1991 Previa Instrument Gauge lights gone - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2006, 03:35 PM   #1 (permalink)
Matty
Guest
Posts: n/a
View Matty's Photo Gallery
Just the other night, I hopped in the Previa to run an errand and when
I went to turn the headlights on, NONE of the speedmeter lights worked
including temp and gas. Fuse seems to be okay. Any ideas about what the
problem could be?
This is really bugging me.
Thanks,
Matty
Old 11-18-2006, 03:41 PM   #2 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: 1991 Previa Instrument Gauge lights gone
One
Check to see if the tail lamps are working or not. The tail lamps and the
instrument panel lights share the same fuse. If the tail lamps are not on,
then you haven't found the correct fuse yet.
Two
There is a knob that adjusts the brighness of the instrument panel lamps.
Have you checked the knob to see if it is adjusted to the correct
position -- basically any position that is not Full Off.
"Matty" <mattguillory@gmail.com> wrote in message
news:1163882159.472049.68080@k70g2000cwa.googlegroups.com...[color=blue]
> problem could be?
> Thanks,
> Matty
>[/color]
Old 11-18-2006, 03:59 PM   #3 (permalink)
Matty
Guest
Posts: n/a
Hi Jeff,
Thanks for the quick reply.
The tail lights are fully functional. That was actually the first thing
I checked. And the dimmer dial is set to maximum brightness. I am
totally confused.
This problem really has me scratching my head.
-Matty
Jeff Strickland wrote:[color=blue]
> One
> Two
> news:1163882159.472049.68080@k70g2000cwa.googlegroups.com...[color=green]
> > problem could be?
> > Thanks,
> > Matty
> >[/color][/color]
Old 11-18-2006, 04:15 PM   #4 (permalink)
Jeff Strickland
Guest
Posts: n/a
My vote is that the dimmer has failed.
news:1163883579.527459.95580@e3g2000cwe.googlegroups.com...[color=blue]
> Hi Jeff,
> totally confused.
> -Matty
> Jeff Strickland wrote:[color=green]
>> One
>> on,
>> Two
>> news:1163882159.472049.68080@k70g2000cwa.googlegroups.com...[color=darkred]
>> > problem could be?
>> > Thanks,
>> > Matty
>> >[/color][/color]
>[/color]
Old 11-18-2006, 04:18 PM   #5 (permalink)
Matty
Guest
Posts: n/a
The A/C climate control lights still work and the dimmer can still
control those. Does that still mean that the dimmer control needs to be
replaced?
Thanks,
Matty
> news:1163883579.527459.95580@e3g2000cwe.googlegroups.com...[color=green]
> > Hi Jeff,
> > totally confused.
> > -Matty
> > Jeff Strickland wrote:[color=darkred]
> >> One
> >> on,
> >> Two
> >> > problem could be?
> >> > Thanks,
> >> > Matty
> >> >[/color]
> >[/color][/color]
Old 11-18-2006, 04:25 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
That would have been good to tell us earlier. ;-)
So, SOME of the instrument panel lights come on and can be controlled by the
dimmer?
news:1163884739.059803.42610@m7g2000cwm.googlegroups.com...[color=blue]
> replaced?
> Thanks,
> Matty
>> news:1163883579.527459.95580@e3g2000cwe.googlegroups.com...[color=darkred]
>> > Hi Jeff,
>> > totally confused.
>> > -Matty
>> >> One
>> >> the
>> >> on,
>> >> Two
>> >> lamps.
>> >> > when
>> >> > worked
>> >> > the
>> >> > problem could be?
>> >> > Thanks,
>> >> > Matty
>> >[/color][/color]
>[/color]
Old 11-18-2006, 04:32 PM   #7 (permalink)
: P
Guest
Posts: n/a
View : P's Photo Gallery
I know the OP has a '91, but maybe this can help.
My '92 Toyota shop manual says:
Problem: Instrument lights do not light up (taillight light up)
Possible cause: Wiring or ground faulty
Remedy: Repair as necessary
> problem could be?
> Thanks,
> Matty
>[/color]
Old 11-18-2006, 04:36 PM   #8 (permalink)
Matty
Guest
Posts: n/a
Sorry Jeff, I should have been more specific.
As of now, ONLY the speedo cluster lights are not working. The A/C
climate control lights are working just fine and are still adjustable
with the dimmer dial. Tail lights are working fine.
Here are some recent mods I have done with the previa:
1) Installed an aftermarket stereo/dvd and satellite radio receiver
about a week and a half ago (Which is working just fine)
2) Replaced 4 speedo 194-gauge bulbs with 194-gauge LEDs about 3 weeks
ago.
Everything was working like a charm up until 2 nights ago.
-Matty
> dimmer?
> news:1163884739.059803.42610@m7g2000cwm.googlegroups.com...[color=green]
> > replaced?
> > Thanks,
> > Matty
> >> > Hi Jeff,
> >> > totally confused.
> >> > -Matty
> >> >> One
> >> >> the
> >> >> on,
> >> >> Two
> >> >> lamps.
> >> >> > when
> >> >> > worked
> >> >> > the
> >> >> > problem could be?
> >> >> > Thanks,
> >> >> > Matty
> >> >[/color]
> >[/color][/color]
Old 11-18-2006, 04:46 PM   #9 (permalink)
: P
Guest
Posts: n/a
Heres another trouble shooting tip I found in another section. (I tried
sending a jpeg of the page but it wouldn't go through.)
Problem: Meter illumination lights do not light up
Possible cause: (1) Bulb burned out, (2) Light control rheostat faulty, (3)
Remedy: (1) Replace bulbs, (2) Check rheostat, (3) Repair as necessary
": P" <none@none.net> wrote in message
news:oZK7h.7095$Fg.255@tornado.socal.rr.com...[color=blue]
>> problem could be?
>> Thanks,
>> Matty
>>[/color]
>[/color]
Old 11-18-2006, 04:51 PM   #10 (permalink)
Matty
Guest
Posts: n/a
Hmmmm Considering the dimmer is still functional for the A/C climate
control, that only leads me to believe that there is a grounding issue.
Thanks for all the help guys. I appreciate it.
BTW... have you ever seen a convertable Previa? I've seen two custom
ones from Japan. Coolest thing I have ever seen. One was more luxury
style, and the other was more racing style with six racing seats!
-Matty
: P wrote:[color=blue]
> news:oZK7h.7095$Fg.255@tornado.socal.rr.com...[color=green]
> >> problem could be?
> >> Thanks,
> >> Matty
> >>[/color]
> >[/color][/color]
Old 11-18-2006, 05:37 PM   #11 (permalink)
Jeff Strickland
Guest
Posts: n/a
I'd be looking to the mods as the source of the problems. Since the stuff
you DID NOT modify is still working properly, my guess is that the stuff you
did modify has failed.
news:1163885773.675749.89170@m7g2000cwm.googlegroups.com...[color=blue]
> ago.
> -Matty
>> the
>> dimmer?
>> news:1163884739.059803.42610@m7g2000cwm.googlegroups.com...[color=darkred]
>> > replaced?
>> > Thanks,
>> > Matty
>> >> > Hi Jeff,
>> >> > thing
>> >> > totally confused.
>> >> > -Matty
>> >> >> One
>> >> >> and
>> >> >> the
>> >> >> not
>> >> >> on,
>> >> >> Two
>> >> >> lamps.
>> >> >> > when
>> >> >> > worked
>> >> >> > what
>> >> >> > the
>> >> >> > problem could be?
>> >> >> > Thanks,
>> >> >> > Matty
>> >[/color][/color]
>[/color]
Old 11-18-2006, 06:16 PM   #12 (permalink)
Andrew Stephenson
Guest
Posts: n/a
View Andrew Stephenson's Photo Gallery
In article <xqedndEwaLayFsLYnZ2dnUVZ_rSdnZ2d@ez2.net>
[email]crwlr@yahoo.com[/email] "Jeff Strickland" writes:
[color=blue]
> the stuff you DID NOT modify is still working properly, my
> guess is that the stuff you did modify has failed.[/color]
Or he disturbed some old wiring/connector that was ready to snap.
Disconnect the plugs &c in that region, clean carefully and check
wire continuities (or test for volts at connectors if they should
be there), then reconnect. If still bust... it was worth trying.
Andrew Stephenson
Old 11-18-2006, 08:32 PM   #13 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> replaced?
> Thanks,
> Matty[/color]
No, that means the dimmer is good.
See my first post.
Ray O
(correct punctuation to reply)[color=blue]
>> > Hi Jeff,
>> > totally confused.
>> > -Matty
>> >> One
>> >> the
>> >> on,
>> >> Two
>> >> lamps.
>> >> > when
>> >> > worked
>> >> > the
>> >> > problem could be?
>> >> > Thanks,
>> >> > Matty
>> >[/color][/color]
>[/color]
Old 11-18-2006, 08:33 PM   #14 (permalink)
Ray O
Guest
Posts: n/a
> problem could be?
> Thanks,
> Matty
>[/color]
The most likely cause is that all of the bulbs are burnt out. Check the
bulbs, and if they are good, check for a bad ground or damaged wiring.
Ray O
Old 11-18-2006, 08:36 PM   #15 (permalink)
Ray O
Guest
Posts: n/a
> ago.
> -Matty
>[/color]
OK, you probably disturbed the ground wires. Check to make sure the LED's
are working. I'd bet they failed.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Instrument Lights king_picotto Camry & Solara Lounge 4 04-18-2006 07:35 PM
For Sale 1991 Previa 174K 2WD crewfor32 Vehicles 0 05-12-2005 05:04 PM
gauge cluster lights SLY Mantis Archived Corolla threads 3 06-28-2003 10:12 PM
Gauge and instrumental panel lights are dim... Stealth Camry & Solara Lounge 4 06-28-2003 02:44 PM
CAN MY GAUGE LIGHTS GET BRIGHTER? spills1969 Camry & Solara Lounge 4 12-13-2002 12:45 PM
