Re: Late '87 Tercel sedan with 5 speed trans question.
Ray, Nick and Hachi,
Thank You for your replies. I guess my course of action is to first try it
with the tranny in the car, and then when things get too difficult, go ahead
and pull it out. Or I guess I could just get a shift knob with the a
4-speed pattern engraved in it instead of the present 5-speed one and trade
it off.<g> Only kidding.
Thanks again,
Lee Richardson
"Hachiroku ????" <Trueno@AE86.gts> wrote in message
news:EJgah.7744$7a2.670@trndny06...[color=blue]
> On Sun, 26 Nov 2006 20:39:16 +1000, Nicholas Bourne wrote:
>[color=green]
>> If you feel confidant than you may be able to do it. I know of a guy who
>> had
>> the same problem in a corolla
>> he had to lower the box a bit to get the housing off but he did it. All
>> he
>> had to do was change the bearings at the end of the shafts to fix the
>> problem.[/color]
> He was lucky! Usually jumping out of gear is an indication the gears are
> worn.
> I can see where worn bearings would cause jumping, but it seems to me it
> would happen in more than one gear.
> If this fixes it, so much the better!
>[color=green]
>> "Lee Richardson" <mechtech@sigecom.net> wrote in message
>> news:AuednYTQ-fjBfPXYnZ2dnUVZ_sadnZ2d@sigecom.net...[color=darkred]
>>> This car "only" has 115,000 miles and jumps out of 5th gear. All other
>>> gears and the clutch work fine. Problem has gradually gotten worse
>>> until
>>> now 5th gear cannot be used at all. It will go in, but will jump out
>>> within a few seconds. I have the factory shop manual, and it looks like
>>> all the parts relating to 5th gear are on the very back end, or I guess
>>> I
>>> should say driver side end of the tranny. There appears to be a good 6"
>>> of clearance between the removable cover and the fenderwell. I guess
>>> you
>>> can see where I am going with this, would it be possible to fix this
>>> problem with the tranny in the car? While I would be capable of pulling
>>> the tranny, if I did so I would want to replace the friction disc,
>>> pressure plate, etc, greatly increasing the parts cost and time the car
>>> would be out of service. I would also have to disturb the axle shafts
>>> and
>>> boots, all of which appear to be in good condition right now, but might
>>> not survive all the flexing around from being disconnected and
>>> reinserted..
>>> In the mean time, the little car still gets 32 mpg easy in city/highway
>>> mix with just 4 speeds. But it is tachin' about 4000 RPM at 70 mph, and
>>> it would just be nice to have 5 speeds again. The body and interior are
>>> in great shape, it uses a little oil, but the original variable venturi
>>> "carb from hell" even works fine on this one.
>>> Lee Richardson
>>> Mech-Tech
>>> Evansville, Indiana
>>>[/color][/color]
>[/color]
