93 Corolla - Oil Pan Replacement Charge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-26-2006, 08:13 PM   #1 (permalink)
Leonard M. Wapner
Guest
Posts: n/a
View Leonard M. Wapner's Photo Gallery
Last month we had our 93 Corolla serviced at a Chevron station. We were
told the threads were stripped on the oil pan drain and the pan would have
to be replaced. We agreed and the bill came to $400+ for parts and labor.
Was the charge excessive?
L
Old 11-26-2006, 11:37 PM   #2 (permalink)
Reasoned Insanity
Guest
Posts: n/a
View Reasoned Insanity's Photo Gallery
Re: 93 Corolla - Oil Pan Replacement Charge
"Leonard M. Wapner" <lwapner@adelphia.net> wrote in message
news:t-udnbsfSfIh1PfYnZ2dnUVZ_vydnZ2d@adelphia.com...[color=blue]
> L
>[/color]
Only by about $350 IMO
Old 11-27-2006, 02:24 AM   #3 (permalink)
Truckdude
Guest
Posts: n/a
View Truckdude's Photo Gallery
"Reasoned Insanity" <mintclovers@@yahoo.com> wrote in message
news:DQuah.246$_s7.47@newsfe21.lga...[color=blue]
> news:t-udnbsfSfIh1PfYnZ2dnUVZ_vydnZ2d@adelphia.com...[color=green]
>> have to be replaced. We agreed and the bill came to $400+ for parts and
>> labor. Was the charge excessive?
>> L
>>[/color]
>[/color]
You think he should have paid no more than $50 parts and labor for a new oil
pan?? Get real!
Old 11-27-2006, 02:45 AM   #4 (permalink)
BigJim
Guest
Posts: n/a
View BigJim's Photo Gallery
you just retap and fit a new bolt and washer
"Truckdude" <shrub@laimeduck.com> wrote in message
news:hhxah.34316$a_2.17556@trnddc01...[color=blue]
> news:DQuah.246$_s7.47@newsfe21.lga...[color=green]
>> news:t-udnbsfSfIh1PfYnZ2dnUVZ_vydnZ2d@adelphia.com...[color=darkred]
>>> L
>>>[/color]
>>[/color]
> oil pan?? Get real!
>[/color]
Old 11-27-2006, 10:19 AM   #5 (permalink)
nospampls2002@yahoo.com
Guest
Posts: n/a
View nospampls2002@yahoo.com's Photo Gallery
Leonard M. Wapner wrote:[color=blue]
> Was the charge excessive?[/color]
This brings to mind a variety of issues.
First, if you use a fresh gasket and do not over tighten the drain
bolt, they do not strip. Seems like the quick oil change places like to
really crank on drain bolts. Once had the clutch replaced in my 1977
Toyota truck which I had been servicing at a quick lube place and when
the shop called to say the work was done it took the better part of
another hour for the owner of that shop to cut and heat the fill plug
with an acetylene torch to finally be able to add transmission fluid.
Obviously, that plug should never have been that tight -- gives another
good reason to do your own work. Toyota actually supplies torque
figures but apparently they're not often used.
Second, as you probably now realize, you must always confirm the price
or at least a written estimate, before the work begins. Also, it would
appear the drain bolt was holding before they touched it. There may be
some culpability there.
As others have mentioned, it may have been possible to repair the drain
or tap in new threads for a slightly larger bolt.
However, you really don't want to take chances with having a leak that
would cause you to lose engine oil.
Replacing the oil pan is not as simple as it may sound.
The exhaust pipe has to come off and the fasteners should be replaced
along with the sealing gaskets.
Then there are a lot of small bolts around the edge of the oil pan
which should be tightened progressively. I believe you need the FIPG
(form in place gasket material) to re seal the pan, so the surfaces
have to be completely clean of all oil prior to reassembly which has to
be performed within a very short time of applying the sealant. The
mating surface on the underside of the block also has to be clean. Best
to wipe it with a solvent first, then work quickly before residual oil
drips back down again.
The bead of sealant has to be applied around the bolt holes and close
enough to the edge at the region of the rear main to avoid leaks.
Done right, this is a durable repair.
Usually charges are based on an hourly rate times the number of hours,
plus the cost of new parts.
First time I did one of these it took a long time, I sliced open my
finger reapplying the sealant I smeared by mispositioning the pan on
the first try, but got it right the second time. Probably removing and
reapplying the sealant provided an even better seal being all surfaces
were cleaned and "primed" twice.
Point is, it is not a particularly simple job.
Old 11-27-2006, 12:39 PM   #6 (permalink)
mack
Guest
Posts: n/a
View mack's Photo Gallery
Replacing the oil pan for the reason of the stripped thread seems a little
(ok, a lot) excessive. Like replacing the engine because you have a broken
bolt in the cylinder head.
I would guess that the service station people didn't do the work themselves,
because of their lack of expertise ...which they may have shown if they
themselves stripped the drain plug.
could the OP please break down the costs involved as regards parts and
labor, please?
<nospampls2002@yahoo.com> wrote in message
news:1164644356.273101.127950@14g2000cws.googlegroups.com...[color=blue]
> Leonard M. Wapner wrote:[color=green]
>> have
>> labor.
>[/color]
Old 11-27-2006, 05:28 PM   #7 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Mon, 27 Nov 2006 08:24:45 GMT, "Truckdude" <shrub@laimeduck.com>
wrote:[color=blue]
>> news:t-udnbsfSfIh1PfYnZ2dnUVZ_vydnZ2d@adelphia.com...[/color][/color]
[color=blue][color=green][color=darkred]
>>> labor. Was the charge excessive?[/color]
>> Only by about $350 IMO[/color]
>pan?? Get real![/color]
I would have gone for an oversized drain plug first, if at all
possible. They are designed for that express purpose, and you'd have
lots of change left from that $50.
Especially when that damage can almost always be traced back to
over-torquing the plug by a Gorilla with a six-foot wrench in the lube
bay, either on this oil-change visit or within the last few. And
they'll never admit it.
("Oops, look what we did... Hang on, the customer is coming over.")
"Gee, Sir, look what we found. Looks like someone stripped it the
last time."
(If they were the ones who worked on it the last time, they'd blame
it on the threads wearing out.)
Myself, if the pan had to come off I would MIG-weld, TIG-weld or
silver-braze on a hex nut with the right metric threads for the stock
drain plug. Fix it once.
You hold the hex nut in position with a metric bolt and a washer to
protect the new nut where the new seal face will be, and you put a big
copper washer on the backside to protect against burn-through of the
pan sheetmetal while welding the nut on.
(Copper is highly thermally conductive and when used as a backup
plate will chill the weld puddle and stop the blow-through, usually
without it sticking to the weld metal. You'll still have to clean up
the backside with a grinder, but you won't be facing a disaster,
trying to fill in a hole that keeps getting bigger.)
--<< Bruce >>--
Old 11-27-2006, 08:49 PM   #8 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
You can buy an expanding rubber plug for $2 that fixes such a problem.
> L
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
oil pan leak nova-rolla Archived Corolla threads 21 11-22-2006 12:58 PM
Does the Oil Pan have a gasket? NickR Tercel, Paseo, Starlet, and Sera Forum 8 06-28-2006 08:55 AM
coolant in my oil pan headcrank Celica Forum 14 03-26-2005 12:59 AM
