Re: 1993 Corola timing - update
"Ralph" <nospam@thanks.com> wrote in message
news:45685b68_1@news.cybersurf.net...[color=blue]
> The exhaust camshaft knockpin was bent by the timing sprocket, due to
> force exerted counterclockwise, by attempting to loosen the crank pulley
> bolt while the camshaft gears were blocked by a rag. (Never do this).
> The hidden damage retarded both valve timing and ignition timing. The
> distributor is driven directly by the exhaust (front) camshaft.
> The force applied at the time (or later attempts to remove the bent knock
> pin) caused hairline cracks at the perimeter of the camshaft at the pin
> bore. A good used camshaft was installed and the engine seems to be
> working properly.
> Thanks to the group for advice, especially the kind comments of Ray O.
> Jack[/color]
Thanks for the update!
Ray O
