Re: no electrical - i mean nothing
"anon" <nobody@nowhere.really.com> wrote in message
news:jNY9h.24312$m9.11378@bignews2.bellsouth.net...[color=blue]
>i have a 1995 Geo Prizm that i haven't driven in several weeks, about a
>month or so. I went to start it & got nothing -- no lights, nothing
>electrical works.
> i've even tried a jumper on the battery & get nothing. Any idea what the
> problem might be? someone suggested the battery cable since the boost
> should be bypassing the battery. The battery has water in it. I've
> looked thru the manual & cannot see that any blown fuse would cause a
> complete lack of response for the entire electrical system. The
> alternator is fairly new (~2 yrs.).
> i'm thinking about carrying the battery to a store to have it checked, but
> given the jumping failure, is that even worthwhile?
> thanks!
>[/color]
Guesses will be just that - guesses.
To diagnose the problem properly, you will need at least a volt meter to
check battery charge. If the battery cable connections are corroded, get a
battery terminal brush and wearing protective goggles and old clothes, clean
the battery terminal and cable clamps and then clean up the mess with a
poultice made from baking soda and a little water, then hose everything down
thoroughly. After the connections are good and clean and tight, try
charging the battery for an hour or so at a trickle or hooking up the jumper
vehicle for a good 5 ~ 10 minutes before attempting to start. With the volt
meter, check battery voltage before and after charging.
If the battery terminals were badly corroded, then it may have been parked
without a full charge, and the battery will discharge over time. If the
battery is left in a discharged state, it will become sulfated and lose its
ability to hold a charge. If the battery is over 4 years old, then the most
likely cause of the problem is a bad battery.
Ray O
