91 Camry Le.. Failed emissions NOx and very high % O2... Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-25-2006, 05:16 PM   #1 (permalink)
Al Kondo
Guest
Posts: n/a
View Al Kondo's Photo Gallery
I just had my 91 Toyota Camry Le inspected for emissions. It passed
everything but NOx. I had the following readings
High Speed Test Low Speed Test
Standard Current Standard Current
HC 123 26 128 127
CO (%) .69 .13 .71 .31
C02(%) 14.6 14.4
O2 (%) 19.7 20.4
NOx 878 1093 970 947
The part that I am especially puzzled about is the very high O2
readings. In my test of last year, I had readings in the .5% range.
How in the world can I get a reading of 20% or more? In fact, isn't
the atmospheric % of O2 in the range of 20%? Is it possible that I
had a reading which reflects only that of atmospheric O2?
I would appreciate opinions on what is going on.
Thanks, Al
Old 11-25-2006, 09:37 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 91 Camry Le.. Failed emissions NOx and very high % O2... Help
"Al Kondo" <alkon@hal-pc.org> wrote in message
news:lkjhm2t3uhrf5mnc962h0do8leqmhnh0rc@4ax.com...[color=blue]
> HC 123 26 128 127
> C02(%) 14.6 14.4
> O2 (%) 19.7 20.4
> Thanks, Al[/color]
Several things can cause high Nox.
Check your EGR valve function by applying vacuum to the EGR while the engine
is idling. If the EGR is functioning properly, the engine will start to
stall if you apply EGR at idle. If the engine starts to stall when applying
vacuum, check the vacuum switching valves that control the EGR. This link
[url]http://oregonstate.edu/~tongt/camry/90/Emission_Control.pdf[/url] explains some of
the emissions control systems, including the EGR valve and controls.
Also check ignition timing and advance.
This link has info for the rest of the car:
[url]http://oregonstate.edu/~tongt/camry/index.html[/url]
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
