Post-flood Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2006, 12:37 AM   #1 (permalink)
starqueg@gmail.com
Guest
Posts: n/a
View starqueg@gmail.com's Photo Gallery
Post-flood Corolla
So, I drive a 2001 Corolla, keep it in great shape, and what happens?
We get 3 inches of rain in one afternoon. The interior is destroyed,
carpets and seats are soaked, and were still wet the next morning. I
thought that it was okay otherwise, but now the SRS warning light is
staying on. I'm taking it to the dealer on Monday morning and meeting
with a claims adjuster on Tuesday. I'm afraid that this warning light
could be a sign of electrical damage, sort of a sign of impending doom.
Anybody know if that's a good bet, or if I'm over-reacting?
Rachel, the proud owner of a swimming car
Old 11-18-2006, 01:19 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Post-flood Corolla
<starqueg@gmail.com> wrote in message
news:1163831839.084702.45840@h54g2000cwb.googlegroups.com...[color=blue]
>[/color]
If the vehicle was submerged, it is time to get another one.
Ray O
Old 11-18-2006, 08:41 AM   #3 (permalink)
starqueg@gmail.com
Guest
Posts: n/a
Thanks Ray. I guess I already knew that, I just keep hoping that
someone will have a magical way to save my car. I'm quite frustrated,
mainly cause this happened right before Thanksgiving break (I'm away at
college) and was my way home.
Thanks again.
Rachel
Ray O wrote:[color=blue]
> news:1163831839.084702.45840@h54g2000cwb.googlegroups.com...[color=green]
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
Old 11-18-2006, 09:22 AM   #4 (permalink)
Fishface
Guest
Posts: n/a
View Fishface's Photo Gallery
> If the vehicle was submerged, it is time to get another one.[/color]
Surely rain water is not as bad as sea water.
I'd have been out there extracting the water from everything
with the carpet cleaner or shop vac, ASAP, maybe parked
at a very steep angle to help it drain. The WD in WD-40 is
"water displacer." Too bad it stinks...
Old 11-18-2006, 11:33 AM   #5 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
The SRS light simply means that the airbag(s) will not deploy when called
upon. If you manage to avoid those situations, then you will be fine. Take
the drive home for Turkey Day.
The SRS system looks at the seats and seatbelts to set itself up properly.
If the system detects any anomoly during the self test -- the period
immediately following turning the key to ON -- then the light will come on.
SRS is a "safety of flight" item that will not reset itself, even when the
condition is corrected or mysteriously goes away. (By definition, this is
not a condition that can "mysteriously go away.") Earlier I said the self
test period, but that is a bit erroneous, the SRS system continuoulsy checks
itself to determine its integrity. All this means is that the sysem could
pass the self test period, but the light can come on at any time while the
vehicle is in operation. The bottom line is that once the light comes on,
the system will not reset, it must be reset by a technician -- presumably
after an exhaustive check to ensure system integrity.
My guess is that you have a problem with one or more of the switches in the
seats and seatbelts.
news:1163860861.225082.93250@m73g2000cwd.googlegroups.com...[color=blue]
> Thanks again.
> Rachel
> Ray O wrote:[color=green]
>> news:1163831839.084702.45840@h54g2000cwb.googlegroups.com...[color=darkred]
>> >[/color]
>> Ray O
>[/color]
Old 11-18-2006, 11:45 AM   #6 (permalink)
Built_Well
Guest
Posts: n/a
View Built_Well's Photo Gallery
[email]starqueg@gmail.com[/email] wrote:[color=blue]
> Rachel, the proud owner of a swimming car[/color]
Sorry to hear about your misfortune. I'm kinda curious though.
How did the interior become soaked from a rainstorm? Were the
windows down or something? In any case, good luck.
Old 11-18-2006, 12:08 PM   #7 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Fri, 17 Nov 2006 22:37:19 -0800, starqueg wrote:
[color=blue]
Water is a weird thing in a car.
I just read an article that said the low intakes on new cars can cause
Hydraulic Lock, a condition where water gets into the engine. Liquids are
not compressable, and can severely damage an engine if you start the car
with water in the engine. Hopefully this is not your case...
Water also seeps places. I used to work at a dealer where we sold flooded
cars. If you have the equipment and the know-how, you can salvage the car
in decent shape. This means removing the seats and carpeting, and having
an 'extractor' helps; kind of a super carpet cleaner designed to extract
water from upholstery. They are expensive; a good detailer will have one,
but expect to pay!
After reomving the carpeting, you need to use a Shop Vac (or better!) to
collect all the water from the creases and folds in the body panels. It's
nice to have a nice, warm sunny day to to this! You extract the water from
the seat and carpeting and let them sit in the sun; if you get to it RIGHT
AWAY they won't smell musty when you're done.
Then, you have to get the water out of the other body panels, like rocker
panels and the trunk, etc. This requires removing the panels from the
doors, the rear panels, the seats, and any sound deadening or insulation
materials, so you have a bare interior. Again, vaccum all the water out
using a good wet/dry vacuum. Then, get a 5 gallon pail of hydraulic oil
and a sandblaster with a good compressor, and spray the oil into the
creases and crevices (note: this is ILLEGAL in some states! In Mass it is
not allowed, but in Vermont, it is!) until no water can be seen in the oil
(this is also a good way to rustproof the car.) You may have to punch
holes to spray the rocker panels, and spray the floor of the car and the
body panels, doors, fenders, etc. Five gallons (~$30) should do it.
You can see, this is a pretty involved operation, and you may still not
get all the water out, leading to early rusting. A good detailer can do
this in a couple days for a couple hundred bucks or so, anything less than
that and you want to watch the guy to make sure he does it right! Or, if
you have someone car savvy with the right equipment you can get to do it
for you, so much the better.
After the interior and the body panels and rockers are done, you want to
put the car on a lift and spray the underside thoroughly, also, and chase
any more water away.
Old 11-18-2006, 02:43 PM   #8 (permalink)
n5hsr
Guest
Posts: n/a
View n5hsr's Photo Gallery
"Hachiroku" <Trueno@AE86.gts> wrote in message
news:P_H7h.1911$Kw2.1131@trndny05...[color=blue]
>[color=green]
> but expect to pay!
> any more water away.[/color]
I had a friend from work sucked water up into her Fine American Car trying
to get through a viaduct one day after a good rain and totally ruined the
engine. The insurance company was a bit snotty about paying out, too.
Charles of Schaumburg
Old 11-18-2006, 04:54 PM   #9 (permalink)
Ray O
Guest
Posts: n/a
> Thanks again.
> Rachel[/color]
You're welcome.
If the carpets are a little wet, then the car is probably fine. If the car
was submerged, most the elctronics will eventually fail.
Ray O
(correct punctuation to reply)[color=blue]
>> >[/color]
>> Ray O
>[/color]
Old 11-19-2006, 02:42 AM   #10 (permalink)
starqueg@gmail.com
Guest
Posts: n/a
I guess I didn't make myself clear in my initial post. The rain caused
the storm drains to spew water into the parking lot where I was "lucky
enough" to park (what is a hard lot to get a spot in at my apt). My
car was partially submerged, maybe 4/5 of the tires were underwater.
The waterline on the back was midway on the rear bumper, and there was
also a waterline on the inside of the doors. I didn't have time to
check on the condition of my car today, but it is still going to the
dealer for an intensive check-up on Monday.
> news:1163860861.225082.93250@m73g2000cwd.googlegroups.com...[color=green]
> > Thanks again.
> > Rachel[/color]
> You're welcome.
> Ray O
> (correct punctuation to reply)[color=green]
> > Ray O wrote:[color=darkred]
> >> Ray O
> >[/color][/color]
Old 11-19-2006, 12:18 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:1163925733.939527.291610@h48g2000cwc.googlegroups.com...[color=blue]
> dealer for an intensive check-up on Monday.[/color]
It sounds like the car was submerged enough to cause some serious problems.
At the very least, all of the fluids will have to be changed, including
engine, transmission, differential, steering, and brake fluids; I would also
change the wheel bearings and every sensor and computer that was submerged.
Computers are about $1,000 each and can include the engine, transmission
(for automatic transmission-equipped vehicles, air bag, cruise control,
antilock brakes, air conditioner, etc. You may have problems with interior
electrical connectors corroding because they are not designed to be
weatherproof so you may encounter future electrical problems.
I would also pull the interior out, including the seats, interior door trim,
and carpets for a thorough cleaning and drying of the trim and what is
underneath so you don't get mold buildup.
Ray O
Old 11-19-2006, 12:43 PM   #12 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sun, 19 Nov 2006 12:18:43 -0600, "Ray O"
<rokigawaATtristarassociatesDOTcom> wrote:
[color=blue]
>news:1163925733.939527.291610@h48g2000cwc.googlegroups.com...[color=green]
>underneath so you don't get mold buildup.[/color]
If it were mine, I'd make a path to my insurance agent and get a new
car...
Scott in Florida
Old 11-19-2006, 02:16 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
"Scott in Florida" <askifyouwant@mindspring.net> wrote in message
news:0e91m2t52esknkt9nili82hkgj7k0vjahr@4ax.com...[color=blue]
>[color=green]
>>news:1163925733.939527.291610@h48g2000cwc.googlegroups.com...[color=darkred]
>>problems.
>>also
>>submerged.
>>interior
>>trim,
> car...
> Scott in Florida
>[/color]
I guess that was the point I was trying to make - doing all that work could
cost more than the car is worth, without even taking into account the other
problems that may surface later.
Ray O
Old 11-22-2006, 09:20 AM   #14 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
> Ray O
lol, yes it would have to be a classic or uninsured even for me to
bother with that - and you know the work Ive done on mine!
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
2007 Corolla Information (Corolla XRS R.I.P) silver04rollas Toyota News 111 08-27-2007 03:17 PM
Questioning the 2006 Corolla again...... RAV4EVR Toyota News 16 08-01-2005 12:26 PM
EVO and Skyline body kits for the Camry, corolla, and Celica! [SMAN] Camry & Solara Lounge 19 07-21-2003 11:14 PM
