal vacuum switching valve
> VSV - vacuum switching valve
> VVT - variable valve timing
> VVT-i - variable valve timing with intelligence
> Bonus: in which Toyota vehicle(s) did EFI first appear in the U.S and in
> what model year? - All I can tell you is my 1977 truck doesn't have it, and the '94 Camry does.[/color]
"Ray O" <rokigawaATtristarassociatesDOTcom> wrote in message
news:19d25$455cca6e$44a4a10d$5887@msgid.meganewsservers.com...[color=blue]
> ABS Anti-lock braking system
> ATF um... After The Fire - wait Toyotas don't catch fire
> BVSV ?
> CO Carbon Monoxide...
> CO2 Carbon Dioxide...
> ECM Electronic Controlled Maintenance?
> ECT Electronically Controlled Transmission (Our FX 16 had that :-))
> EFI ?
> EGR ?
> ESA ?
> HC Hatch Coupe?
> LF ?
> LH ?
> LR ?
> MAF ?
> MAP Something my husband uses.
> NAP Something I treasure
> NOx Nitrous Oxide...something LOL
> NUMMI ?
> OBD II ?
> OD Olive Drab ;-)
> PDC ?
> POE Morbid poet
> RF Right Front?
> RH ?
> RR Right Rear?
> SADS ?
> SRS Supplemental Restraint System (Airbags?)
> SSM ?
> SST Something Turbo?
> TMC The Movie Channel :)
> TMCC ?
> TMD Toyota of Mass Destruction? LOL
> TMIS Too Much Information, Scott
> TMS ?
> TSB ?
> TVIS ?
> TVSV ?
> VSV?
> VVT Variable Valve Timing
> VVT-i Variable Valve Timing with Intelligence (Echo and Scion xA owner
> here..)
> what model year?
>[/color]
As if...
Natalie, flunking yet another standardized test...
<nospampls2002@yahoo.com> wrote in message
news:1163716734.990645.305990@m7g2000cwm.googlegroups.com...[color=blue]
> vehicle))[color=green]
>> ESA
>> HC - hydrocarbon
>> LF - left front
>> LH - left hand
>> LR - left rear
>> MAF - mass air flow
>> NAP
>> NOx - nitrous oxide
>> OD - overdrive
>> PDC - I know PDQ
>> POE
>> RF - right front
>> RH - right hand
>> RR - right rear
>> SADS
>> SSM
>> TMCC
>> TMD
>> TMIS
>> TMS
>> VVT-i - variable valve timing with intelligence[/color][/color]
I'm impressed, of the answers provided, on 2 are incorrect. NOx is oxides
of nitrogen,which is not the same as nitrous oxide. TVIS is Toyota variable
induction system.
For someone who doesn't look at that stuff every[color=blue][color=green]
>> and the '94 Camry does.[/color][/color]
"Wickeddoll®" <wickeddoll1958diespammersdie@yahoo.com> wrote in message
news:eji7lo.gk.1@news.evilcabal.org...[color=blue]
> news:19d25$455cca6e$44a4a10d$5887@msgid.meganewsservers.com...[color=green]
>> ATF um... After The Fire - wait Toyotas don't catch fire[/color][/color]
** electronic control module**
>> EFI ?
>> EGR ?
>> ESA ?
>> HC Hatch Coupe?[/color][/color]
** hydrocarbons**[color=blue][color=green]
>> LF ?
>> LH ?
>> LR ?
>> MAF ?
>> NOx Nitrous Oxide...something LOL[/color][/color]
**close, oxides of nitrogen - don't ask me why it is nott OxN instead of
NOx**
>> NUMMI ?
>> OBD II ?
>> OD Olive Drab ;-)
>> PDC ?
>> POE Morbid poet
>> RF Right Front?
>> RH ?
>> RR Right Rear?
>> SADS ?
>> SSM ?
>> SST Something Turbo?[/color][/color]
**special service tool**
>> TMCC ?
>> TMD Toyota of Mass Destruction? LOL[/color][/color]
** come to think of it, that describes a former co-worker!**[color=blue][color=green]
>> TMS ?
>> TSB ?
>> TVIS ?
>> TVSV ?
>> VSV?
>> here..)
>> what model year?
>>[/color]
> As if...
> Natalie, flunking yet another standardized test...[/color]
Not a standardized test, more a memory check for Ray ;-)
I must admit, some of your answers are better than the real ones!
news:aa8cb$455ceed1$44a4a10d$10238@msgid.meganewsservers.com...[color=blue]
> news:eji7lo.gk.1@news.evilcabal.org...[color=green]
>> news:19d25$455cca6e$44a4a10d$5887@msgid.meganewsservers.com...[color=darkred]
> **Hint: Automatic Transmission Fl_ _ _**[/color]
Yeah, the other person said that...[color=blue]
>[color=green][color=darkred]
>>> BVSV ?
>>> ECM Electronic Controlled Maintenance?[/color][/color]
> ** electronic control module**[/color]
I was close![color=blue]
>>> EFI ?
>>> EGR ?
>>> ESA ?
> ** hydrocarbons**[/color]
I like mine better :)[color=blue][color=green][color=darkred]
>>> LF ?
>>> LH ?
>>> LR ?
>>> MAF ?
> NOx**
>[/color]
SCIENTISTS! :-)
>>> NUMMI ?
>>> OBD II ?
>>> OD Olive Drab ;-)
>>> PDC ?
>>> POE Morbid poet
>>> RF Right Front?
>>> RH ?
>>> RR Right Rear?
>>> SADS ?
>>> SSM ?
> **special service tool**[/color]
Such as...?[color=blue]
>>> TMCC ?
> ** come to think of it, that describes a former co-worker!**[/color]
Or my son - just insert any car make/model!
>>> TMS ?
>>> TSB ?
>>> TVIS ?
>>> TVSV ?
>>> VSV?
>>> here..)
>>> what model year?
>>>[/color]
>> As if...
> Not a standardized test, more a memory check for Ray ;-)[/color]
Hey no fair making us help you![color=blue]
> Ray O[/color]
news:ejiat8.11k.1@news.evilcabal.org...[color=blue]
>[/color]
<snipped[color=blue][color=green][color=darkred]
> I was close![/color]
I would give you credit but my sophmore year geometry teacher wouldn't,
because he used to say that a bridge doesn't almost stay up <g>
>>[color=darkred]
>>>> EFI ?
>>>> EGR ?
>>>> ESA ?
> I like mine better :)[/color]
Actually, so do I!
<more snippage>
> Such as...?[color=green]
>>[/color][/color]
An OBD II scan tool or W55 transmission 5th gear puller. The cleverest tool
I saw was an oil pan FIPG (freebie - formed-in-place gasket) seal cutter
>>>> TMCC ?
> Or my son - just insert any car make/model![/color]
Or any teen behind the wheel!
<snipped>
> Hey no fair making us help you![/color]
I cheated and only posted the ones I remembered.
>> Ray O[/color]
> *curtsey*
> Natalie[/color]
If you survived the acronym-laden verbiage in the U.S. military, this stuff
should be a piece of cake!
news:e8b0e$455d07a6$44a4a10d$13832@msgid.meganewsservers.com...[color=blue]
> news:ejiat8.11k.1@news.evilcabal.org...[color=green]
>>[/color]
> <snipped[color=green][color=darkred]
> because he used to say that a bridge doesn't almost stay up <g>[/color]
I don't have a brain for numbers, anyway - I'm an English nerd[color=blue]
> <more snippage>
>> Such as...?[color=darkred]
>>>[/color][/color]
> tool I saw was an oil pan FIPG (freebie - formed-in-place gasket) seal
> cutter[/color]
You may as well be speaking Turkish.[color=blue]
>>>>> TMCC ?
>[/color]
Amen!
[color=blue]
> <snipped>
> I cheated and only posted the ones I remembered.[/color]
You mean there are more?! *gasp*[color=blue]
>>> Ray O[/color]
>> *curtsey*
>> Natalie[/color]
> stuff should be a piece of cake!
> Ray O[/color]
Heh - and what's scary is I *still* remember them when hubby speaks "Air
Force"
On Thu, 16 Nov 2006 14:30:35 -0600, Ray O wrote:
[color=blue]
> ABS[/color]
Anti-Lock Braking System[color=blue]
> ATF[/color]
Automatic Tranny Sauce[color=blue]
> BVSV[/color]
BiMetal Vacuum Switching Valve[color=blue]
> CO[/color]
Monoxide[color=blue]
> CO2[/color]
Dioxide[color=blue]
> ECM[/color]
Electronic Control Module[color=blue]
> ECT[/color]
Electronically Controlled Tranny[color=blue]
> EFI[/color]
Elctronic Fool Injection[color=blue]
> EGR[/color]
Exhaust Gas Recirculator[color=blue]
> ESA[/color]
That's ESA for YOU to say![color=blue]
> HC[/color]
Hydrocarbon[color=blue]
> LF[/color]
Left Front[color=blue]
> LH[/color]
Left hand[color=blue]
> LR[/color]
Left Rear[color=blue]
> MAF[/color]
Mas Airflow Sensor[color=blue]
> MAP[/color]
Mass Airflow 'Puter...?[color=blue]
> NAP[/color]
Something I needed desparately this afternoon![color=blue]
> NOx[/color]
Tee Hee Hee!!!![color=blue]
> NUMMI[/color]
How you feel after huffing NOx!!
(Or, a place in California that does a horrible job of trying to build
Toyotas!)[color=blue]
> OBD II[/color]
On Board Diags, V.2[color=blue]
> OD[/color]
....and man alive, I shifted on down into OverDrive![color=blue]
> PDC[/color]
Where Ray goes if he doesn't pay a Parking Ticket?[color=blue]
> POE[/color]
Port of Entry[color=blue]
> RF[/color]
Right Front[color=blue]
> RH[/color]
Right Hand[color=blue]
> RR[/color]
Right Rear[color=blue]
> SADS[/color]
How I felt after being Laid-Off.[color=blue]
> SRS[/color]
Something you hope you never have to meet Face to "Face".[color=blue]
> SSM[/color]
Special Service Module[color=blue]
> SST[/color]
SS Tool[color=blue]
> TMC[/color]
Toy Motor (T3q)[color=blue]
> TMCC[/color]
Somebody I owe a LOT of money to right now![color=blue]
> TMD[/color]
I have NO idea![color=blue]
> TMIS[/color]
I don't know! Somekind of Timing/Induction system?[color=blue]
> TMS[/color]
What men get once a month[color=blue]
> TSB[/color]
Tech Svc Bull[color=blue]
> TVIS[/color]
Tiy Variable Induction System (The heart of the 4A-GE)[color=blue]
> TVSV[/color]
?[color=blue]
> VSV[/color]
> VVT[/color]
Variable Valve timing[color=blue]
> VVT-i[/color]
Injected[color=blue]
> what model year?[/color]
I would guess the 1968 2000GT...
On Thu, 16 Nov 2006 17:04:50 -0600, Ray O wrote:
[color=blue]
>>> BVSV ?
>>> EFI ?
>>> EGR ?
>>> ESA ?
>>> HC Hatch Coupe?[/color][/color][/color]
AHEM! That's "Hachi" coupe! ;)
[color=blue]
> ** hydrocarbons**[color=green][color=darkred]
>>> LF ?
>>> LH ?
>>> LR ?
>>> MAF ?
> NOx**
>>> NUMMI ?
>>> OBD II ?
>>> OD Olive Drab ;-)
>>> PDC ?
>>> POE Morbid poet[/color][/color][/color]
Nevermore!
>>> RF Right Front?
>>> RH ?
>>> RR Right Rear?
>>> SADS ?
>>> SSM ?
>>> TMCC ?
> ** come to think of it, that describes a former co-worker!**[color=green][color=darkred]
>>> TMIS Too Much Information, Scott[/color][/color][/color]
BWAHAHAHAHA!!!
>>> TMS ?
>>> TSB ?
>>> TVIS ?
>>> TVSV ?
>>> VSV?
>>> here..)
>>> what model year?
>>>[/color]
>> As if...
> I must admit, some of your answers are better than the real ones![/color]
On Thu, 16 Nov 2006 20:03:54 -0500, Wickeddoll® wrote:
[color=blue]
> news:e8b0e$455d07a6$44a4a10d$13832@msgid.meganewsservers.com...[color=green]
>> news:ejiat8.11k.1@news.evilcabal.org...[color=darkred]
>>>[/color]
>> <snipped[color=darkred]
> I don't have a brain for numbers, anyway - I'm an English nerd[color=green]
>> <more snippage>
>>[color=darkred]
>>> Such as...?
>>>>[/color]
>> cutter[/color]
> You may as well be speaking Turkish.[/color]
Um, RTV? Gasket Goo?
>>[color=darkred]
>>>>>> TMCC ?
>>[/color]
> Amen!
>[color=green]
>> <snipped>
>>[color=darkred]
> You mean there are more?! *gasp*[color=green]
>>[color=darkred]
>>>> Ray O
>>> *curtsey*
>>> Natalie[/color]
>> Ray O[/color]
> Force"
> Natalie[/color]
On Thu, 16 Nov 2006 16:59:30 -0600, Ray O wrote:
[color=blue]
> news:1163716734.990645.305990@m7g2000cwm.googlegroups.com...[color=green]
>> vehicle))[color=darkred]
>>> ESA
>>> HC - hydrocarbon
>>> LF - left front
>>> LH - left hand
>>> LR - left rear
>>> MAF - mass air flow
>>> NAP
>>> NOx - nitrous oxide
>>> OD - overdrive
>>> PDC - I know PDQ
>>> POE
>>> RF - right front
>>> RH - right hand
>>> RR - right rear
>>> SADS
>>> SSM
>>> TMCC
>>> TMD
>>> TMIS
>>> TMS
> induction system.
> For someone who doesn't look at that stuff every[color=green][color=darkred]
> You are in the correct range![/color]
> news:ejiat8.11k.1@news.evilcabal.org...[/color]
<snipped>[color=blue][color=green][color=darkred]
>>> Ray O[/color]
>> *curtsey*
>> Natalie[/color]
> stuff should be a piece of cake![/color]
I was thinking the same thing, only about teaching: TST, CST, CSE, NYSTRS,
NYSTA (obsolete), NYSUT, AFT, NEA, IEP, 504, AIS, PEP (obsolete), BOCES, PTA
or PTO, AD/HD, ESL, LD, OHI, PSAT, SAT, GED, OT, PT, NCLB, PDD.... and on &
on... They just keep multiplying.
Cathy
[color=blue]
> Ray O
> (correct punctuation to reply)
>[/color]
> ABS[/color]
Antilock Braking System
[color=blue]
> ATF[/color]
Automatic Transmission Fluid
[color=blue]
> BVSV
> CO[/color]
Carbon Monoxide
[color=blue]
> CO2[/color]
Carbon Dioxide
[color=blue]
> ECM[/color]
[color=blue]
> ECT[/color]
Electronic Controlled Transmission
[color=blue]
> EFI[/color]
Electronic Fuel Injection
[color=blue]
> EGR[/color]
Exhaust Gas Recirculation (valve)
[color=blue]
> ESA
> HC[/color]
Hydro Carbon
[color=blue]
> LF[/color]
Left Front
[color=blue]
> LH[/color]
Left hand
[color=blue]
> LR[/color]
Left Rear
[color=blue]
> MAF[/color]
Mass Air Flow
[color=blue]
> MAP[/color]
Mass Air Pressure
[color=blue]
> NAP
> NOx
> NUMMI
> OBD II[/color]
On Board Diagnostics, Level 2
[color=blue]
> OD[/color]
Over Drive
[color=blue]
> PDC
> POE[/color]
Port of Entry
[color=blue]
> RF[/color]
Right Front
[color=blue]
> RH[/color]
Right Hand
[color=blue]
> RR[/color]
Right Rear
[color=blue]
> SADS
> SRS[/color]
Suplemental Restraint System
[color=blue]
> SSM
> SST
> TMC[/color]
Toyota Motor Company
[color=blue]
> TMCC[/color]
Toyota Motor Credit Corporation
[color=blue]
> TMD
> TMIS
> TMS
> TSB[/color]
Technical Service Bulletin
[color=blue]
> TVIS
> TVSV
> VSV
> VVT[/color]
[color=blue]
> VVT-i[/color]
Another version of Variable Valve Timing
[color=blue]
My fuzzy recollection is that EFI came to us on the truck line first. It
seems to me that it came in the mid-80s.
