Re: Programming a Toyota Standard key remote - ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2006, 11:38 PM   #1 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Joe Lauton" <JL@Lauton2000.com> wrote in message
news:m1ksl2941i147ghnrb0ikal38u4c5db4t7@4ax.com...[color=blue]
> What is the procedure (if any) for changing the battery in a Sienna
> remote when NO optional engine disable or security system is present?
> Can the battery be removed for an extended period of time without all
> that programming described here a couple of weeks ago?
> jl[/color]
From the keyfob, yes, from the vehicle, no (I think)
Ray O
Old 11-18-2006, 12:34 PM   #2 (permalink)
Joe Lauton
Guest
Posts: n/a
View Joe Lauton's Photo Gallery
On Fri, 17 Nov 2006 23:38:49 -0600, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:m1ksl2941i147ghnrb0ikal38u4c5db4t7@4ax.com...[color=green]
>> jl[/color]
>From the keyfob, yes, from the vehicle, no (I think)[/color]
So I understand that the key battery can be removed and replaced any
time without having to reset anything?
Re car battery - will the car typically hold the memory ok if one took
say 5-10 min to install a new battery?
The manual says nothing except to 'normalize' the power window by
rolling a window down half way and then close it and hold the button
for a second.
jl
Old 11-18-2006, 07:17 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
news:l4kul2p6re6ipnrho5pls1uikq109mgl43@4ax.com...[color=blue]
>[color=green]
>>news:m1ksl2941i147ghnrb0ikal38u4c5db4t7@4ax.com...[color=darkred]
>>> jl[/color]
> time without having to reset anything?[/color]
Yes.[color=blue]
>[/color]
For the remote unlocking system, 5-10 minutes should be quick enough to
change the car battery, however, the radio, clock, and powertrain ECM will
lose memory. If you are going for an emissions test soon, the ECM will have
to be put into the ready state by driving 2 trip cycles.
[color=blue]
> for a second.
> jl[/color]
Ray O
Old 11-18-2006, 07:52 PM   #4 (permalink)
Joe Lauton
Guest
Posts: n/a
On Sat, 18 Nov 2006 19:17:00 -0600, "Ray O"
[color=blue]
>news:l4kul2p6re6ipnrho5pls1uikq109mgl43@4ax.com...[color=green]
>>[color=darkred]
>>>> jl
>Yes.[color=green]
>>[/color]
>lose memory.[/color]
What does that (no ECM) do to driving ability????
If you are going for an emissions test soon, the ECM will have[color=blue]
>[/color]
How do you define two trip cycles? Start the wreck twice???
jl
[color=blue][color=green]
>> for a second.
>> jl[/color][/color]
Old 11-18-2006, 09:00 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:p0evl2h5a1u9q9qkoge8fbjhmdfl39rbbl@4ax.com...[color=blue]
>[color=green]
>>news:l4kul2p6re6ipnrho5pls1uikq109mgl43@4ax.com...[color=darkred]
>>>>> jl
>>Yes.[color=darkred]
>>>[/color]
> What does that (no ECM) do to driving ability????[/color]
Nothing.
[color=blue]
> If you are going for an emissions test soon, the ECM will have[color=green]
>>[/color]
> jl
>[/color]
There is a specific definition of a "trip cycle," depending on the vehicle,
engine, and transmission combination that involves a cold start, driving at
specific speeds for specific distances, then shutting down for a certain
amount of time and starting over.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
starter problem sureshot 89-95 Toyota Pickup/Hilux 10 12-14-2006 09:24 PM
Toyota and Nevada Partners Team Up 02AspenGreen Toyota News 0 04-13-2006 08:41 PM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 08:04 PM
