Headlight bulb change 2000 corolla - how to do it - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2006, 11:31 AM   #1 (permalink)
ez24
Guest
Posts: n/a
View ez24's Photo Gallery
Hi
My left front headlight is out and I bought a replacement bulb. I have
replaced bulbs in the past on my cars but cannot figure this one out.
There is not much room in the back to access. I took out 2 bolts that
hold a fuse holder that is behind and to the top of the light to gain
access. But this only moved it an inch. Was able to disconnect the
connector but that is far as I have been able to get.[color=blue]
>From the back I cannot get ahold of anything that seems like it has a[/color]
clip on snap or whatever.
But the bulb looks like it is mounted from the rear.
There are 2 metal clips that hold the front lens and I took them off
but the lens would not come off. I tried a little force but was afraid
to use a lot of force because I don't know if this is the way or not.
I guess the first thing to know is do I go from the front or back on
this?
Thanks in advance and in the mean time I will won't drive at night.
Old 11-30-2006, 11:42 AM   #2 (permalink)
JoeSpareBedroom
Guest
Posts: n/a
View JoeSpareBedroom's Photo Gallery
Re: Headlight bulb change 2000 corolla - how to do it
"ez24" <ez24hours@yahoo.com> wrote in message
news:1164907861.671221.160530@j72g2000cwa.googlegroups.com...[color=blue]
> Hi
> connector but that is far as I have been able to get.[color=green]
> this?
>[/color]
I just peeked at the arrangement in my Tacoma pickup, but it's not typical
of other Toyotas I've had in the past. Mine's got a plastic "cup" with a tab
on top, and the inscription "Pull Top Out". In previous Toyotas, I'd pull
the plug (which you've done already), and what was left was a plastic thing
that you'd turn about 1/4 turn, and it would then separate from the metal
housing by pulling straight out. They had a bayonet-style fastening system.
There's tension on them because of an O-ring which serves to seal out
moisture, so you have to press the plastic thing forward to relieve the
tension, and then turn it. There's usually some dirt buildup in there which
makes them harder to turn.
Just a guess, but probably a good one!
Don't mess with the lens. Otherwise, you may misalign the thing and end up
with one light pointing in a stupid direction. Then, other drivers will want
to kill you.
Old 11-30-2006, 11:48 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> Hi
> this?
>[/color]
The lens only comes off once so put those clips back on ;-)
The bulb is removed and installed from the rear of the headlight assembly.
The bulb is held in place with a plastic ring. The ring has raised numbs to
make it easier to grip. Unplug the socket from the back of the bulb and
turn the ring counter-clockwise to unlock the ring, then pull the ring and
bulb straight back towards the firewall. Over time, the ring tends to get
stuck and may take a fair amount of force to unstick. Do not touch the
glass part of the replacement bulb with your bare hands or let any dirt,
grease, or oil get on it because the bulb's life will be reduced
significantly. If you already touched the glass, wipe it clean with rubbing
alcohol and use a clean cloth or paper towel if you have to handle the
glass.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
05 corolla tail light bulb oem mismatch-any one else had this issue? ekimwons Archived Corolla threads 3 06-10-2006 08:43 AM
Headlight Bulb Info - Halogen, HID, HIR, Lumins, etc... BLUEMEANIE General Discussion 2 02-09-2005 01:19 PM
The 2003 corolla vs 2000 Ford Focus dbellemafia Archived Corolla threads 16 09-23-2004 12:29 PM
